PETSc segmentation fault during adaptive remeshing after ~2300 steps
import os
from pathlib import Path
import ngsPETSc.utils.fenicsx as ngfx
from packaging.version import Version
from netgen.geom2d import SplineGeometry
from ufl import (
    FacetNormal,
    Identity,
    TestFunction,
    TrialFunction,
    div,
    dot,
    ds,
    dx,
    inner,
    lhs,
    nabla_grad,
    rhs,
    sym,
    TestFunctions,
    split,
    variable,
    diff,
    inner,
    grad,
    as_vector,
    sqrt
from dolfinx import default_real_type, log, plot,mesh,geometry
from dolfinx.fem import(
    Function,
    functionspace,
    Expression,
    Constant,
    Function,
    extract_function_spaces,
    functionspace,
    assemble_scalar,
    dirichletbc,
    form,
    locate_dofs_geometrical,
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem
import pyvista as pv
import pyvista
try:
    import pyvistaqt as pvqt
    have_pyvista = True
except ModuleNotFoundError:
    print("pyvista and pyvistaqt are required to visualise the solution")
    have_pyvista = False
from dolfinx import fem
# Save all logging to file
log.set_output_file("log.txt")
rank = MPI.COMM_WORLD.rank
######ORIZW TIS PARAMETROUS POU EINAI STATHERES
r0=5
e4=0.05
Delta=0.65
W0=1
D=1
tau0=1
l=1.5957*D
lamda =1.5957*D
dt =0.016  ## XRONIKO BIMA
t=0
T= 150 # XRONIKI PERIODOS
MPI.COMM_WORLD.Barrier()
start_time = MPI.Wtime()
######################### MESH NETGEN
geo=SplineGeometry()
pnts= [(-400,-400),(400,-400),(400,400),(-400,400)]
p1,p2,p3,p4 = [geo.AppendPoint(*pnt) for pnt in pnts]
curves = [
    [["line",p1,p2],"line"],
    [["line",p2,p3],"line"],
    [["line",p3,p4],"line"],
    [["line",p4,p1],"line"],
for c,bc in curves :
    geo.Append(c,bc=bc)
geoModel = ngfx.GeometricModel(geo, MPI.COMM_WORLD)
domain, (ct, ft), region_map = geoModel.model_to_mesh(gdim=2, hmax=15)
def mark_cells_radius_DG(domain, R_ref, center=(0.0, 0.0)):
    W = fem.functionspace(domain, ("DG", 0))
    cx, cy = center
    r = sqrt((x[0] - cx)**2 + (x[1] - cy)**2)
    indicator = ufl.conditional(ufl.le(r, R_ref), 1.0, 0.0)
    markers = fem.Function(W)
    ip = W.element.interpolation_points
    if Version(dolfinx.__version__) < Version("0.10.0"):
        ip = ip()
    markers.interpolate(fem.Expression(indicator, ip))
    # --- IMPORTANT: keep only owned cells (exclude ghosts) ---
    tdim = domain.topology.dim
    n_owned = domain.topology.index_map(tdim).size_local
    arr_owned = markers.x.array[:n_owned]
    cells = np.flatnonzero(arr_owned > 0.5).astype(np.int32)
    return cells
mesh_id = 0
out_folder = Path("code_3")
out_folder.mkdir(parents=True, exist_ok=True)
# γράψε αρχικό mesh
# geometric initial refinement
n_init_ref = 8
R_ref = 6
# καλό να υπάρχει connectivity που χρειάζεται το compute_incident_entities
domain.topology.create_connectivity(tdim, tdim-1)
for k in range(n_init_ref):
    cells_local = mark_cells_radius_DG(domain, R_ref, center=(0.0, 0.0))
    # 100% ασφάλεια: μόνο owned (όχι ghost) ΚΑΙ σωστό dtype
    cells_local = cells_local[cells_local < n_owned].astype(np.int32, copy=False)
    # Debug check (αν θες)
    # assert cells_local.size == 0 or (cells_local.min() >= 0 and cells_local.max() < n_owned)
    domain, (ct, ft) = geoModel.refineMarkedElements(tdim, cells_local)
import sys
comm = MPI.COMM_WORLD
rank = comm.rank
n_local = domain.topology.index_map(tdim).size_local
all_locals = comm.gather(n_local, root=0)
comm.Barrier()
if rank == 0:
    arr = np.array(all_locals)
    print("Local cells per rank:", arr.tolist())
    print("min/mean/max:", int(arr.min()), float(arr.mean()), int(arr.max()))
    print("max/mean:", float(arr.max()/arr.mean()))
    sys.stdout.flush()
###################### dokimazw na plotarw to mesh na dw pws fainetai pyhto
grid = pyvista.UnstructuredGrid(*vtk_mesh(domain))
grid.cell_data["ct"] = ct.values
plotter = pyvista.Plotter()
plotter.add_mesh(grid, show_edges=True, scalars="ct", show_scalar_bar=True)
plotter.view_xy()
if not pyvista.OFF_SCREEN:
    plotter.show()
from dolfinx import geometry
class TipTrackerRoot:
    def __init__(self, mesh, x_min, x_max, y0=0.0,
                 x0_guess=None,  # αρχική εικασία για tip
                 tol_x=1e-10, tol_f=1e-12, max_it=200,
                 scan_n=60, expand_factor=1.6,
                 out_path="tip_velocity.csv", comm=None):
        self.mesh = mesh
        self.comm = comm if comm is not None else MPI.COMM_WORLD
        self.rank = self.comm.rank
        self.x_min = float(x_min)
        self.x_max = float(x_max)
        self.y0 = float(y0)
        self.tol_x = float(tol_x)
        self.tol_f = float(tol_f)
        self.max_it = int(max_it)
        self.scan_n = int(scan_n)
        self.expand_factor = float(expand_factor)
        self.bb = geometry.bb_tree(self.mesh, self.mesh.topology.dim)
        self.x_tip_old = None
        self.x_guess = x0_guess
        self.f = None
        if self.rank == 0:
            self.f = open(out_path, "w", buffering=1)
            self.f.write("step,t,x_tip,v_tip\n")
    def _eval_phi_at(self, phi, x):
        Αξιολόγηση φ στο point (x, y0) σε MPI με ασφάλεια:
        - κάθε rank δοκιμάζει αν το point πέφτει σε local cell
        - όσοι βρίσκουν τιμή συνεισφέρουν, μετά κάνουμε average
        (σε partition boundaries μπορεί να βρεθεί από 2 ranks, αλλά η τιμή είναι ίδια για CG).
        pt = np.array([[float(x), self.y0, 0.0]], dtype=np.float64)
        candidates = geometry.compute_collisions_points(self.bb, pt)
        colliding  = geometry.compute_colliding_cells(self.mesh, candidates, pt)
        local_found = 0
        local_val = 0.0
        links = colliding.links(0)
        if len(links) > 0:
            cell = np.array([links[0]], dtype=np.int32)
            local_val = float(phi.eval(pt, cell).reshape(-1)[0])
            local_found = 1
        found = self.comm.allreduce(local_found, op=MPI.SUM)
        val_sum = self.comm.allreduce(local_val, op=MPI.SUM)
        if found == 0:
            return np.nan
        return val_sum / found
    def _find_bracket(self, phi, x_center):
        Βρίσκει [a,b] με sign change γύρω από x_center.
        1) προσπαθεί με expanding window
        2) αν αποτύχει, κάνει coarse scan σε όλο [x_min, x_max]
        # clamp center
        x_center = float(np.clip(x_center, self.x_min, self.x_max))
        # αρχικό μικρό παράθυρο
        width = max(1e-6, 0.01 * (self.x_max - self.x_min))
        for _ in range(40):
            a = max(self.x_min, x_center - width)
            b = min(self.x_max, x_center + width)
            fa = self._eval_phi_at(phi, a)
            fb = self._eval_phi_at(phi, b)
            if np.isfinite(fa) and np.isfinite(fb) and fa * fb < 0:
                return a, b, fa, fb
            width *= self.expand_factor
        # fallback: coarse scan across full interval
        xs = np.linspace(self.x_min, self.x_max, self.scan_n)
        fs = np.array([self._eval_phi_at(phi, x) for x in xs], dtype=np.float64)
        ok = np.isfinite(fs)
        xs, fs = xs[ok], fs[ok]
        if xs.size < 2:
            return None
        s = np.sign(fs)
        idx = np.where(s[:-1] * s[1:] < 0)[0]
        if idx.size == 0:
            return None
        j = idx[0]  # πρώτο crossing (πιο αριστερό)
        return float(xs[j]), float(xs[j+1]), float(fs[j]), float(fs[j+1])
    def _bisect(self, phi, a, b, fa, fb):
        Bisection μέχρι tol_x ή tol_f.
        if fa * fb > 0:
            return None
        for _ in range(self.max_it):
            m = 0.5 * (a + b)
            fm = self._eval_phi_at(phi, m)
            if not np.isfinite(fm):
                # αν πέσει σε “κενό” λόγω γεωμετρίας, μικρή μετατόπιση
                m = np.nextafter(m, b)
            if np.isfinite(fm) and abs(fm) < self.tol_f:
                return float(m)
            if abs(b - a) < self.tol_x:
                return float(0.5 * (a + b))
            # keep bracket
            if fa * fm < 0:
                b, fb = m, fm
                a, fa = m, fm
    def update(self, phi, step, t, dt):
        # initial guess
        if self.x_tip_old is None:
            x_center = self.x_guess if self.x_guess is not None else 0.5*(self.x_min+self.x_max)
            x_center = self.x_tip_old
        br = self._find_bracket(phi, x_center)
        if br is None:
            x_tip = np.nan
            a, b, fa, fb = br
            x_tip = self._bisect(phi, a, b, fa, fb)
        # velocity
        if self.x_tip_old is None or not np.isfinite(x_tip):
            v_tip = 0.0
            v_tip = (x_tip - self.x_tip_old) / dt
        self.x_tip_old = x_tip
        if self.rank == 0 and self.f is not None:
            self.f.write(f"{step},{t},{x_tip},{v_tip}\n")
        return x_tip, v_tip
    def close(self):
            self.f.close()
def tau(phi):
    gradphi=grad(phi)
    absgradphi = sqrt(inner( gradphi,  gradphi)+1e-12)
    abs4gradphi=absgradphi**4
    sum_grad_phi4= gradphi[0]**4 + gradphi[1]**4
    whole = sum_grad_phi4/abs4gradphi
    a=(1-3*e4)*(1+((4*e4)/(1-3*e4))*whole)
    return tau0*(a)**2
def W(phi):
    gradphi=grad(phi)
    return W0*a
def omega(phi):
    gradphi=grad(phi)
    V1=  gradphi[0]*(( gradphi[1]**2)*(( gradphi[0]**2)-(  gradphi[1]**2)))
    V2=  gradphi[1]*(( gradphi[0]**2)*(( gradphi[1]**2)-(  gradphi[0]**2)))
    V=as_vector([V1,V2])
    return ((16*e4*W0)/abs4gradphi)*V
def f(phi,u):
    return (phi-l*u*(1-phi**2))*(1-phi**2)
def build_system(domain, dt, D, petsc_options,
                 old_sol=None, old_sol0=None,
                 init_phi=None, init_u=None,
                 petsc_prefix="Crystal_growth"):
    Χτίζει: ME, sol, sol0, problem  πάνω στο current domain (mesh).
    - An old_sol/old_sol0 δοθούν: μεταφέρει λύση nonmatching (για mesh change).
    - Αλλιώς, an init_phi/init_u δοθούν: βάζει τα initial initial conditions .
    # 1) Spaces + functions
    P1 = element("Lagrange", domain.basix_cell(), 1, dtype=default_real_type)
    ME = fem.functionspace(domain, mixed_element([P1, P1]))
    sol  = fem.Function(ME)
    sol0 = fem.Function(ME)
    # 2) είτε μεταφορά λύσης (mesh changed) είτε initial conditions
    if old_sol is not None and old_sol0 is not None:
        # Old components
        old_phi  = old_sol.sub(0)
        old_u    = old_sol.sub(1)
        old_phi0 = old_sol0.sub(0)
        old_u0   = old_sol0.sub(1)
        # Collapsed spaces + maps
        Vphi_new, map_phi = ME.sub(0).collapse()
        Vu_new,   map_u   = ME.sub(1).collapse()
        phi_new  = fem.Function(Vphi_new)
        u_new    = fem.Function(Vu_new)
        phi0_new = fem.Function(Vphi_new)
        u0_new   = fem.Function(Vu_new)
        # Nonmatching interpolation data
        num_local_cells = domain.topology.index_map(tdim).size_local
        new_cells = np.arange(num_local_cells, dtype=np.int32)
        idata_phi = fem.create_interpolation_data(Vphi_new, old_phi.function_space, new_cells)
        idata_u   = fem.create_interpolation_data(Vu_new,   old_u.function_space,   new_cells)
        # Interpolate old -> new
        phi_new.interpolate_nonmatching(old_phi,   new_cells, idata_phi)
        phi0_new.interpolate_nonmatching(old_phi0, new_cells, idata_phi)
        u_new.interpolate_nonmatching(old_u,   new_cells, idata_u)
        u0_new.interpolate_nonmatching(old_u0, new_cells, idata_u)
        # Write back into mixed sol/sol0
        sol.sub(0).x.array[map_phi]  = phi_new.x.array
        sol.sub(1).x.array[map_u]    = u_new.x.array
        sol0.sub(0).x.array[map_phi] = phi0_new.x.array
        sol0.sub(1).x.array[map_u]   = u0_new.x.array
        sol.x.scatter_forward()
        sol0.x.scatter_forward()
        # initial conditions (στην αρχή)
        if init_phi is not None:
            sol.sub(0).interpolate(init_phi)
        if init_u is not None:
            sol.sub(1).interpolate(init_u)
        sol0.x.array[:] = sol.x.array
    # 3) Weak form (πάντα ξαναχτίζεται στο νέο ME/sol/sol0)
    q, v = ufl.TestFunctions(ME)
    phi, u   = ufl.split(sol)
    phi0, u0 = ufl.split(sol0)
    F1 = (
        ufl.inner(u, v) * ufl.dx
        - ufl.inner(u0, v) * ufl.dx
        + dt * D * ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
        - 0.5 * ufl.inner(phi, v) * ufl.dx
        + 0.5 * ufl.inner(phi0, v) * ufl.dx
    F2 = (
        ufl.inner(tau(phi0) * phi, q) * ufl.dx
        - ufl.inner(tau(phi0) * phi0, q) * ufl.dx
        + dt * ufl.inner(W(phi0)**2 * ufl.grad(phi), ufl.grad(q)) * ufl.dx
        - dt * ufl.inner(f(phi0, u0), q) * ufl.dx
        + dt * ufl.inner(W(phi0) * omega(phi0), ufl.grad(q)) * ufl.dx
    F = F1 + F2
    # 4) Problem
    problem = NonlinearProblem(F, sol,
                               petsc_options_prefix=petsc_prefix,
                               petsc_options=petsc_options)
    return ME, sol, sol0, problem
def mark_cells_multiband_buffered(phi: fem.Function,
                                  core=0.15, h0=0.18,
                                  out1=0.40, in1=0.20, h1=0.30,
                                  out2=0.75, in2=0.35, h2=0.50,
                                  out3=0.95, in3=0.50, h3=0.80):
    mesh = phi.function_space.mesh
    W = fem.functionspace(mesh, ("DG", 0))
        ip = ip()
    phi_dg = fem.Function(W)
    phi_dg.interpolate(fem.Expression(phi, ip))
    phi_dg.x.scatter_forward()
    hfun = fem.Function(W)
    hfun.interpolate(fem.Expression(ufl.CellDiameter(mesh), ip))
    hfun.x.scatter_forward()
    tdim = mesh.topology.dim
    n_owned = mesh.topology.index_map(tdim).size_local
    p = phi_dg.x.array[:n_owned]
    h = hfun.x.array[:n_owned]
    marked = (
        ((np.abs(p) < core) & (h > h0)) |
        ((p > -out1) & (p < in1) & (h > h1)) |
        ((p > -out2) & (p < in2) & (h > h2)) |
        ((p > -out3) & (p < in3) & (h > h3))
    return np.flatnonzero(marked).astype(np.int32)
def mark_cells_multiband_outside(phi: fem.Function,
                                 eps0=0.10, h0=0.12,   # very fine around phi=0 on both sides
                                 neg1=0.30, h1=0.22,   # first outer band:   -neg1 < phi < -eps0
                                 neg2=0.60, h2=0.40,   # second outer band:  -neg2 < phi < -neg1
                                 neg3=0.90, h3=0.70):  # third outer band:   -neg3 < phi < -neg2
        ip = ip()
    # cellwise phi
    # cell diameter
    marked = (
        ((p > -eps0) & (p <  eps0) & (h > h0)) |      # symmetric thin band around phi=0
        ((p <= -eps0) & (p > -neg1) & (h > h1)) |     # outside only
        ((p <= -neg1) & (p > -neg2) & (h > h2)) |     # farther outside
        ((p <= -neg2) & (p > -neg3) & (h > h3))       # even farther outside
    cells = np.flatnonzero(marked).astype(np.int32)
    return cells
def expand_marked_cells(mesh, cells, n_layers=1):
    fdim = tdim - 1
    mesh.topology.create_connectivity(tdim, fdim)
    c_to_f = mesh.topology.connectivity(tdim, fdim)
    f_to_c = mesh.topology.connectivity(fdim, tdim)
    marked = set()
    for c in np.asarray(cells, dtype=np.int64).ravel():
        if 0 <= c < n_owned:
            marked.add(int(c))
    for _ in range(n_layers):
        new_marked = set(marked)
        for c in marked:
            for f in c_to_f.links(c):
                for cn in f_to_c.links(f):
                    if 0 <= int(cn) < n_owned:
                        new_marked.add(int(cn))
        marked = new_marked
    return np.array(sorted(marked), dtype=np.int32)
#ΔΗΛΩΣΗ ΤΟΥ ΤΙ OPTIONS ΘΑ ΕΧΕΙ Ο SOLVER #######
use_superlu = PETSc.IntType == np.int64
sys = PETSc.Sys()
if sys.hasExternalPackage("mumps") and not use_superlu:
    linear_solver = "mumps"
elif sys.hasExternalPackage("superlu_dist"):
    linear_solver = "superlu_dist"
    linear_solver = "petsc"
petsc_options = {
    "snes_type": "newtonls",
    "snes_linesearch_type": "basic",
    "snes_atol": 1e-6,
    "snes_rtol": 1e-6,
    "snes_monitor": None,
    "ksp_error_if_not_converged": True,
    "ksp_type": "gmres",
    "ksp_rtol": 1e-8,
    "ksp_monitor": None,
    "pc_type": "hypre",
    "pc_hypre_type": "boomeramg",
    "pc_hypre_boomeramg_max_iter": 1,
    "pc_hypre_boomeramg_cycle_type": "v",
###################################################ARXIKI SINTHIKI GIA TO PHI PARAGONTAS PHI ######
def Initial_condition_PHI(x):
    r1 = np.sqrt(x[0]**2 + x[1]**2)
    return -np.tanh((r1 - r0) / np.sqrt(2))
##############ARXIKI ADIASTATIS SIGKENTRWSIS%%%%%%%%%%%%%%%%%
def Initial_condition_U(x):
    r2 = np.sqrt(x[0]**2 + x[1]**2)
    u_init = np.where(r2<=r0,
                      0,
                      -Delta * (1 - np.exp(-(r2 -r0)/1))
    return u_init
######################################################ARXIKI DILWSI TOY PROBLIMATOS
ME, sol, sol0, problem = build_system(
    init_phi=Initial_condition_PHI,
    init_u=Initial_condition_U
file = XDMFFile(MPI.COMM_WORLD,out_folder / f"output_mesh{mesh_id}.xdmf", "w")
file.write_mesh(domain)
log_path = out_folder / "residuals.txt"
if rank == 0:
    f_log = open(log_path, "w", buffering=1)  # line-buffered
    f_log.write("step,t,snes_reason,snes_its,snes_norm,ksp_its,ksp_rnorm\n")
    f_log = None
step = 0
# --- Initial refinement passes (before time loop) ---
##############################arxiko refinement###############
gdim = domain.geometry.dim
# ∇phi (vector)
def rebuild_postprocess_objects(domain, tip_tracker=None):
    Vgrad = fem.functionspace(domain, ("CG", 1, (gdim,)))
    grad_u = fem.Function(Vgrad, name="grad_u")
    grad_phi = fem.Function(Vgrad, name="grad_phi")
    if tip_tracker is not None:
        tip_tracker.mesh = domain
        tip_tracker.bb = geometry.bb_tree(domain, domain.topology.dim)
    return Vgrad, grad_u, grad_phi
def keep_owned_cells(mesh, cells):
    imap = mesh.topology.index_map(tdim)
    n_owned = imap.size_local
    cells = np.asarray(cells, dtype=np.int64).ravel()
    cells = cells[(cells >= 0) & (cells < n_owned)]
    cells = np.unique(cells)
    return cells.astype(np.int32, copy=False)
tip_tracker = TipTrackerRoot(
    mesh=domain,
    x_min=-400.0,
    x_max=0.0,
    y0=0.0,
    x0_guess=-r0,                    # προαιρετικό: αρχική εικασία
    tol_x=1e-10, tol_f=1e-12,        # πολύ αυστηρά
    out_path=str(out_folder / "tip_velocity.csv"),
    comm=MPI.COMM_WORLD
Vgrad, grad_u, grad_phi = rebuild_postprocess_objects(domain, tip_tracker)
while t < T:
    step += 1
    problem.solve()
    # diagnostics
    converged_reason = problem.solver.getConvergedReason()
    num_iterations = problem.solver.getIterationNumber()
    snes = problem.solver
    ksp = snes.getKSP()
    snes_reason = snes.getConvergedReason()
    snes_its    = snes.getIterationNumber()
    # SNES residual norm
    snes_norm = snes.getFunctionNorm()
    # KSP stats (τελευταίο linear solve)
    ksp_its   = ksp.getIterationNumber()
    ksp_rnorm = ksp.getResidualNorm()
    if step % 99 == 0:
        old_sol_fine  = sol.copy()
        old_sol0_fine = sol0.copy()
        domain, (ct, ft), region_map = geoModel.model_to_mesh(gdim=2, hmax=10.0)
        max_rebuild_ref = 10
        for k in range(max_rebuild_ref):
            ME_tmp, sol_tmp, sol0_tmp, _ = build_system(
                old_sol=old_sol_fine, old_sol0=old_sol0_fine
            cells = mark_cells_multiband_buffered(
                sol_tmp.sub(0),
                core=0.15, h0=0.18,
            cells = expand_marked_cells(domain, cells, n_layers=1)
            cells = keep_owned_cells(domain, cells)
            local_marked = cells.size
            global_marked = comm.allreduce(local_marked, op=MPI.SUM)
            if rank == 0:
                print(f"[rebuild pass {k+1}] global_marked={global_marked}", flush=True)
            if global_marked < 10:
                break
            n_all   = domain.topology.index_map(tdim).size_local + domain.topology.index_map(tdim).num_ghosts
            if rank == 0:
                print(f"About to refine: cells.size={cells.size}, dtype={cells.dtype}", flush=True)
                if cells.size > 0:
                    print(f"cells.min()={cells.min()}, cells.max()={cells.max()}", flush=True)
                print(f"n_owned={n_owned}, n_all(local+ghost)={n_all}", flush=True)
            assert cells.dtype == np.int32
            assert np.all(cells >= 0)
            assert np.all(cells < n_owned), f"Found non-owned cells: max={cells.max()} n_owned={n_owned}"
            assert len(np.unique(cells)) == len(cells), "Duplicate cell ids in refine list"
            domain, (ct, ft) = geoModel.refineMarkedElements(domain.topology.dim, cells)
        mesh_id += 1
        file.close()
        file = XDMFFile(MPI.COMM_WORLD, out_folder / f"output_mesh{mesh_id}.xdmf", "w")
    if step % 50 == 0:
                sol.sub(0),
                core=0.15, h0=0.2,
                out2=0.75, in2=0.35, h2=0.60,
                out3=0.95, in3=0.50, h3=1.00)
        if rank == 0:
            print(f"[step {step}] global_marked={global_marked}", flush=True)
        if global_marked >= 20:
            old_sol = sol.copy()
            old_sol0 = sol0.copy()
            print(f"Refining {global_marked} cells at step {step}", flush=True)
            domain.topology.create_connectivity(domain.topology.dim, domain.topology.dim - 1)
            domain.topology.create_connectivity(domain.topology.dim - 1, domain.topology.dim)
            mesh_id += 1
            file.close()
                old_sol=old_sol, old_sol0=old_sol0
            phi = sol.sub(0)
            u = sol.sub(1)
    # Γράψιμο ΜΕΣΑ στο loop
    if rank == 0:
        f_log.write(f"{step},{t},{snes_reason},{snes_its},{snes_norm},{ksp_its},{ksp_rnorm}\n")
    # 1) διάνυσμα gradient
    phi = sol.sub(0)
    u   = sol.sub(1)
    tip_tracker.update(phi, step=step, t=t, dt=dt)
    ip_grad = Vgrad.element.interpolation_points
        ip_grad = ip_grad()
    grad_phi.interpolate(fem.Expression(ufl.grad(phi), ip_grad))
    grad_u.interpolate(fem.Expression(ufl.grad(u), ip_grad))
    grad_phi.x.scatter_forward()
    grad_u.x.scatter_forward()
    # Write output
    if step % 1==0:
        phi_out = sol.sub(0)
        u_out   = sol.sub(1)
        file.write_function(phi_out, t)
        file.write_function(u_out, t)
        file.write_function(grad_u,t)
        file.write_function(grad_phi,t)
        file.flush()
tip_tracker.close()
file.close()
if rank == 0 and f_log is not None:
    f_log.close()
if rank == 0:
    print(f"Simulation completed: {step} steps, final time t={t}")
end_time = MPI.Wtime()
print(f"Elapsed time: {end_time-start_time} s.",flush=True) #remove later
if rank == 0:
dolfinx.common.list_timings(MPI.COMM_WORLD)
Hi, I am running a phase-field simulation where I do adaptive mesh refinement and coarsening during the time loop by rebuilding a new mesh and then interpolating the old solution onto the new mesh .
More specifically, I periodically create a new mesh, transfer the solution with interpolation / nonmatching interpolation, and continue the solve on the updated mesh. However, after around 2300+ time steps , the code consistently crashes with a PETSc segmentation fault during the mesh adaptation stage.
The error I keep getting is:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
The nonlinear solve itself converges normally before that, and the crash appears during the remeshing / refinement part, not during the Newton solve. This works for many iterations, but after roughly 2300 time steps the code consistently crashes with a PETSc SEGV .
Has anyone seen this kind of issue when repeatedly doing adaptive remeshing with interpolation onto a new mesh?
whate ever i do explodes at 2376 time step
step Residual norms for Crystal_growth solve.
    0 KSP Residual norm 2.191661216976e-01
    1 KSP Residual norm 3.692687231071e-03
    2 KSP Residual norm 6.468373697158e-05
    3 KSP Residual norm 3.287897826985e-06
    4 KSP Residual norm 1.683661279456e-07
    5 KSP Residual norm 8.914356604226e-09
    6 KSP Residual norm 4.779632244027e-10
  1 SNES Function norm 5.329359457957e-10
[rebuild pass 1] global_marked=40
About to refine: cells.size=40, dtype=int32
cells.min()=48, cells.max()=286
n_owned=3727
Sadly I don’t have time to go through your code in detail, but here are some initial suggestions until better advice comes along:
  • If you can eliminate as much code as possible and still reproduce the issue, that would be extremely helpful for those of us who volunteer our time here.
  • Check for “over-creation” of PETSc objects. By this I mean, try to reuse PETSc (and DOLFINx) objects wherever you can. I have a suspicion you’re encountering invalid memory for this reason.
  • If you can’t reuse PETSc objects, make sure you delete them carefully when you don’t need them anymore. E.g., dolfinx/python/dolfinx/fem/petsc.py at f8fed2dff47dee90e9258cc3393379c707f97616 · FEniCS/dolfinx · GitHub
Inside the time loop, I use a mesh coarsening/adaptation procedure. I first regenerate the initial coarse mesh, then I run a refinement loop where I repeatedly interpolate the solution onto the current mesh and refine it. After the last refinement step, I rebuild the problem on the final adapted mesh and interpolate the stored solution onto that final mesh. this is the coarsening
if step % 99 == 0:
                sol_tmp.sub(0),
                core=0.15, h0=0.18,
            if rank == 0:
                break
            if rank == 0:
                if cells.size > 0:
        mesh_id += 1
        file.close()
and this is the function that i call inside the for loop to interopolate
        # Old components
    F1 = (
    F2 = (
    F = F1 + F2
    # 4) Problem
after 2376 steps which mean 2376/99=24 blow up .with this error .
As stated by @nate, you need to reduce the amount of code to reproduce the problem for us the be able to help you. The code is over 1000 lines long, which makes it really hard for us to give any sensible feedback without spending hours figuring out all the aspects of your code.
A small thing to test, is whether your RAM is slowly increasing over time. That would hint at something along the lines of Nate’s comment:
Thank you for your suggestions.
I was able to resolve the issue. The problem turned out to be related to object cleanup: I was rebuilding the nonlinear problem repeatedly during mesh adaptation, and the old problem objects were not being released early enough. After explicitly deleting the old problem object before rebuilding it, the code runs normally without the blow-up.
So the issue appears to have been caused by memory accumulation due to repeated creation of PETSc/DOLFINx objects during the rebuild cycle.
Thank you again for your help.
