Hey all - I am modeling simple 2D Stokes flow around a circular barrier:
I am trying to calculate the maximum tensile strength (first principal stress) across the mesh. I solve for u, p using the residual method as found here and I calculate the maximum tensile stress like so:
def sigma(u,p): # Cauchy stress tensor
return 2*eta*epsilon(u) - p*I
TS = TensorFunctionSpace(mesh, "CG", 2)
cauchy = project(sigma(u,p), TS)
sigma_x = cauchy[0,0]
sigma_y = cauchy[1, 1]
tau_xy = cauchy[0, 1]
def sigma1(sigma_x, sigma_y, tau_xy): # magnitude of first principal stress
return((sigma_x+sigma_y)/2 + sqrt(((sigma_x-sigma_y)/2)**2 + tau_xy))
ps1 = sigma1(sigma_x, sigma_y, tau_xy)
plot(ps1, title="Maximum tensile stress")
I get the following error:
File "/anaconda3/envs/fenicsproject/lib/python3.8/site-packages/dolfin/common/plotting.py", line 438, in plot
return _plot_matplotlib(object, mesh, kwargs)
File "/anaconda3/envs/fenicsproject/lib/python3.8/site-packages/dolfin/common/plotting.py", line 304, in _plot_matplotlib
return mplot_function(ax, obj, **kwargs)
File "/anaconda3/envs/fenicsproject/lib/python3.8/site-packages/dolfin/common/plotting.py", line 152, in mplot_function
return ax.tricontourf(mesh2triang(mesh), C, levels, **kwargs)
File "/anaconda3/envs/fenicsproject/lib/python3.8/site-packages/matplotlib/tri/tricontour.py", line 275, in tricontourf
return TriContourSet(ax, *args, **kwargs)
File "/anaconda3/envs/fenicsproject/lib/python3.8/site-packages/matplotlib/tri/tricontour.py", line 35, in __init__
ContourSet.__init__(self, ax, *args, **kwargs)
File "/anaconda3/envs/fenicsproject/lib/python3.8/site-packages/matplotlib/contour.py", line 822, in __init__
kwargs = self._process_args(*args, **kwargs)
File "/anaconda3/envs/fenicsproject/lib/python3.8/site-packages/matplotlib/tri/tricontour.py", line 47, in _process_args
tri, z = self._contour_args(args, kwargs)
File "/anaconda3/envs/fenicsproject/lib/python3.8/site-packages/matplotlib/tri/tricontour.py", line 94, in _contour_args
raise ValueError('z array must not contain non-finite values '
ValueError: z array must not contain non-finite values within the triangulation
I believe this is because of the irrational values generated by the sqrt function required to calculate sigma1. I know that UFL does not provide any floor, ceil, or round operators. Is there any way to round irrational values to a finite values so that they can be plotted?
Thanks!
