Hello everyone,
I am having a problem with plotting, as in I am not getting a heat map of the solution of the stokes problem, but instead some sort of vector field. As a background I am solving stokes problem on a irregular mesh. When I use dl.plot , I obtain the vector field, I found that if I used instead vtkplotter.dolfin, I get what, however after I plot it and see the plot I cannot do any more plots, I get the plot staying until I force quit it. I tried reinstalling the Fenics and vtkplotter.dolfin multiple times and the problem is still there. I was hoping someone can help me item use the dl.plot (dolfin) or the issue with the vtkplotter plot resolved
import dolfin as dl
from vtkplotter.dolfin import plot
u0 = SA.solve_fwd_Stokes() %u0 here is a dolfin.cpp.la.PETScVector
fig = plt.figure(1)
p1 = dl.plot(u1f.sub(0))
plt.colorbar(p1)
u0f = convert_to_function(u0) %dolfin.cpp.la.PETScVector to function
plot(u0f)
Currently I am running Fenics 2019.1 and the version on the 2020.3.1 . I am running macOS Big Sur (11.6). Thank you so much for the time and consideration! I am attaching the plots from the dl.plot and the one from vtkplotter
