Hi there
i have a problem with the velocity . i dont undersatand why the velocity is 0.0
the full code is:
from mshr import*
p1 = Point(np.array([1.0, 0.0]))
p2 = Point(np.array([2.0, -0.2]))
p3 = Point(np.array([6.0, 0.2]))
c0 = Circle(p1,1)
R = Rectangle (p2,p3)
vessie = R+c0
mesh = generate_mesh (vessie , 64)
plt.figure(figsize=(20, 8))
plot(mesh, title="Mesh")
mark = {"generic": 0,
"wall1": 1,
"wall2": 2,
"right": 3 }
#Fonction pour le maillage
subdomains = MeshFunction("size_t", mesh, 1)
subdomains.set_all(mark["generic"])
#Partie droite des conditions aux bords
class Right(SubDomain):
return on_boundary and near(x[0], 6.0)
#Parois
class Wall1(SubDomain):
return on_boundary and near (x[1], -0.2) or near (x[1],0.2 )
class Wall2(SubDomain):
return on_boundary and near (x[1]*x[1]+x[0]*x[0] ,1)
#application parois
wall1 = Wall1()
wall2 = Wall2()
wall1.mark(subdomains, mark["wall1"])
wall2.mark(subdomains, mark["wall2"])
#application a droite
right = Right()
right.mark(subdomains, mark["right"])
#définitioon de l'espace des fonctions
P2 = VectorElement('P', triangle, 2)
P1 = FiniteElement('P', triangle, 1)
TH = P2 * P1
W = FunctionSpace(mesh, TH)
# Definition du problème variationel
(u, p) = TrialFunctions(W)
(v, q) = TestFunctions(W)
#integral de volume et de surface
dx = Measure("dx", domain=mesh, subdomain_data=subdomains)
ds = Measure("ds", domain=mesh, subdomain_data=subdomains)
# Surface normale
# Pression des deux cotés
p_wall2 = 2000.00
p_right = 0.0
# pression des deux coté codées pour DOLFIN:
pressure_wall2 = Constant(p_wall2)
pressure_right = Constant(p_right)
#force
force = Constant((0.0, 0.0))
#Utilisation de DOLFIN
a = inner(grad(u), grad(v))*dx - p*div(v)*dx + q*div(u)*dx
L = inner(force, v) * dx \
- p_right * inner(n, v) * ds(mark["right"]) - p_wall2 * inner(n, v) * ds(mark["wall2"])
#conditions de vitesse aux bords de la parois
noslip = Constant((0.0, 0.0))
bcu_wall = DirichletBC(W.sub(0), noslip, subdomains, mark["wall1"])
#Résolution
w = Function(W)
#solve(a == L, w, bcu)
solve(a == L, w, bcu_wall)
# Split using deep copy
(u, p) = w.split(True)
u
u.vector().get_local()
# Plot solution
plot(u, title="Velocity")
plot§
