Bonjour
Jai essaye de faire le couplage mais j’avais un problème quand Jai lance le domaine fluide ( ./run.sh)
Jai utiliser 8 processeur dans mes calcules mais les résultats des erreurs !!!
Erreur:
attempt to run parallel on 1 processor
Without supplying your script, the dependencies, how you installed them and what errors you are getting, there is no way one can help you.
Please have a look at Read before posting: How do I get my question answered? and open a new message that adheres with those guidelines. In summary, the message you wrote here is nowhere near informative enough for anyone to have enough information to help you (for instance, you mention a script run.sh, but we have no idea what’s inside the script).
It would also be helpful if you wrote your message in English from now on, otherwise only the subset of the community which speaks French will be able to read your message and help.
