Rate of convergence without exact solution
Hi everyone,
I’m currently working on a time-dependent nonlinear PDE in FEniCS and performing a temporal convergence study. I’m using a fixed spatial mesh and comparing my numerical solution against a reference solution computed on a much finer time grid.
However, I’m having trouble obtaining a clean optimal convergence rate. The expected temporal order should be around second order, but the observed rate of convergence (ROC) fluctuates quite a bit, especially for coarser time steps.
Here is my output:
dt           L2-error      L2-order    H1-error     H1-order
2.000000e-01   1.228031e-05   0.0000   1.091201e-04   0.0000
1.000000e-01   1.441561e-06   3.0906   2.038898e-05   2.4201
5.000000e-02   2.418780e-07   2.5753   2.151336e-06   3.2445
2.500000e-02   5.629508e-08   2.1032   5.005621e-07   2.1036
1.250000e-02   1.338052e-08   2.0729   1.189736e-07   2.0729
The rates eventually settle close to 2, but for larger time steps they fluctuate significantly and even exceed the expected order (e.g., 3.09 and 3.24).
I’m wondering:
  1. Is this kind of fluctuation normal in temporal convergence studies?
  2. Could the issue come from the reference solution not being sufficiently fine?
  3. Is there a possibility that spatial errors are still influencing the temporal error even though I fixed a relatively fine mesh?
I’m attaching my FEniCS code as well for context.
Any suggestions or insights would be greatly appreciated. Thanks in advance!
import time
pi = np.pi
T    = 10.0
nref = 5
eL2 = []
eH1 = []
hh  = []
rL2 = [0.0]
rH1 = [0.0]
solutions = []
spaces = []
meshes = []
total_start = time.time()
def main(N, M, k1):
    level_start = time.time()
    h  = 1.0 / N
    dt = 1.0/M
    num_steps = int(round(T / dt))
    # ── Mesh & space ──
    mesh = UnitSquareMesh(N, N)
    V    = FunctionSpace(mesh, "CG", k1)
    u_0 = Expression(
        'sin(2*pi*x[0])*sin(2*pi*x[1])',
        degree=2, pi=pi
    f = Expression(
    '-(1-k/2.0)*sin(2*pi*x[0])*sin(2*pi*x[1])',
    degree=2,
    pi=pi,
    k=dt
    # ── Dirichlet BC ──
    def boundary(x, on_boundary):
        return on_boundary
    bc = DirichletBC(V, Constant(0.0), boundary)
    # ── Interpolate u^0 ──
    u_k = interpolate(u_0, V)
    u0  = Function(V)
    du0 = TrialFunction(V)
    v0  = TestFunction(V)
    u0.assign(u_k)                     # Newton initial guess
    # ── First-step residual F0(u0; v0) ───
    F0 = (
          ((u0 - u_k) / dt) * v0 * dx
        + (dt / 4.0) * dot(grad(u0 + u_k), grad(v0)) * dx
        + (dt / 8.0) * (u0**3 + u0**2*u_k + u0*u_k**2 + u_k**3) * v0 * dx
        - (dt/2.0) * dot(grad(u0), grad(v0)) * dx -f * v0 * dx
    J0 = derivative(F0, u0, du0)
    solve(
        F0 == 0, u0, bc, J=J0,
          solver_parameters={
                    "newton_solver":{
                    "relative_tolerance":1e-6,
                    "absolute_tolerance":1e-6,
                    "maximum_iterations":50,
                    "linear_solver":"lu"
    # ── Initialise 3-level state ───
    uoldd = Function(V)
    uold  = Function(V)
    u     = Function(V)
    uoldd.assign(u_k)    # u^{n-1} = u^0
    uold.assign(u0)      # u^n     = u^1
    phi = TestFunction(V)
    du  = TrialFunction(V)
    t = dt
    for _ in range(1, num_steps):
        u.assign(uold)                 # Newton initial guess
        F = (
              ((u - 2*uold + uoldd) / dt**2) * phi * dx
            + 0.5 * dot(grad(u),     grad(phi)) * dx
            + 0.5 * dot(grad(uoldd), grad(phi)) * dx
            +  dot(grad(u),     grad(phi)) * 1./(2*dt) * dx
            -  dot(grad(uoldd), grad(phi)) * 1./(2*dt) * dx
            + u * phi * 1./(2*dt) * dx
            - uoldd * phi * 1./(2*dt) * dx
            + (1.0/4.0) * u**3          * phi * dx
            + (1.0/4.0) * u**2 * uoldd  * phi * dx
            + (1.0/4.0) * uoldd**2 * u  * phi * dx
            + (1.0/4.0) * uoldd**3      * phi * dx
        J = derivative(F, u, du)
        solve(
            F == 0, u, bc, J=J,
            solver_parameters={
                    "newton_solver":{
        uoldd.assign(uold)
        uold.assign(u)
    return u, V, mesh
if __name__ == "__main__":
    degree = 2
    Mlist = [5,10,20,40,80]
    dtvals = []
    eU     = []
    eUH1   = []
    rU     = [0.0]
    rUH1   = [0.0]
    Nref = 100
    Mref = 512
    print("Computing reference solution")
    uh_ref, V_ref, mesh_ref = main(
        Nref,
        Mref,
        degree
    Nfixed = 100
    for M in Mlist:
        print("Solving dt = ",1./M)
        uh,V,mesh = main(
            Nfixed,
            M,
            degree
        dt = 1./M
        dtvals.append(dt)
        # Common space
        W = FunctionSpace(
                mesh_ref,
                "CG",
                degree
        uhW = interpolate(
                    uh,
                    W
        urefW = interpolate(
                        uh_ref,
                        W
        diff = Function(W)
        diff.vector()[:] = \
            uhW.vector().get_local() \
            - urefW.vector().get_local()
        # L2 error
        L2_error = sqrt(
            assemble(
                diff*diff*dx
        # H1 error
        H1_error = sqrt(
            assemble(
                inner(
                    grad(diff),
                    grad(diff)
                )*dx
        eU.append(L2_error)
        eUH1.append(H1_error)
        k = len(eU)-1
        if k>0:
            rU.append(
                np.log(
                    eU[k-1]/eU[k]
                np.log(
                    dtvals[k-1]/dtvals[k]
            rUH1.append(
                np.log(
                    eUH1[k-1]/eUH1[k]
                np.log(
print("\n-----------------------------------------------------------")
print("dt           L2-error      L2-order    H1-error     H1-order")
print("-----------------------------------------------------------")
for i in range(len(eU)):
    print(
        "{:.6e}   {:.6e}   {:.4f}   {:.6e}   {:.4f}".format(
            dtvals[i],
            eU[i],
            rU[i],
            eUH1[i],
            rUH1[i]
