Hello everyone,
I am new to the FEniCS. I am trying to compute a field (f_a_2) that is based on the line integral of displacement in a particular section of the mesh. The field (f_a_2) also depends on its value from previous iteration. To save the field, I project the field on functionspace and use assign command to use in next iteration. I noticed that during projection there are some negative values, which I supposed that are not possible (due to the use conditional command). Please, help me to understand the reason of these negative values. I attached the minimal code.
Thank you. ![]()
from ufl import nabla_div
from ufl import replace
import sys, os, shutil, math
from numpy.linalg import eig
from numpy import array
import time
from ufl import eq
from ufl import le
from ufl import ge, ne
#Compiler parameter
"eliminate_zeros": True, \
"precompute_ip_const": True}
# Define Data
mu = 80770.
lmbda = 121150.
gamma_val = 0.002194
beta_val = 23.649
del_f = 0.01
del_c = 0.0036
# Mesh Data
mesh = Mesh('mesh_2.xml')
ndim = mesh.topology().dim()
remain = CompiledSubDomain("x[1] >= 1.0 - tol",tol = 1E-14)
boundaries = MeshFunction("size_t", mesh,mesh.topology().dim()-1)
boundaries.set_all(0)
remain.mark(boundaries, 1)
ds = Measure("ds",subdomain_data=boundaries)
V_u = VectorFunctionSpace(mesh, 'CG', 1)
V_alpha = FunctionSpace(mesh, 'CG', 1)
u, du, v = Function(V_u), TrialFunction(V_u), TestFunction(V_u)
u_0 = Function(V_u)
jump_0 = Function(V_alpha)
f_a = Function(V_alpha)
f_a_2 = Function(V_alpha)
f_a_0 = Function(V_alpha)
zero_1 = Constant(0.0)
f_a_0 = project(zero_1,V_alpha)
u.rename('displacement','displacement')
f_a_T1 = Constant(2.2e-70)
f_a = project(f_a_T1, V_alpha)
fdf_p = Function(V_alpha)
tol = 1E-10
tol_v = 1e-18
def boundary_D_l(x, on_boundary):
return x[1] <= 0.0 + tol
def boundary_D_o(x, on_boundary):
return x[0] <= 0.0 + tol and x[1] <= 0.0 + tol
def boundary_D_t(x, on_boundary):
return x[1] >= 1.0 - tol
bcl = DirichletBC(V_u.sub(1), Constant(0.0), boundary_D_l, method='pointwise')
bco = DirichletBC(V_u, Constant((0.0 ,0.0)), boundary_D_o, method='pointwise')
# Calculation of positive part of strain
def eps(u):
return sym(grad(u))
def sigma(u):
return 2.0*mu*(eps(u)) + lmbda*tr(eps(u))*Identity(ndim)
def line_integral(field, a,b,n):
assert n > 0
A = np.array([a, b-0.006])
B = np.array([a, b+0.006])
mesh_points = [A + t*(B-A) for t in np.linspace(0, 1, n+1)]
tdim, gdim = 1, len(A)
mesh_l = Mesh()
editor = MeshEditor()
editor.open(mesh_l, 'interval', tdim, gdim)
editor.init_vertices(n+1)
editor.init_cells(n)
for vi, v in enumerate(mesh_points):
editor.add_vertex(vi, v)
for ci in range(n): editor.add_cell(ci, np.array([ci, ci+1], dtype='uintp'))
editor.close()
V_l = FunctionSpace(mesh_l, 'Lagrange',1)
v = interpolate(field, V_l)
return assemble(v*dx)
energy = 0.5 * inner(sigma(u), eps(u)) * dx
E_u = derivative(energy,u,v)
Jd = derivative(E_u, u, du)
num_steps = 25
num_of_large_load_step = 25
total_disp = 0.01
u_R = Expression(('disp_A + disp_app*(n+1-B)'),disp_A = 0.0, disp_app = total_disp/(num_of_large_load_step), n=0., B=0., degree=0)
bct = DirichletBC(V_u.sub(1), u_R, boundary_D_t, method='pointwise')
bc_disp = [bcl, bco, bct]
problem_u = NonlinearVariationalProblem(E_u, u, bc_disp, Jd)
solver_u = NonlinearVariationalSolver(problem_u)
prm = solver_u.parameters
prm["newton_solver"]["relative_tolerance"] = 5E-3
prm["newton_solver"]["absolute_tolerance"] = 8E-3
prm["newton_solver"]["convergence_criterion"] = "residual"
prm["newton_solver"]["error_on_nonconvergence"] = True
prm["newton_solver"]["linear_solver"] = 'mumps'
prm["newton_solver"]["lu_solver"]["symmetric"] = False
prm["newton_solver"]["maximum_iterations"] = 5000
prm["newton_solver"]["relaxation_parameter"] = 1.0
prm["newton_solver"]["krylov_solver"]["nonzero_initial_guess"] = True
class MyFunctionExpression(UserExpression):
def __init__(self, n,u_sol, **kwargs):
super().__init__(**kwargs)
self.n = n
self.u_sol = u_sol
def eval(self, value, x):
x_c = x[0]
y_c = x[1]
if y_c <= 0.501 and y_c >= 0.497:
q = line_integral(self.u_sol,x_c,y_c,self.n)
value[0]= q
value[0]= 0.
def value_shape(self):
return (1,)
def alternate_minimization(u):
print('Solution for displacement')
solver_u.solve()
jump = MyFunctionExpression(n=10,u_sol=project(sym(grad(u))[1,1],V_alpha),element = V_alpha.ufl_element())
jump_sign = conditional(ge(jump,0.),1.,0.)
jump_rate = jump-MyFunctionExpression(n=10,u_sol=project(sym(grad(u_0))[1,1],V_alpha),element = V_alpha.ufl_element())
jump_rate_sign = conditional(ge(jump_rate,0.),1.,0.)
jump_star = conditional(ge(jump,del_c),(del_f - del_c)*f_a_0 + del_c,del_c)
alpha_fun = (f_a_0 + gamma_val)*pow((abs(jump_rate)/jump_star),beta_val)
alpha_fun_1 = conditional(lt(alpha_fun,0.),0.,alpha_fun)
f_a_2 = f_a_0 + alpha_fun_1
f_a = conditional(lt(f_a_2, f_a_T1), f_a_T1, f_a_2)
fdf = (2*f_a_T1)/(f_a + f_a_T1)
f_a_0.assign(project(f_a_2,V_alpha))
fdf_p = project(fdf, V_alpha)
file_f_a << (f_a_0,n)
file_fdf << (fdf_p,n)
u_0.assign(u)
return ()
savedir = "results/"
if os.path.isdir(savedir):
shutil.rmtree(savedir)
file_u = File(savedir+"/u.pvd")
file_f_a = File(savedir+"/f_a.pvd")
file_fdf = File(savedir+"/fdf.pvd")
def postprocessing():
file_u << (u,n)
for n in range(num_steps):
u_R.n = n
postprocessing()
