Ahoy!
I need the fourth order second elasticity tensor, i.e. the derivative of the second Piola-Kirchhoff stress tensor (S) w.r.t. the right Cauchy-Green strain tensor (C). I’m projecting each component into a function space and saving the result at a point in a txt file. There follows a minimal working example. The point is that the minor symmetries do not show up, which is wrong, because both S and C are symmetric tensors in their own rights. Does anyone know what is the issue?
# Minimal working example for saving elasticity tensor at a point
import ufl_legacy as ufl
import os
L, H, W = 1.0, 0.2, 0.3
mesh = BoxMesh(Point(0,0,0), Point(W,H,L), 10,10,10)
lower_facet = CompiledSubDomain("near(x[1], 0)")
left_facet = CompiledSubDomain("near(x[2], 0)")
right_facet = CompiledSubDomain("near(x[2], L)", L=L)
volume_1 = CompiledSubDomain("x[2]<=L*0.5", L=L)
volume_2 = CompiledSubDomain("x[2]>L*0.5", L=L)
boundary_markers = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
boundary_markers.set_all(0)
lower_facet.mark(boundary_markers, 2)
left_facet.mark(boundary_markers, 3)
right_facet.mark(boundary_markers, 6)
dx = Measure("dx", domain=mesh, metadata={"quadrature_degree": 2})
ds = Measure("ds", domain=mesh, subdomain_data=boundary_markers)
# Constitutive model
class Neo_Hookean:
def __init__(self, E, v):
self.E = E
self.v = v
self.mu = Constant(self.E/(2*(1+self.v)))
self.lmbda = Constant(self.v*self.E/((1+self.v)*(1-2*self.v)))
def strain_energy(self, C):
I1_C = ufl.tr(C)
I2_C = ufl.det(C)
J = ufl.sqrt(I2_C)
psi_1 = (self.mu/2)*(I1_C - 3)
ln_J = ufl.ln(J)
psi_2 = -(self.mu*ln_J)+((self.lmbda*0.5)*((ln_J)**2))
return psi_1+psi_2
def first_piolaStress(self, u):
I = Identity(3)
F = grad(u)+I
C = (F.T)*F
C = variable(C)
W = self.strain_energy(C)
S = 2*diff(W,C)
return F*S
def second_elasticityTensor(self, u):
I = Identity(3)
F = grad(u)+I
C = (F.T)*F
C = variable(C)
S = 2*diff(W,C)
return diff(S, C)
constitutive_model = Neo_Hookean(1E6,0.3)
traction_vectors = {2: Constant([0.0, 0.0, 0.0]), 6: Constant([0.0, 0.0, 1E5])}
# Sets the forms
V = VectorFunctionSpace(mesh, "Lagrange", 2)
u_trial = TrialFunction(V)
u_solution = Function(V)
bc = [DirichletBC(V, Constant((0.0, 0.0, 0.0)), boundary_markers, 3)]
external_work = 0.0
internal_work = inner(constitutive_model.first_piolaStress(u_solution),grad(v))*dx
for physical_group, traction in traction_vectors.items():
external_work += dot(traction,v)*ds(physical_group)
# Solver
residual_form = internal_work-external_work
residual_derivative = derivative(residual_form , u_solution, u_trial)
Res = NonlinearVariationalProblem(residual_form, u_solution, bc, J=residual_derivative)
solver = NonlinearVariationalSolver(Res)
solver.solve()
# Gets the fourth order tensor
W_index = FunctionSpace(mesh, "CG", 1)
C_array = np.zeros((3,3,3,3))
for i in range(3):
for j in range(3):
for k in range(3):
for l in range(3):
C_array[i,j,k,l] = project(constitutive_model.second_elasticityTensor(
u_solution)[i,j,k,l], W_index, form_compiler_parameters={
"quadrature_degree": 2})(Point(0.5*W, 0.5*H, 0.5*L))
txt_file = open(os.getcwd()+"//tests//minimal_working_examples_forum//dS_dC_array.txt", "w")
txt_file.write(str(C_array))
txt_file.close()
