Segmentation fault/bus error
I have installed fenicsx on my computer and coded with it several times, and recently I have adapted the code from https://fenicsproject.org/olddocs/dolfin/2019.1.0/python/_downloads/c77fbaa3a69e585fae8c203928c088a6/demo_elastodynamics.py to fit elastodynamics in orthotropy and with some growth, and with a mesh that forms a hollow tube in 3D. the code seems to work fine for a few time stamps, but often when it comes to plotting the final result, or going through the last steps, I get the error “Segmentation fault” or “bus error”, which has happened before on other files that were much simpler, but perhaps with big figures to plot in the end.
I assumed this was an error due to a big command for the computer to execute but am not so sure. Are there ways to avoid that, is it related to my computer processing ability or is it an error that could be in my code? I can provide my code if needed !
Thank you for the help!
Without the code there is now way of giving any guidance. Please try to make the problem a minimal reproducible example.
This is the code, most of it is the code that was given for an adaptation to the elastodynamics code to Fenicsx, the changes are regarding the mesh, and the time loop, and the final plotting
Outer_cylinder = gmsh.model.occ.addCylinder(0, 0, 0, 0, 0, L, R_outer)
Inner_cylinder = gmsh.model.occ.addCylinder(0, 0, 0, 0, 0, L, R_inner)
gmsh.model.occ.synchronize()
tube = gmsh.model.occ.cut([(3, Outer_cylinder)], [(3, Inner_cylinder)])
tube_tag = tube[0][0][1]
gmsh.model.addPhysicalGroup(3, [tube_tag], tag=1)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin",0.01)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax",0.08)
gmsh.model.mesh.generate(3)
domain, ct, _ = model_to_mesh(gmsh.model, MPI.COMM_WORLD, model_rank, gdim=3)
gmsh.finalize()
#### Space definition and function definition
V = fem.functionspace(domain, ("CG", 1, (domain.geometry.dim,)))
Vsig = fem.functionspace(domain, ("DG", 0, (domain.geometry.dim, domain.geometry.dim)))
def boundary_condition(x):
    return np.isclose(x[2], 0, atol=1e-1)
boundary_facets = mesh.locate_entities_boundary(domain, fdim, boundary_condition)
print("Boundary facets:", boundary_facets)
bc_end_0 = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
bcs = [bc_end_0]
boundary_tag = 1
facet_indices = np.array(boundary_facets, dtype=np.int32)
facet_values = np.full(len(facet_indices), boundary_tag, dtype=np.int32)
boundary_mt = mesh.meshtags(domain, fdim, facet_indices, facet_values)
i=1
# Time integration parameters
am = 0.2
af = 0.4
g = 0.5 + af - am
alpha_m = fem.Constant(domain, am)
alpha_f = fem.Constant(domain, af)
gamma = fem.Constant(domain, g)
beta = fem.Constant(domain, (g + 0.5)**2 / 4.0)
rho = 1.1
eta_m = 0.0
eta_k = 0.0
T = 10
Nsteps = 20
dt = fem.Constant(domain, T / Nsteps)
# Functions and fields
u_ = ufl.TestFunction(V)
u = fem.Function(V, name='Displacement')
u_old = fem.Function(V)
v_old = fem.Function(V)
a_old = fem.Function(V)
# Force expression
Traction = fem.Constant(domain, default_scalar_type([0,0,0]))
dx = ufl.Measure("dx", domain=domain)
# Stress tensor
def F(u):
    return ufl.Identity(len(u)) + ufl.nabla_grad(u)
def F_growth(t, alpha):
    return ufl.as_matrix([
        [1, 0, 0],
        [0, 1, 0],
        [0, 0, 1+alpha*t]
def epsilon(u, t, alpha):
    F_stress = F(u)
    F_g = F_growth(t, alpha)
    F_stres = ufl.dot(F_stress, ufl.inv(F_g))
    return 0.5 * (ufl.dot(F_stress.T,F_stress) - ufl.Identity(len(u)))
def S(E1, E3, nu12, nu13, nu31, G13):
    S = np.array([
        [1/E1, -nu12/E1, -nu31/E3, 0, 0, 0],
        [-nu12/E1, 1/E1, -nu31/E3, 0, 0, 0],
        [-nu13/E1, -nu13/E1, 1/E3, 0, 0, 0],
        [0, 0, 0, 1/(2*G13), 0, 0],
        [0, 0, 0, 0, 1/(2*G13), 0],
        [0, 0, 0, 0, 0, (1+nu12)/E1]
    return S
def sigma(u, t, alpha):
    E1 = E_list[1][0]
    E3 = E_list[1][1]
    nu12 = nu_list[1][0]
    nu13 = nu_list[1][1]
    nu31 = nu_list[1][2]
    G13 = G_list[1]
    matrix_S = S(E1, E3, nu12, nu13, nu31, G13)
    inverse_S = ufl.as_matrix(np.linalg.inv(matrix_S))
    eps = epsilon(u, t, alpha)
    vector_eps = ufl.as_vector([eps[0, 0], eps[1, 1], eps[2, 2], eps[1, 2], eps[0, 1], eps[0, 2]])
    vector_sigma = ufl.dot(inverse_S, vector_eps)
    sigma_matrix = ufl.as_matrix([
        [vector_sigma[0], vector_sigma[4], vector_sigma[5]],
        [vector_sigma[4], vector_sigma[1], vector_sigma[3]],
        [vector_sigma[5], vector_sigma[3], vector_sigma[2]]
    return sigma_matrix
## Below this is the elastodynamics file code (copied from another post on here)
def m(u, u_):
    return rho*ufl.inner(u, u_)*dx
def k(u, u_, t, alpha):
    return ufl.inner(sigma(u, t, alpha), ufl.grad(u_)) * dx
def c(u, u_, t, alpha):
    return eta_m * m(u, u_) + eta_k * k(u, u_, t, alpha)
#Update fields
def update_a(u, u_old, v_old, a_old, ufl_=True):
    if ufl_:
        dt_ = dt
        beta_ = beta
        return (u-u_old-dt_*v_old)/beta_/dt_**2 - (1-2*beta_)/2/beta_*a_old
        dt_ = dt
        beta_ = beta.value
        return (u-u_old-float(dt_)*v_old)/float(beta_)/float(dt_)**2 - (1-2*float(beta_))/2/float(beta_)*a_old
def update_v(a, u_old, v_old, a_old, ufl_=True):
    if ufl_:
        return v_old + dt*((1-gamma)*a_old + gamma*a)
        return v_old + float(dt) * ((1 - float(gamma)) * a_old + float(gamma)*a)
def update_fields(u, u_old, v_old, a_old):
    u_vec, u0_vec = u.x.array[:], u_old.x.array[:]
    v0_vec, a0_vec = v_old.x.array[:], a_old.x.array[:]
    a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec, ufl_=False)
    v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec, ufl_=False)
    v_old.x.array[:] = v_vec
    a_old.x.array[:] = a_vec
    u_old.x.array[:] = u_vec
def avg(x_old, x_new, alpha):
    return alpha*x_old + (1-alpha)*x_new
a_new = update_a(u, u_old, v_old, a_old, ufl_=True)
v_new = update_v(a_new, u_old, v_old, a_old, ufl_=True)
# Quantities to track
times = np.linspace(0, T, Nsteps + 1)
u_tip = np.zeros((Nsteps + 1,))
# Create file
with XDMFFile(domain.comm, "rod_dbc0.xdmf", "w") as xdmf_file:
    xdmf_file.write_mesh(domain)
    xdmf_file.write_function(u, 0)
plotter = pyvista.Plotter()
plotter.open_gif("growth_trial.gif", fps=3)
topology, cells, geometry = plot.vtk_mesh(u.function_space)
function_grid = pyvista.UnstructuredGrid(topology, cells, geometry)
values = np.zeros((geometry.shape[0], 3))
values[:, :len(u)] = u.x.array.reshape(geometry.shape[0], len(u))
function_grid["u"] = values
function_grid.set_active_vectors("u")
warped = function_grid.warp_by_vector("u", factor=1)
warped.set_active_vectors("u")
# Add mesh to plotter and visualize
actor = plotter.add_mesh(warped, show_edges=True, lighting=False, clim=[0, 10], cmap = "viridis")
solve_time = 0
# Write function at each time step
for i in range(Nsteps):
    t = times[i + 1]
    print("Time = %s" % t)
    # Problem setup
    res = m(avg(a_old, a_new, alpha_m), u_) + c(avg(v_old, v_new, alpha_f), u_, t, alpha) + \
    k(avg(u_old, u, alpha_f), u_, t, alpha) - rho * \
    ufl.inner(Traction, u_)*ds(2)  # residual to solve
    problem = fem.petsc.NonlinearProblem(res, u, bcs)
    # Solver setup
    solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
    solver.atol = 1e-8
    solver.rtol = 1e-8
    s = time.perf_counter()
    num_its, converged = solver.solve(u)
    e = time.perf_counter()
    solve_time += e-s
    assert converged
    u.x.scatter_forward()
    # Update old fields with new quantities
    # Write the function to the XDMF file
    xdmf_file.write_function(u, t)
    #normal = nanson_normal(u,normal)
    # Update function_grid with new solution
    function_grid["u"][:, :len(u)] = u.x.array.reshape(geometry.shape[0], len(u))
    warped_n = function_grid.warp_by_vector(factor=1)
    warped.points[:, :] = warped_n.points
    plotter.update_scalar_bar_range([0, 10])
    plotter.show_axes()
    plotter.write_frame()
plotter.close()
print("--- %s seconds runtime ---" % (time.time() - start_time))
print(solve_time)
