../../../../miniforge3/envs/fea-env/lib/python3.12/site-packages/dolfinx/fem/petsc.py:624: in _assemble_matrix_block_mat
Asub = A.getLocalSubMatrix(is_rows[i], is_cols[j])
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
E petsc4py.PETSc.Error: error code 73
E [0] SNESSolve() at /home/conda/feedstock_root/build_artifacts/petsc_1727967184032/work/src/snes/interface/snes.c:4841
E [0] SNESSolve_FAS() at /home/conda/feedstock_root/build_artifacts/petsc_1727967184032/work/src/snes/impls/fas/fas.c:870
E [0] SNESFASCycle_Multiplicative() at /home/conda/feedstock_root/build_artifacts/petsc_1727967184032/work/src/snes/impls/fas/fas.c:713
E [0] SNESFASDownSmooth_Private() at /home/conda/feedstock_root/build_artifacts/petsc_1727967184032/work/src/snes/impls/fas/fas.c:362
E [0] SNESSolve_NEWTONLS() at /home/conda/feedstock_root/build_artifacts/petsc_1727967184032/work/src/snes/impls/ls/ls.c:218
E [0] SNESComputeJacobian() at /home/conda/feedstock_root/build_artifacts/petsc_1727967184032/work/src/snes/interface/snes.c:2966
E [0] MatGetLocalSubMatrix() at /home/conda/feedstock_root/build_artifacts/petsc_1727967184032/work/src/mat/interface/matrix.c:10700
E [0] Object is in wrong state
E [0] Matrix must have local to global mapping provided before this call
petsc4py/PETSc/Mat.pyx:4026: Error
================================================================== short test summary info ===================================================================
FAILED unit/fem/test_petsc_nonlinear_assembler.py::TestNLSPETSc::test_assembly_solve_block_nl - petsc4py.PETSc.Error: error code 73
I’d be leaning toward stating that this might be a bug in PETSc.
For instance, can it be possible that for the FAS type somehow calling
clears out not only the values, but also the mappings?
A simple test you could do would be to try to comment out that line (of course then you’ll get non convergence, because the matrix values get accumulated across the nonlinear iterations, but at least it would be useful to check if you still get the same error).
