Slow Newton convergence using dolfinx_materials
Hello
This is my first post here so please let me know if anything is not following the current guidelines. I have tried follow the post (Read before posting: How do I get my question answered?) the best I could.
Anyways, I am having trouble with slow convergence of a mechanical problem defined with the library dolfinx_materials. The problem concerns a simple linear elastic bar in 2 dimensions which is fixed in one end and has a prescribed displacement in the other end. For simplicity, the mesh consists of only 2 linear quadrilateral elements.
The behavior of the bar is defined in MFront using the volumetric and shear components, i.e.
\boldsymbol{\sigma} = \kappa \operatorname{tr} [\boldsymbol{\varepsilon}] \boldsymbol{I} + 2 \mu \operatorname{dev} [\boldsymbol{\varepsilon}]
\mathbb{C} = \kappa \; \boldsymbol{I} \otimes \boldsymbol{I} + 2 \mu \mathbb{P}_\text{dev}
Using the following scripts, the problem converges in 8 iterations. Comparatively, if I define the residual and Jacobian using only UFL (i.e. without MFront and dolfinx_materials), the problem converges in 1 iteration as expected.
Scripts
The FEniCSx script:
# PREAMBLE
# Import python libraries
import os
# Import fenicsx libraries
from dolfinx import fem, mesh
from dolfinx.fem import petsc
from basix.ufl import element
# Import dolfinx_materials libraries
from dolfinx_materials.quadrature_map import QuadratureMap
from dolfinx_materials.material.mfront import MFrontMaterial
from dolfinx_materials.solvers import SNESNonlinearMaterialProblem
from dolfinx_materials.utils import symmetric_tensor_to_vector
# MESH
# Parallel communicator
comm = MPI.COMM_WORLD
# Create the mesh
msh = mesh.create_rectangle(comm=comm, points=[[0.0, 0.0], [25.0, 1.0]], n=[2, 1], cell_type=mesh.CellType.quadrilateral)
# Dimensionality
tdim = msh.topology.dim
fdim = tdim - 1
# Get boundary edges
edge_right = mesh.locate_entities_boundary(mesh=msh, dim=fdim, marker=lambda x: np.isclose(x[0], 25.0))
edge_left = mesh.locate_entities_boundary(mesh=msh, dim=fdim, marker=lambda x: np.isclose(x[0], 0.0))
# FUNCTIONS AND SPACES
# Define element
ele = element(family="Lagrange", cell=msh.basix_cell(), degree=1, shape=(tdim,))
# Create function space
V = fem.functionspace(mesh=msh, element=ele)
# Define current state function
u = fem.Function(V, name="displacement")
# Define test/trial functions
du = ufl.TrialFunction(V)
# BOUNDARY CONDITIONS
# Get boundary displacement dofs
dofs_ux_right = fem.locate_dofs_topological(V=V.sub(0), entity_dim=fdim, entities=edge_right)
dofs_ux_left = fem.locate_dofs_topological(V=V.sub(0), entity_dim=fdim, entities=edge_left)
dofs_uy_left = fem.locate_dofs_topological(V=V.sub(1), entity_dim=fdim, entities=edge_left)
# Set displacement boundary condition values
u_load = fem.Constant(domain=msh, c=PETSc.ScalarType(1.0))
u_fixed = fem.Constant(domain=msh, c=PETSc.ScalarType(0.0))
# Define Dirichlet BCs for displacement
bc_ux_right = fem.dirichletbc(value=u_load, dofs=dofs_ux_right, V=V.sub(0))
bc_ux_left = fem.dirichletbc(value=u_fixed, dofs=dofs_ux_left, V=V.sub(0))
bc_uy_left = fem.dirichletbc(value=u_fixed, dofs=dofs_uy_left, V=V.sub(1))
# Collect boundary conditions
bcs = [bc_ux_right, bc_ux_left, bc_uy_left]
# MATERIAL DEFINITION
# Define MFront material
material = MFrontMaterial(
    path=os.path.join(os.getcwd(), "mfront/src/libBehaviour.so"),
    name="DisplacementDeviatoric",
    hypothesis="plane_strain",
    material_properties={"YoungModulus": 1.0, "PoissonRatio": 0.0},
# Define quadrature map
qmap = QuadratureMap(mesh=msh, deg=2, material=material)
# VARIATIONAL FORMULATION
# Displacement functions
def eps(u):
    '''Strain tensor as vector'''
    return symmetric_tensor_to_vector(ufl.sym(ufl.grad(u)))
# Declare strain measure
qmap.register_gradient("Strain", eps(u))
# Extract stress from material
sig = qmap.fluxes["Stress"]
# Displacement subproblem
res = ufl.dot(sig, eps(v)) * qmap.dx
Jac = qmap.derivative(res, u, du)
# SOLVER
problem = SNESNonlinearMaterialProblem(qmap=qmap, F=res, J=Jac, u=u, bcs=bcs)
# Create and configure solver
solver = PETSc.SNES().create(comm)
solver.setType("newtonls")
solver.setTolerances(rtol=0.0, atol=1e-6, stol=1e-8, max_it=200)
solver.getKSP().setType("preonly")
solver.getKSP().setTolerances(rtol=1.0e-9)
solver.getKSP().getPC().setType("lu")
solver.getKSP().getPC().setFactorSolverType('mumps')
# Disable line search
PETSc.Options().setValue("snes_linesearch_type", "basic")
solver.setFromOptions()
# TEST SOLVER
# Set initial guess
petsc.set_bc(u.x.petsc_vec, bcs)
u.x.scatter_forward()
# Solve
problem.solve(solver, print_solution=True)
The MFront behavior:
@DSL DefaultDSL;
@Behaviour DisplacementDeviatoric;
// β•‘ Hypotheses β•‘
// β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•
@ModellingHypothesis PlaneStrain;
// β•‘ Material properties β•‘
// β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
@MaterialProperty stress young;
young.setGlossaryName("YoungModulus");
@MaterialProperty real nu;
nu.setGlossaryName("PoissonRatio");
// β•‘ Local Variables β•‘
// β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
@LocalVariable stress Ξ»; // first LamΓ© parameter
@LocalVariable stress ΞΌ; // second LamΓ© parameter (shear modulus)
@LocalVariable stress ΞΊ; // bulk modulus
// β•‘ Init Local Variables β•‘
// β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
@InitLocalVariables {
  Ξ» = computeLambda(young, nu);
  ΞΌ = computeMu(young, nu);
  ΞΊ = Ξ» + (2. / 3.) * ΞΌ;
// β•‘ Integrator β•‘
@ProvidesSymmetricTangentOperator;
@Integrator {
  // current total strain tensor
  const auto Ξ΅ = eval(Ξ΅α΅—α΅’ + ΔΡᡗᡒ);
  // stress computation
  Οƒ = ΞΊ * trace(Ξ΅) * Iβ‚‚ + 2 * ΞΌ * deviator(Ξ΅);
  // tangent operator
  if (computeTangentOperator_) {
    // suppress unused variable warning
    static_cast<void>(smt);
    // compute tangent operator
    βˆ‚Οƒβˆ•βˆ‚Ξ”Ξ΅α΅—α΅’ = ΞΊ * Stensor4::IxI() + 2 * ΞΌ * Stensor4::K();
  } // end if computeTangentOperator_
} // end of @Integrator
The pure UFL implementation is practically identical to the dolfinx_materials implementation except for the residual and Jacobian which are defined like this:
# Material parameters
lmbda = E * nu / (1 - nu**2)
mu = E / (2 * (1 + nu))
kappa = lmbda + 2/tdim*mu
# Stress and strain tensors
eps = ufl.variable(ufl.sym(ufl.grad(u)))
sig = kappa * ufl.tr(eps) * ufl.Identity(tdim) + 2 * mu * ufl.dev(eps)
# Problem definition
res = ufl.inner(sig, ufl.grad(v)) * ufl.dx
Jac = ufl.derivative(res, u, du)
Additional information
Convergence history
This is the convergence history of residual norms:
dolfinx_materials implementation:
iter = 0, ||r|| = 5.656854e-02
iter = 1, ||r|| = 1.118034e-02
iter = 2, ||r|| = 2.795085e-03
iter = 3, ||r|| = 6.987712e-04
iter = 4, ||r|| = 1.746928e-04
iter = 5, ||r|| = 4.367320e-05
iter = 6, ||r|| = 1.091830e-05
iter = 7, ||r|| = 2.729575e-06
iter = 8, ||r|| = 6.823938e-07
pure UFL implementation:
iter = 1, ||r|| = 1.182172e-16
Which suggests that at least the residual is computed correctly as the initial residuals are identical.
Jacobian matrix
The Jacobian matrix for the two implementations:
[[ 1.    0.    0.    0.    0.    0.    0.    0.    0.    0.    0.    0.  ]
 [ 0.    1.    0.    0.    0.    0.    0.    0.    0.    0.    0.    0.  ]
 [ 0.    0.    1.    0.    0.    0.    0.    0.    0.    0.    0.    0.  ]
 [ 0.    0.    0.    1.    0.    0.    0.    0.    0.    0.    0.    0.  ]
 [ 0.    0.    0.    0.    5.61  1.96 -5.53 -1.96  0.    0.32  0.   -0.66]
 [ 0.    0.    0.    0.    0.01  8.37  0.01 -8.32  0.    2.12  0.   -2.15]
 [ 0.    0.    0.    0.   -5.53 -1.96  5.61  1.96  0.   -0.32  0.    0.66]
 [ 0.    0.    0.    0.    0.01 -8.32  0.01  8.37  0.   -2.03  0.    2.01]
 [ 0.    0.    0.    0.    0.    0.    0.    0.    1.    0.    0.    0.  ]
 [ 0.    0.    0.    0.   -0.17  2.01  0.16 -2.03  0.    4.13  0.   -4.1 ]
 [ 0.    0.    0.    0.    0.    0.    0.    0.    0.    0.    1.    0.  ]
 [ 0.    0.    0.    0.   -0.17 -2.15  0.16  2.12  0.   -4.22  0.    4.24]]
 [ 0.    0.    0.    0.    4.22 -0.   -4.14 -0.    0.   -0.12  0.   -0.12]
 [ 0.    0.    0.    0.   -0.    8.36  0.   -8.32  0.    2.07  0.   -2.09]
 [ 0.    0.    0.    0.   -4.14  0.    4.22 -0.    0.    0.12  0.    0.12]
 [ 0.    0.    0.    0.   -0.   -8.32 -0.    8.36  0.   -2.09  0.    2.07]
 [ 0.    0.    0.    0.   -0.12  2.07  0.12 -2.09  0.    4.18  0.   -4.16]
 [ 0.    0.    0.    0.   -0.12 -2.09  0.12  2.07  0.   -4.16  0.    4.18]]
The main thing I notice is that the Jacobian of the dolfinx_materials implementation is not symmetric. I imagine there is a (stupid) error somewhere in my script that I just can’t find. Otherwise I think my problem might have something to do with the way dolfinx_materials define the Jacobian?
Installation and platform
I have installed FEniCSx from conda-forge using micromamba. The FEniCSx version is 0.8.0 and I have cloned the main branch of dolfinx_materials I am working in VS Code with a DevContainer setup, but honestly I do not know a lot about this, so anyone thinks this could influence the convergence issue i am having, I will be happy to share the configuration files.
I am grateful for any advice
If anybody comes across the same issue, i found a solution to my problem.
It seems like there happens something internally to the MFront function Stensor4::IxI(). Defining it before using it apparently solves this problem, i.e. the @Integrator block in my MFront file becomes
@Integrator {
  // Fourth-order tensor: Iβ‚‚βŠ—Iβ‚‚
  constexpr Stensor4 IxI = Stensor4::IxI();
  // tangent operator
    βˆ‚Οƒβˆ•βˆ‚Ξ”Ξ΅α΅—α΅’ = ΞΊ * IxI + 2 * ΞΌ * Stensor4::K();
With this definition, my problem now converges in 1 iteration.
