Hello, this is a continuation of efficient-way-to-sum-up-fem-functions, where I was solving the homogenous linear wave equation.
While doing so, I have noticed that the solution breaks down for Newmark’s time discretization scheme (vs central scheme) in the case of a finer mesh and a higher degree of finite element.
Code:
import dolfinx.fem.petsc
n_cells = 100
degree = 2
TIME_SCHEME = "Newmark" # central | Newmark
msh = mesh.create_unit_square(MPI.COMM_WORLD, n_cells, n_cells, cell_type=mesh.CellType.quadrilateral)
t = fem.Constant(msh, 0.)
dt = 5e-3
T = 1
c = 1
V = fem.FunctionSpace(msh, ("Lagrange", degree))
uh = fem.Function(V)
u = ufl.TrialFunction(V)
def u_init(x, sigma=0.05, mu=0.5):
return np.exp(-0.5*((x[0]-mu)/sigma)**2)*np.exp(-0.5*((x[1]-mu)/sigma)**2)
if TIME_SCHEME == "central":
u_n = fem.Function(V)
u_nn = fem.Function(V)
dudtdt = (u - 2 * u_n + u_nn) / dt**2
du = (u + u_nn) / 2
u_n.interpolate(u_init)
u_nn.interpolate(u_init)
elif TIME_SCHEME == "Newmark":
dudt_n = fem.Function(V)
dudtdt_n = fem.Function(V)
u_temp = fem.Function(V)
dudt_temp = fem.Function(V)
beta = 0.25
gamma = 0.5
dudtdt = u
du = u_n + dudt_n*dt + ((1-beta)*dudtdt_n + 2*beta*dudtdt) * dt**2/2
dudt_n.interpolate(u_init)
dudtdt_n.interpolate(u_init)
F = 1 / c**2 * ufl.inner(dudtdt, v) * ufl.dx \
+ ufl.inner(ufl.grad(du), ufl.grad(v)) * ufl.dx \
a, L = ufl.system(F)
petsc_options = {"ksp_type": "preonly",
"pc_type": "lu", "pc_factor_mat_solver_type": "mumps"}
problem = dolfinx.fem.petsc.LinearProblem(a, L, u=uh, bcs=[], petsc_options=petsc_options)
from pathlib import Path
folder = Path("FENICS - results/mine_out_wave_equation_issue")
vtx_u = io.VTXWriter(msh.comm, folder / f"results_{TIME_SCHEME}_cells{n_cells}_degree{degree}.bp", u_n, engine="BP4")
vtx_u.write(0)
while t.value < T:
t.value += dt
problem.solve()
u_nn.x.array[:] = u_n.x.array
u_n.x.array[:] = uh.x.array
u_temp.x.array[:] = u_n.x.array + dudt_n.x.array*dt + ((1-beta)*dudtdt_n.x.array + 2*beta*uh.x.array) * dt**2/2
dudt_temp.x.array[:] = dudt_n.x.array + ((1-gamma)*dudtdt_n.x.array + gamma*uh.x.array) * dt
u_n.x.array[:] = u_temp.x.array
dudt_n.x.array[:] = dudt_temp.x.array
dudtdt_n.x.array[:] = uh.x.array
vtx_u.write(t.value)
