Solve PDE at quadrature (DG 0) instead of nodes (CG 1)
Hi!
For my application, I want to solve a phase field based on information from a mechanical problem. I have this information at the quadrature, and so far, I’ve been projecting this to the nodes, solving the phase field, and then projecting the phase field variable back to the quadrature points.
Now I would like to clean this up, and satisfy my equations directly at the quadrature points. First of all I am unsure whether this conceptually makes sense, given a general FEM formulation. Secondly, in the MWE below, I get the phase field to run in a “DG” 0 space, however the result in paraview appears to be noise rather than a phase field solution.
MWE: (switch lines 20-21 and 31-36 to switch between the two options)
import dolfinx.fem.petsc
from dolfinx import mesh, fem
print(f"dolfinx version: {dolfinx.__version__}")
dt = 2e-1
epsilon = 1e-2
mesh_domain = mesh.create_unit_square(MPI.COMM_WORLD, 50, 50, mesh.CellType.triangle)
Function spaces
# V = fem.functionspace(mesh_domain, ("CG", 1))         # works as expected
V = fem.functionspace(mesh_domain, ("DG", 0))         # gives noisy outcome
phi = fem.Function(V, name="phase")
phi_prev = fem.Function(V, name="phase_old")
Phase field formulation
# Phase-field energy
# Corresponding to CG 1
# F = (phi - phi_prev) / dt * v * ufl.dx + epsilon**2 * ufl.inner(ufl.grad(phi), ufl.grad(v)) * ufl.dx + 2 * phi * ((1-phi)**2 - phi * (1-phi)) * v * ufl.dx
# Corresponding to DG 0
dx = ufl.Measure("dx", domain=mesh_domain)
F = (phi - phi_prev) / dt * v * dx + epsilon**2 * ufl.inner(ufl.grad(phi), ufl.grad(v)) * dx + 2 * phi * ((1-phi)**2 - phi * (1-phi)) * v * dx     # ufl.dx no longer is a valid integration domain. New "dx" is.
Initial conditions
rng = np.random.default_rng(42)
phi.interpolate(lambda x: 0.5 + 0.5 * (0.5 - rng.random(x.shape[1]))) # random
Solver setup: Create nonlinear problem and Newton solver
problem = NonlinearProblem(F, phi)
Solving
file = XDMFFile(MPI.COMM_WORLD, "phasefield_demo.xdmf", "w")
file.write_mesh(mesh_domain)
t = 0.0
timesteps = 20
file.write_function(phi, 0)
for i in range(timesteps):
    phi_prev.x.array[:] = phi.x.array
    r = solver.solve(phi)
    print(f"Step {int(t / dt)}: num iterations: {r[0]}")
    # Process & save solution
    file.write_function(phi, i+1)
file.close()
CG 1 outcome:
DG 0 outcome:
Any help with solving this would be much appreciated!
I’m a bit confused by this question. Isn’t your problem inherently ilposed with a non-conforming basis since you’re not conserving flux between elements? Perhaps I’m missing something but shouldn’t the second order operator of your implicit Euler time formulation be discretised in space with, e.g., a DG or finite volume method if you want to use DG0?
You are right nate, thanks for pointing that out. I can’t solve my problem this way, since DG0 elements are discontinuous while my formulation requires it.
