Hello. I installed FEniCS 2019.1.0 on Ubuntu 16.04 LTS. When I tried ‘import dolfin’, I get error message "cannot import name ‘Array’ ". The python version is 3.5.2.
import dolfin
File “”, line 1, in
File “/usr/lib/python3/dist-packages/dolfin/init.py”, line 136, in
from . import parameter
File “/usr/lib/python3/dist-packages/dolfin/parameter/init.py”, line 11, in
from ffc import default_jit_parameters
File “/usr/lib/python3/dist-packages/ffc/init.py”, line 24, in
from ffc.compiler import compile_form, compile_element
File “/usr/lib/python3/dist-packages/ffc/compiler.py”, line 127, in
from ffc.representation import compute_ir
File “/usr/lib/python3/dist-packages/ffc/representation.py”, line 44, in
from ffc.fiatinterface import create_element, reference_cell
File “/usr/lib/python3/dist-packages/ffc/fiatinterface.py”, line 31, in
import FIAT
File “/usr/local/lib/python3.5/dist-packages/fenics_fiat-2019.2.0.dev0-py3.5.egg/FIAT/init.py”, line 18, in
File “/usr/local/lib/python3.5/dist-packages/fenics_fiat-2019.2.0.dev0-py3.5.egg/FIAT/serendipity.py”, line 20, in
ImportError: cannot import name ‘Array’
