I’m trying to solve a pretty straightforward problem:
Find u_0 \in V_0(\Omega_0) and u_1 \in V_1(\Omega_1) such that
for all v_0 \in V_{0,E}(\Omega_0) and v_1 \in V_{1,E}(\Omega_1). Here V_{\cdot, E}(\cdot) corresponds to the space modified to accommodate homogeneous Dirichlet boundary data.
The following code is my attempt to approximate the solution of the above problem.
import dolfinx.fem.petsc
# Parent mesh
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 8, 8)
# Extract submeshes, mesh0 left, mesh1 right
cells = np.arange(mesh.topology.index_map(mesh.topology.dim).size_local, dtype=np.int32)
sub_cells0 = cells[dolfinx.mesh.compute_midpoints(mesh, mesh.topology.dim, cells)[:, 0] <= 0.5]
sub_cells1 = cells[dolfinx.mesh.compute_midpoints(mesh, mesh.topology.dim, cells)[:, 0] >= 0.5]
sub_mesh0, mapping_entity0, mapping_vertex0, mapping_geom0 = dolfinx.mesh.create_submesh(mesh, mesh.topology.dim, sub_cells0)
sub_mesh1, mapping_entity1, mapping_vertex1, mapping_geom1 = dolfinx.mesh.create_submesh(mesh, mesh.topology.dim, sub_cells1)
# Create domain markers
sub_mt0 = dolfinx.mesh.meshtags(mesh, mesh.topology.dim, sub_cells0, np.ones_like(sub_cells0))
sub_mt1 = dolfinx.mesh.meshtags(mesh, mesh.topology.dim, sub_cells1, np.ones_like(sub_cells1))
# Create spaces on each subdomain and mixed element
V0 = dolfinx.fem.functionspace(sub_mesh0, ("CG", 1))
V1 = dolfinx.fem.functionspace(sub_mesh1, ("CG", 1))
W = ufl.MixedFunctionSpace(V0, V1)
# Integration measures on each subdomain
dx0 = ufl.Measure("dx", domain=mesh, subdomain_data=sub_mt0)
dx1 = ufl.Measure("dx", domain=mesh, subdomain_data=sub_mt1)
# FE formulation
u0, u1 = ufl.TrialFunctions(W)
v0, v1 = ufl.TestFunctions(W)
a = ufl.inner(ufl.grad(u0), ufl.grad(v0)) * dx0
a += ufl.inner(ufl.grad(u1), ufl.grad(v1)) * dx1
L = ufl.inner(dolfinx.fem.Constant(sub_mesh0, 1.0), v0) * dx0
L += ufl.inner(dolfinx.fem.Constant(sub_mesh1, 1.0), v1) * dx1
# Extract block system
a_blocked = ufl.extract_blocks(a)
L_blocked = ufl.extract_blocks(L)
# Create BCs
sub_mesh0.topology.create_connectivity(sub_mesh0.topology.dim, sub_mesh0.topology.dim - 1)
sub_mesh0.topology.create_connectivity(sub_mesh0.topology.dim - 1, sub_mesh0.topology.dim)
u0_bdry = dolfinx.fem.Function(V0)
u0_bc = dolfinx.fem.dirichletbc(
u0_bdry, dolfinx.fem.locate_dofs_topological(
V0, sub_mesh0.topology.dim - 1, dolfinx.mesh.exterior_facet_indices(sub_mesh0.topology)
sub_mesh1.topology.create_connectivity(sub_mesh1.topology.dim, sub_mesh1.topology.dim - 1)
sub_mesh1.topology.create_connectivity(sub_mesh1.topology.dim - 1, sub_mesh1.topology.dim)
u1_bdry = dolfinx.fem.Function(V1)
u1_bc = dolfinx.fem.dirichletbc(
u1_bdry, dolfinx.fem.locate_dofs_topological(
V1, sub_mesh1.topology.dim - 1, dolfinx.mesh.exterior_facet_indices(sub_mesh1.topology)
# Solve problem
bcs = [u0_bc, u1_bc]
u0h = dolfinx.fem.Function(V0)
u1h = dolfinx.fem.Function(V1)
problem = dolfinx.fem.petsc.LinearProblem(
a_blocked,
L_blocked,
u=[u0h, u1h],
bcs=bcs,
entity_maps=[mapping_entity0, mapping_entity1],
petsc_options={
"ksp_type": "preonly",
"pc_type": "lu",
"ksp_error_if_not_converged": True,
"ksp_monitor": None,
petsc_options_prefix="monolithic_",
problem.solve()
I notice that I’m getting non-deterministic success. Sometimes this solves giving me the expected result, and sometimes it does not, yielding the error:
File "$SCRIPT_PATH/poisson_subdomain_coupled.py", line 65, in <module>
a_blocked,
...<11 lines>...
File "$LIB_PATH/python3.14/site-packages/dolfinx/fem/petsc.py", line 804, in __init__
self._A = create_matrix(self._a, kind=kind)
File "$LIB_PATH/python3.14/site-packages/dolfinx/fem/petsc.py", line 193, in create_matrix
return _cpp.fem.petsc.create_matrix_block(_a, kind)
RuntimeError: Cannot insert rows that do not exist in the IndexMap.
Exception ignored while calling deallocator <function LinearProblem.__del__ at 0x12aee5380>:
File "$LIB_PATH/python3.14/site-packages/dolfinx/fem/petsc.py", line 882, in __del__
lambda obj: obj is not None, (self._solver, self._A, self._b, self._x, self._P_mat)
AttributeError: 'LinearProblem' object has no attribute '_solver'
Am I doing something silly in my original script?
>>> import dolfinx
>>> dolfinx.git_commit_hash
'338f32f692a1500571c910a29e69a3ff1d5c6549'
>>> dolfinx.__version__
'0.11.0.dev0'
