The mesh converted into xdmf has problem
Dear everyone,
I generated mesh with gmsh and it looks normally. Then the mesh is converted into xdmf file and the mesh is messy as it’s viewed with paraview. The figures are the mesh looks in Gmsh editor and Paraview respectively. I don’t know it’s the problem with paraview or the transform code.
The transformation code is:
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    if prune_z:
        out_mesh.prune_z_0()
    return out_mesh
    msh = meshio.read("mesh.msh")
    # Create and save one file for the mesh, and one file for the facets
    meshio.write("mt.xdmf", line_mesh)
The gmsh file used to generate mesh is :
// Gmsh project created on Tue Oct 19 20:46:26 2021
Point(1) = {0, 0, 0, 0.0001};
Point(2) = {0.0015, 0, 0, 0.0001};
Point(3) = {0, 0.0015, 0, 0.0001};
Point(4) = {0, 0.015, 0, 0.001};
Point(5) = {0.015, 0, 0, 0.001};
Point(6) = {0.15, 0, 0, 0.01};
Point(7) = {0, 0.15, 0, 0.01};
Point(8) = {0, 1.5, 0, 0.1};
Point(9) = {1.5, 0, 0, 0.1};
Point(10) = {15, 0, 0, 1};
Point(11) = {0, 15, 0, 1};
Point(12) = {0, 150, 0, 10};
Point(13) = {150, 0, 0, 10};
Point(14) = {1500, 0, 0, 100};
Point(15) = {0, 1500, 0, 100};
Line(1) = {14, 13};
Line(2) = {15, 12};
Line(3) = {13, 10};
Line(4) = {12, 11};
Line(5) = {10, 9};
Line(6) = {11, 8};
Line(7) = {9, 6};
Line(8) = {8, 7};
Line(9) = {6, 5};
Line(10) = {7, 4};
Line(11) = {5, 2};
Line(12) = {4, 3};
Line(13) = {2, 1};
Line(14) = {3, 1};
Circle(15) = {2, 1, 3};
Circle(16) = {5, 1, 4};
Circle(17) = {6, 1, 7};
Circle(18) = {9, 1, 8};
Circle(19) = {10, 1, 11};
Circle(20) = {13, 1, 12};
Circle(21) = {14, 1, 15};
Curve Loop(1) = {21, 2, -20, -1};
Plane Surface(1) = {1};
Curve Loop(2) = {20, 4, -19, -3};
Plane Surface(2) = {2};
Curve Loop(3) = {19, 6, -18, -5};
Plane Surface(3) = {3};
Curve Loop(4) = {18, 8, -17, -7};
Plane Surface(4) = {4};
Curve Loop(5) = {17, 10, -16, -9};
Plane Surface(5) = {5};
Curve Loop(6) = {16, 12, -15, -11};
Plane Surface(6) = {6};
Curve Loop(7) = {15, 14, -13};
Plane Surface(7) = {7};
Physical Surface("Air", 22) = {1, 2, 3, 4, 5, 6};
Physical Surface("Conductor", 23) = {7};
Physical Curve("Boundary", 24) = {20};
Your mesh file gives an error
In [5]: msh = meshio.read("mesh.msh")
ReadError                                 Traceback (most recent call last)
<ipython-input-5-3bc8152695b7> in <module>
----> 1 msh = meshio.read("mesh.msh")
/usr/lib/python3/dist-packages/meshio/_helpers.py in read(filename, file_format)
     68         raise ReadError(msg)
     69
---> 70     return reader_map[file_format](filename)
     71
     72
/usr/lib/python3/dist-packages/meshio/gmsh/main.py in read(filename)
     17     filename = pathlib.Path(filename)
     18     with open(filename.as_posix(), "rb") as f:
---> 19         mesh = read_buffer(f)
     20     return mesh
     21
/usr/lib/python3/dist-packages/meshio/gmsh/main.py in read_buffer(f)
     32
     33     if line != "$MeshFormat":
---> 34         raise ReadError()
     35     fmt_version, data_size, is_ascii = _read_header(f)
     36
ReadError:
I guess you left out a step. The mesh file you gave is gmsh input, not mesh.msh.
Even after processing with gmsh, the resultant mesh.msh still gives an error
In [4]: msh = meshio.read("mesh.msh")
<ipython-input-4-3bc8152695b7> in <module>
     69
     71
     72
     20     return mesh
     21
     46                 )
     47             )
---> 48     return reader.read_buffer(f, is_ascii, data_size)
     49
     50
/usr/lib/python3/dist-packages/meshio/gmsh/_gmsh41.py in read_buffer(f, is_ascii, data_size)
    100
    101     if cells is None:
--> 102         raise ReadError("$Element section not found.")
    103     cell_data = cell_data_from_raw(cells, cell_data_raw)
    104     cell_data.update(cell_tags)
ReadError: $Element section not found.
There is no real issue here. The issue is that you are trying to show cell sizes of a magnitude of order 4 difference at once. By using the Clip filter (with options: Origin: 0.1, 0.1, 0, Normal: 1, 1, 0 the boundary will render nicely
Dear dparsons,
Thank your for help. Yes, it’s the input file for gmsh since the msh file is too big to allow uploading. I also got the same error “ReadError: $Element section not found.” and it’s solved by adding Physical Curve(“Boundary”, 24) = {20}; in the input file in the gmsh version “4.8.4”. I don’t know why you still have the problem
Dear dokken,
Thank you very much for your helpful answer.
That line is in your script. I think my problem is just gmsh usage. The missing command seems to be the invocation (the generated mesh is empty if -2 is not specified),
gmsh -2 mesh.gmsh
Anyway, looks like dokken has resolved the real problem.
