Hi DOLFINx community,
I am solving a transient EM axisymmetric magnetoquasistatic problem in DOLFINx using a backward Euler time discretization, and I am observing an unexpected behavior when transitioning from the static to the transient formulation.
Below I provide a minimal reproducible example consisting of:
a source coil driven by a prescribed current ramp (I0 + dIsdt * t), and
a passive conductive coil where eddy currents are induced.
By modifying dIsdt in a wide range (e.g. (0, 1e6]), one can observe that for sufficiently small ramp rates the eddy current evolution no longer follows the expected analytical RL curve.
More precisely:
For larger values of
dIsdt, the transient solution is smooth and matches the analytical RL response very well. -
As
dIsdtdecreases, a noticeable jump appears at the first transient time step. -
After this first step, the solution evolves smoothly again, but the initial deviation remains.
This behavior seems to be directly linked to the first transient step (it is like the previous static result, prev_psi, not passed correctly to the transient analysis… indeed the issue is not present if I0 = 0).
Additional details:
DOLFINx version: 0.8.0
The problem is set up using
LinearProblem -
The system is fully reassembled at every time step (I am aware this is not optimal, but I intentionally started with a straightforward and “safe” implementation before optimizing the workflow)
I would greatly appreciate any suggestions to solve this problem.
Thanks in advance for your help.
from ufl import TrialFunction, TestFunction, grad, dot, SpatialCoordinate
from dolfinx import fem
from dolfinx.fem import Function, functionspace, Constant, form
from dolfinx.io import gmshio
from dolfinx.mesh import locate_entities_boundary
# 1. MESH GENERATION
gmsh.model.add("D_shape")
r_outer = 10.0
width = 0.1
shift = 1.0
mesh_size = 0.2
p1 = gmsh.model.occ.addPoint(0, r_outer, 0)
p2 = gmsh.model.occ.addPoint(0, 0, 0)
p3 = gmsh.model.occ.addPoint(0, -r_outer, 0)
arc = gmsh.model.occ.addCircleArc(p1, p2, p3)
line = gmsh.model.occ.addLine(p3, p1)
loop = gmsh.model.occ.addCurveLoop([arc, line])
d_surface = gmsh.model.occ.addPlaneSurface([loop])
square1 = gmsh.model.occ.addRectangle(shift, shift, 0, width, width)
square2 = gmsh.model.occ.addRectangle(shift, -shift, 0, width, width)
cut = gmsh.model.occ.cut([(2, d_surface)],
[(2, square1), (2, square2)],
removeObject=True,
removeTool=False)
gmsh.model.occ.synchronize()
gmsh.model.addPhysicalGroup(2, [cut[0][0][1]], 3)
gmsh.model.addPhysicalGroup(2, [square1], 1)
gmsh.model.addPhysicalGroup(2, [square2], 2)
gmsh.model.mesh.setSize(gmsh.model.getEntities(0), mesh_size)
gmsh.model.mesh.generate(2)
domain, cell_tags, facet_tags = gmshio.model_to_mesh(
gmsh.model, MPI.COMM_WORLD, 0, gdim=2
gmsh.finalize()
dx = ufl.Measure("dx", domain=domain, subdomain_data=cell_tags)
tdim = domain.topology.dim
# 2. FUNCTION SPACES
V = functionspace(domain, ("Lagrange", 1))
Q = functionspace(domain, ("DG", 0))
psi = Function(V)
psi_prev = Function(V)
js = Function(Q)
sigma = Function(Q)
cells_square1 = cell_tags.find(1)
cells_square2 = cell_tags.find(2)
sigma.x.array[cells_square2] = 5.96e7
sigma.x.scatter_forward()
# 3. PHYSICAL PARAMETERS
MU0 = Constant(domain, PETSc.ScalarType(4e-7 * np.pi))
dt = Constant(domain, PETSc.ScalarType(1e-3))
I0 = 1e3
dIsdt = 1.0
R_self = 1.1077e-05
L_self = 3.9273e-06
tau_RL = L_self / R_self
dt.value = tau_RL / 10
# 4. BOUNDARY CONDITION
facets = locate_entities_boundary(
domain, tdim - 1,
lambda x: np.isclose(x[0], 0.0)
dofs = fem.locate_dofs_topological(V, tdim - 1, facets)
bc = fem.dirichletbc(PETSc.ScalarType(0.0), dofs, V)
# 5. STATIC INITIAL CONDITION
area_square1 = domain.comm.allreduce(
fem.assemble_scalar(form(1.0 * dx(1))),
op=MPI.SUM,
js.x.array[cells_square1] = I0 / area_square1
js.x.scatter_forward()
x = SpatialCoordinate(domain)
r = x[0]
r_factor = 1 / (2.0 * np.pi * r)
a_static = (r_factor / MU0) * dot(grad(u), grad(v)) * dx
L_static = js * v * dx(1)
problem_static = LinearProblem(a_static, L_static, u=psi, bcs=[bc])
problem_static.solve()
psi_prev.x.array[:] = psi.x.array[:]
psi_prev.x.scatter_forward()
# 6. TIME LOOP (LinearProblem style)
t_end = 4 * tau_RL
t_values = np.arange(0, t_end + dt.value, dt.value)
Ieddy = np.zeros(len(t_values))
for i in range(1, len(t_values)):
# Update source current
js.x.array[cells_square1] = (
(I0 + dIsdt * t_values[i]) / area_square1
# Base operators
a = (r_factor / MU0) * dot(grad(u), grad(v)) * dx
L = js * v * dx
# Transient contribution (Backward Euler)
a += (r_factor * sigma / dt) * u * v * dx
L += (r_factor * sigma / dt) * psi_prev * v * dx
problem = LinearProblem(a, L, u=psi, bcs=[bc])
problem.solve()
# Eddy current
Je = fem.Function(Q)
Je_expr = fem.Expression(
-sigma * r_factor * (psi - psi_prev) / dt,
Q.element.interpolation_points(),
Je.interpolate(Je_expr)
Ieddy[i] = domain.comm.allreduce(
fem.assemble_scalar(form(Je * dx(2))),
op=MPI.SUM,
# 7. FINAL PLOT (FEM + ANALYTICAL)
if domain.comm.rank == 0:
L_mutual = 1.62943168e-07
Ieddy_analytic = (
-L_mutual * dIsdt / R_self
* (1 - np.exp(-t_values / tau_RL))
plt.figure(figsize=(8, 5))
plt.plot(t_values, Ieddy, linewidth=2, label="DOLFINx FEM")
plt.plot(t_values, Ieddy_analytic, "--", linewidth=2,
label="Analytical RL")
plt.xlabel("Time [s]")
plt.ylabel("Eddy current [A]")
plt.title("Transient Eddy Current Response")
plt.legend()
plt.grid(True)
plt.tight_layout()
