Dear Community
I wrote a code for calculating the drag experienced by a sphere in Stokes flow. When I performed the calculations on a .msh file [titled “annular.msh”] that was created in GMSH, and imported into FEniCS using the procedure described here, I get the theoretically correct answer of 6\pi.
However when I use gmsh -2 annular.geo to create annular.msh, and perform the necessary calculations I notice that the computed drag is \sim 20.6, which is erroneous.
May I please know there is a difference in the output? Also, I would like to know how the mesh resolution is specified in the geo file, so that I may work with the script directly, instead of having to generate the geometry in the GUI each time.
The contents of “annular.geo” are given below:
// Gmsh project created on Thu Oct 21 14:19:22 2021
SetFactory("OpenCASCADE");
Circle(1) = {0, 0, 0, 1, 0, Pi};
Circle(2) = {0, 0, 0, 5, 0, Pi};
Line(3) = {1, 3};
Line(4) = {2, 4};
Curve Loop(1) = {2, -4, -1, 3};
Plane Surface(1) = {1};
Physical Curve(1) = {1};
Physical Curve(2) = {2};
Physical Surface(3) = {1};
Thank You
Warm Regards
