Hi averyone,
I have a 3D simulation (SIM1) in a cylinder in which the temperature is solved.
What I need is to extract the temperature profile in the outlet section of the cylinder and use it as a boundary condition at the inlet section in another simulation (SIM2).
Note that:
The meshes used in the two simulation are the same and the triangles in the outlet section of SIM1 are aligned with the triangles in the inlet section of SIM2
Ok, I need to edit and correct one part of the question.
The question reamins the same but:
The meshes are not the same. They share the “shape” but not the size and then the triangles in the inlet section of SIM2 are not aligned with those of SIM1
