Using 2 disconnected meshes and connecting them with jump condition
Hi there,
I want to impose a jump condition between two separate meshes like below;
Is it possible in dolfinx? Should define two different meshes or mixed elements for one mesh?
I did try using 2 seperate mesh files and when I read subdomains and facets_tags, I get;
File "main.py", line 33, in <module>
    matrices = PassiveFlame2(mesh1, mesh2, boundary_conditions, c, degree=degree)
  File "/home/ee331/Dev/Acoustics-Dev/LOTAN/HelmholtzX/MP/Javier/passive_flame_x.py", line 280, in __init__
    self.a_form = form(-self.c**2 * inner(grad(self.u1), grad(self.v1))*self.dx1(1)-self.c**2 * inner(grad(self.u2), grad(self.v2))*self.dx2(2))
  File "/home/ee331/Dev/Venvs/v042c/lib/python3.8/dist-packages/dolfinx/fem/forms.py", line 139, in form
    return _create_form(form)
  File "/home/ee331/Dev/Venvs/v042c/lib/python3.8/dist-packages/dolfinx/fem/forms.py", line 134, in _create_form
    return _form(form)
  File "/home/ee331/Dev/Venvs/v042c/lib/python3.8/dist-packages/dolfinx/fem/forms.py", line 102, in _form
    subdomains, = list(sd.values())  # Assuming single domain
ValueError: too many values to unpack (expected 1)
I think dolfinx can only handle single domain. But wonder is there any other way of implementing this?
Thank you for your answers in advance.
There is no way with ufl to prescribe such a variational form.
Depending on what the jump condition between the meshes is supposed to do, you could use dolfinx_mpc.
Can I still use separate meshes, if I map these 2 boundaries using dolfinx_mpc?
See for instance: dolfinx_mpc/demo_elasticity_disconnect_2D.py at main · jorgensd/dolfinx_mpc · GitHub
Depending on your jump-condition, you can do it in dolfinx_mpc.
I am solving an eigenvalue problem. Weak form of my equation is;
-\int_\Omega s^2 \nabla u \cdot \nabla \hat{v} d\Omega + \int_{\partial \Omega} s^2 (\nabla \hat{u} \cdot \mathbf{n}) v dS + \omega^2 \int_\Omega u \cdot \hat{v} d\Omega = 0
where
\nabla \hat{u} \cdot \mathbf{n} = [\hat{u}_2-\hat{u}_1] for the mesh below;
I couldn’t understand how I impose the pressure difference on boundaries. Here is my MWE;
from typing import List, Tuple
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace,
                         VectorFunctionSpace, locate_dofs_geometrical,
                         locate_dofs_topological,form)
from dolfinx.mesh import locate_entities_boundary
from dolfinx_mpc import LinearProblem, MultiPointConstraint, assemble_matrix
from dolfinx_mpc.utils import (create_point_to_point_constraint,
                               gmsh_model_to_mesh, rigid_motions_nullspace)
from ufl import (Identity, Measure, SpatialCoordinate, TestFunction,
                 TrialFunction, grad, inner, sym, tr)
from slepc4py import SLEPc
# Mesh parameters for creating a mesh consisting of two disjoint rectangles
right_tag = 1
left_tag = 2
if MPI.COMM_WORLD.rank == 0:
    gmsh.clear()
    left_rectangle = gmsh.model.occ.addRectangle(0, 0, 0, 1, 1)
    right_rectangle = gmsh.model.occ.addRectangle(1.1, 0, 0, 1, 1)
    gmsh.model.occ.synchronize()
    # Add physical tags for volumes
    gmsh.model.addPhysicalGroup(1, [8], tag=2)
    gmsh.model.setPhysicalName(1, 2, "Downstream")
    gmsh.model.addPhysicalGroup(1, [2], tag=1)
    gmsh.model.setPhysicalName(1, 1, "Upstream")
    gmsh.model.addPhysicalGroup(2, [right_rectangle], tag=right_tag)
    gmsh.model.setPhysicalName(2, right_tag, "Right square")
    gmsh.model.addPhysicalGroup(2, [left_rectangle], tag=left_tag)
    gmsh.model.setPhysicalName(2, left_tag, "Left square")
    gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 1)
    gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 1)
    gmsh.option.setNumber("Mesh.MeshSizeMax", 0.1)
    # Generate mesh
    gmsh.model.mesh.generate(2)
    # gmsh.option.setNumber("General.Terminal", 1)
    # gmsh.fltk.run()
mesh, ct,ft = gmsh_model_to_mesh(gmsh.model, cell_data=True, facet_data=True, gdim=2)
gmsh.clear()
gmsh.finalize()
MPI.COMM_WORLD.barrier()
with XDMFFile(mesh.comm, "test.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
V = FunctionSpace(mesh, ("Lagrange", 1))
tdim = mesh.topology.dim
fdim = tdim - 1
DG0 = FunctionSpace(mesh, ("DG", 0))
left_cells = ct.indices[ct.values == left_tag]
right_cells = ct.indices[ct.values == right_tag]
left_dofs = locate_dofs_topological(DG0, tdim, left_cells)
right_dofs = locate_dofs_topological(DG0, tdim, right_cells)
dx = Measure("dx", domain=mesh, subdomain_data=ct)
ds = Measure("ds", domain=mesh, subdomain_data=ft)
def gather_dof_coordinates(V, dofs):
    Distributes the dof coordinates of this subset of dofs to all processors
    local_dofs = dofs[dofs < V.dofmap.index_map.size_local * V.dofmap.index_map_bs]
    coords = x[local_dofs]
    num_nodes = len(coords)
    glob_num_nodes = MPI.COMM_WORLD.allreduce(num_nodes, op=MPI.SUM)
    recvbuf = None
        recvbuf = np.zeros(3 * glob_num_nodes, dtype=np.float64)
    sendbuf = coords.reshape(-1)
    sendcounts = np.array(MPI.COMM_WORLD.gather(len(sendbuf), 0))
    MPI.COMM_WORLD.Gatherv(sendbuf, (recvbuf, sendcounts), root=0)
    glob_coords = MPI.COMM_WORLD.bcast(recvbuf, root=0).reshape((-1, 3))
    return glob_coords
facets_r = locate_entities_boundary(mesh, fdim, lambda x: np.isclose(x[0], 1))
dofs_r = locate_dofs_topological(V, fdim, facets_r)
facets_l = locate_entities_boundary(mesh, fdim, lambda x: np.isclose(x[0], 1.1))
dofs_l = locate_dofs_topological(V, fdim, facets_l)
# Given the local coordinates of the dofs, distribute them on all processors
nodes = [gather_dof_coordinates(V, dofs_r), gather_dof_coordinates(V, dofs_l)]
pairs = []
for x in nodes[0]:
    for y in nodes[1]:
        if np.isclose(x[1], y[1]):
            pairs.append([x, y])
            break
mpc = MultiPointConstraint(V)
for i, pair in enumerate(pairs):
    sl, ms, co, ow, off = create_point_to_point_constraint(
        V, pair[0], pair[1])
    mpc.add_constraint(V, sl, ms, co, ow, off)
mpc.finalize()
s = 343
a_form = -s**2 * inner(grad(u), grad(v))*dx
e_form =  s**2 * (inner(u, v)*ds(2)-inner(u, v)*ds(1)) # THIS MIGHT BE WRONG
mass_form = form(a_form+e_form)
A = assemble_matrix(mass_form, mpc)
stiffnes_form = form(inner(u , v) * dx)
C = assemble_matrix(stiffnes_form, mpc)
C.assemble()
def print0(string: str):
    """Print on rank 0 only"""
        print(string)
def solve_GEP_shiftinvert(A: PETSc.Mat, B: PETSc.Mat,
                          problem_type: SLEPc.EPS.ProblemType = SLEPc.EPS.ProblemType.GNHEP,
                          solver: SLEPc.EPS.Type = SLEPc.EPS.Type.KRYLOVSCHUR,
                          nev: int = 10, tol: float = 1e-7, max_it: int = 10,
                          target: float = 0.0, shift: float = 0.0) -> SLEPc.EPS:
    # Build an Eigenvalue Problem Solver object
    EPS = SLEPc.EPS()
    EPS.create(comm=MPI.COMM_WORLD)
    A=-A
    EPS.setOperators(A, B)
    EPS.setProblemType(problem_type)
    # set the number of eigenvalues requested
    EPS.setDimensions(nev=nev)
    # Set solver
    EPS.setType(solver)
    # set eigenvalues of interest
    EPS.setWhichEigenpairs(SLEPc.EPS.Which.TARGET_MAGNITUDE)
    EPS.setTarget(target)  # sorting
    # set tolerance and max iterations
    EPS.setTolerances(tol=tol, max_it=max_it)
    # Set up shift-and-invert
    # Only work if 'whichEigenpairs' is 'TARGET_XX'
    ST = EPS.getST()
    ST.setType(SLEPc.ST.Type.SINVERT)
    ST.setShift(shift)
    EPS.setST(ST)
    # set monitor
    it_skip = 1
    EPS.setMonitor(lambda eps, it, nconv, eig, err:
                   monitor_EPS_short(eps, it, nconv, eig, err, it_skip))
    # parse command line options
    EPS.setFromOptions()
    # Display all options (including those of ST object)
    # EPS.view()
    EPS.solve()
    EPS_print_results(EPS)
    return EPS
def EPS_get_spectrum(EPS: SLEPc.EPS,
                     mpc: MultiPointConstraint) -> Tuple[List[complex], List[PETSc.Vec], List[PETSc.Vec]]:
    """ Retrieve eigenvalues and eigenfunctions from SLEPc EPS object.
        Parameters
        EPS
           The SLEPc solver
        mpc
           The multipoint constraint
        Returns
            Tuple consisting of: List of complex converted eigenvalues,
             lists of converted eigenvectors (real part) and (imaginary part)
    # Get results in lists
    eigval = [EPS.getEigenvalue(i) for i in range(EPS.getConverged())]
    eigvec_r = list()
    eigvec_i = list()
    V = mpc.function_space
    for i in range(EPS.getConverged()):
        vr = Function(V)
        vi = Function(V)
        EPS.getEigenvector(i, vr.vector, vi.vector)
        eigvec_r.append(vr)
        eigvec_i.append(vi)    # Sort by increasing real parts
    idx = np.argsort(np.real(np.array(eigval)), axis=0)
    eigval = [eigval[i] for i in idx]
    eigvec_r = [eigvec_r[i] for i in idx]
    eigvec_i = [eigvec_i[i] for i in idx]
    return (eigval, eigvec_r, eigvec_i)
def monitor_EPS_short(EPS: SLEPc.EPS, it: int, nconv: int, eig: list, err: list, it_skip: int):
    Concise monitor for EPS.solve().
    Parameters
    eps
        Eigenvalue Problem Solver class.
    it
       Current iteration number.
    nconv
       Number of converged eigenvalue.
    eig
       Eigenvalues
    err
       Computed errors.
    it_skip
        Iteration skip.
    if (it == 1):
        print0('******************************')
        print0('***  SLEPc Iterations...   ***')
        print0("Iter. | Conv. | Max. error")
        print0(f"{it:5d} | {nconv:5d} | {max(err):1.1e}")
    elif not it % it_skip:
def EPS_print_results(EPS: SLEPc.EPS):
    """ Print summary of solution results. """
    print0("\n******************************")
    print0("*** SLEPc Solution Results ***")
    print0("******************************")
    its = EPS.getIterationNumber()
    print0(f"Iteration number: {its}")
    nconv = EPS.getConverged()
    print0(f"Converged eigenpairs: {nconv}")
    if nconv > 0:
        # Create the results vectors
        vr, vi = EPS.getOperators()[0].createVecs()
        print0("\nConverged eigval.  Error ")
        print0("----------------- -------")
        for i in range(nconv):
            k = EPS.getEigenpair(i, vr, vi)
            error = EPS.computeError(i)
            if k.imag != 0.0:
                print0(f" {k.real:2.2e} + {k.imag:2.2e}j {error:1.1e}")
                pad = " " * 11
                print0(f" {k.real:2.2e} {pad} {error:1.1e}")
target_eig = (170*2*np.pi)**2
EPS = solve_GEP_shiftinvert(A, C, problem_type=SLEPc.EPS.ProblemType.GHEP,
                            solver=SLEPc.EPS.Type.KRYLOVSCHUR,
                            nev=10, tol=1e-7, max_it=10,
                            target=target_eig, shift=1.5)
(eigval, eigvec_r, eigvec_i) = EPS_get_spectrum(EPS, mpc)
for i in range(len(eigval)):
    mpc.backsubstitution(eigvec_r[i].vector)
    mpc.backsubstitution(eigvec_i[i].vector)
print0(f"Computed eigenvalues:\n {np.around(eigval,decimals=2)}")
print0(f"Computed eigenfrequencies:\n {np.sqrt(eigval)/(2*np.pi)}")
# Save first eigenvector
with XDMFFile(MPI.COMM_WORLD, "results/eigenvector.xdmf", "w", encoding=XDMFFile.Encoding.HDF5) as xdmf:
    xdmf.write_function(eigvec_r[12])
I get this results now;
 [-1.00000000e+00+0.j -1.00000000e+00+0.j -1.00000000e+00+0.j
 -1.00000000e+00+0.j -1.00000000e+00+0.j -0.00000000e+00+0.j
  2.90732620e+05+0.j  1.16776004e+06+0.j  1.16806494e+06+0.j
  1.46205284e+06+0.j]
 [  0.        +1.59154943e-01j   0.        +1.59154943e-01j
   0.        +1.59154943e-01j   0.        +7.73230399e-07j
  85.81575235+0.00000000e+00j 171.98752123+0.00000000e+00j
 172.009972  +0.00000000e+00j 192.44279967+0.00000000e+00j]
These values makes sense, but I wonder whether my implementation is correct or not?
I cannot get damping (positive imaginary part for eigenvalues) for the eigenvalues. Originally, my damping term is;
\int_{\partial \Omega} s^2 (\nabla \hat{u} \cdot \mathbf{n} v dS) = \int_{\partial \Omega} s^2 \frac{K_R}{d^2}[\hat{u}_2-\hat{u}_1]v dS
where
K_R = 2a\frac{(\pi/2 I_1(St) e^{-St})-1jK_1(St)sinh(Sh)}{St((\pi/2 I_1(St) e^{-St})+1jK_1(St)cosh(Sh))}, I_1 and K_1 are Bessel functions and St = wa/U.
My implementation is;
c = 347
a = 3*1E-3
d = 35*1E-3
U = 5
omega = (382.9)*2*np.pi
St = omega*a/U
num =       (np.pi/2)*jv(1,St)*np.exp(-St)-1j*yv(1,St)*np.sinh(St)
denom = St*((np.pi/2)*jv(1,St)*np.exp(-St)+1j*yv(1,St)*np.cosh(St))
expression = 1+num/denom
K_r = 2*a*expression
e_form =  -c**2 * K_r/d**2 * (inner(u, v)*ds(1)-inner(u, v)*ds(2))
Is it something mpc cannot handle @dokken ? I am using v0.4.1 of dolfinx_mpc and v0.4.2 of dolfinx.
Alternatively, you could try adapting the code from Mirok/emi-book-fem.
In particular, take a look at this demo that shows how to implement Poisson equations on two domains with some coupling condition between them.
The model problem and equations this repo solves are introduced in Chapter 5 of the EMI book: Solving the EMI Equations using Finite Element Methods | SpringerLink
Implementing your jump condition with dolfinx_mpc would be quite tricky, I feel.
You might be better off with a fixed-point iteration, similar to a domain-decomposition method with Robin-type coupling, in which you solve on one domain at a time until you converge.
I think dolfinx_mpc is not suitable for this problem. DG elements could be more useful. I have implemented another simple MWE;
from dolfinx.io import gmshio
from dolfinx.fem import FunctionSpace, form
from dolfinx.fem.petsc import  assemble_matrix
from ufl import TestFunction,TrialFunction,Measure,inner,grad,jump
from scipy.special import jv,yv
gdim = 2
mesh_comm = MPI.COMM_WORLD
model_rank = 0
if model_rank == 0:
    gmsh.clear()
    gmsh.option.setNumber("General.Terminal", 0)
    r_inner, r_outer = 0.2 , 0.25
    c1 = gmsh.model.occ.addCircle(0, 0, 0, r_inner)
    cl1 = gmsh.model.occ.addCurveLoop([c1], 1)
    s1 = gmsh.model.occ.addPlaneSurface([cl1])
    c2 = gmsh.model.occ.addCircle(0, 0, 0, r_outer)
    cl2= gmsh.model.occ.addCurveLoop([c2], 2)
    s2 = gmsh.model.occ.addPlaneSurface([cl2], 2)
    gmsh.model.occ.cut([(2,s2)], [(2,s1)],3,True,False)
    # Boundary Tags
    gmsh.model.addPhysicalGroup(1, [1], 1)
    gmsh.model.addPhysicalGroup(1, [2], 2)
    # Surface Tags
    gmsh.model.addPhysicalGroup(2, [1], tag=1) # Inner Circle Boundary
    gmsh.model.addPhysicalGroup(2, [3], tag=2) # Outer Circle Boundary
    lc = 0.02 # 0.01
    gmsh.option.setNumber("Mesh.MeshSizeMax", lc)
    # gmsh.fltk.run()
mesh, ct,ft = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
gmsh.clear()
gmsh.finalize()
V = FunctionSpace(mesh, ("DG", 1))
dx = Measure('dx', domain=mesh, subdomain_data=ct)
dS = Measure('dS', domain=mesh, subdomain_data=ft)
c = 347
form1 = -c**2 * inner(grad(u), grad(v))*dx
a = 3*1E-3
d = 35*1E-3
U = 5
St = omega*a/U
form2 = -c**2 * K_r/d**2 * inner(jump(u), jump(v))*dS(1)
mass_form = form(form1+form2)
A = assemble_matrix(mass_form)
C = assemble_matrix(stiffnes_form)
C.assemble()
def results(E):
    if MPI.COMM_WORLD.Get_rank()==0:
        print()
        print("******************************")
        print("*** SLEPc Solution Results ***")
        print()
        its = E.getIterationNumber()
        print("Number of iterations of the method: %d" % its)
        eps_type = E.getType()
        print("Solution method: %s" % eps_type)
        nev, ncv, mpd = E.getDimensions()
        print("Number of requested eigenvalues: %d" % nev)
        tol, maxit = E.getTolerances()
        print("Stopping condition: tol=%.4g, maxit=%d" % (tol, maxit))
        nconv = E.getConverged()
        print("Number of converged eigenpairs %d" % nconv)
        A = E.getOperators()[0]
        vr, vi = A.createVecs()
        if nconv > 0:
            print()
            k = E.getEigenpair(i, vr, vi)
            print("%15f, %15f" % (k.real, k.imag))
        print()
def eps_solver(A, C, target, nev, two_sided=False, print_results=False):
    E = SLEPc.EPS().create(MPI.COMM_WORLD)
    C = - C
    E.setOperators(A, C)
    # spectral transformation
    st = E.getST()
    st.setType('sinvert')
    # E.setKrylovSchurPartitions(1) # MPI.COMM_WORLD.Get_size()
    E.setTarget(target)
    E.setWhichEigenpairs(SLEPc.EPS.Which.TARGET_MAGNITUDE)  # TARGET_REAL or TARGET_IMAGINARY
    E.setTwoSided(two_sided)
    E.setDimensions(nev, SLEPc.DECIDE)
    E.setTolerances(1e-15)
    E.setFromOptions()
    E.solve()
    if print_results and MPI.COMM_WORLD.rank == 0:
        results(E)
    return E
target = 400*2*np.pi
nev=10
E = eps_solver(A, C, target**2, nev=nev, print_results= True)
for i in range(nev):
    eig = E.getEigenvalue(i)
    omega = np.sqrt(eig)
    print(omega/(2*np.pi))
I should get the eigenvalues around 380Hz with a negative complex part (around -20j). However, I still get 0 solution vectors and eigenvalues, if I use DG elements. According to post1 and post2, I might need to manipulate my weak form due to the DG elements usage. But I am not sure how to do it. Is there anybody who can help?
Thank you for your responses in advance.
