Implementing dynamic analysis for von-Mises plasticity
I’ve implemented a dynamic analysis for the von-Mises plasticity based on vonMises_Plasticity and Elastodynamics tutorials. The simulation works well in the elastic region but when it enters the plastic region, the residual becomes very large and does not converge in the first increment in the plastic region.
Here are the main functions in this approach. The other necessary functions (integration scheme, etc.) are not changed. I am not sure if I have to consider anything additional for the plasticity.
def eps(v):
    e = sym(grad(v))
    return as_tensor([[e[0, 0], e[0, 1], 0],
                      [e[0, 1], e[1, 1], 0],
                      [0, 0, 0]])
def sigma(eps_el):
    return lmbda*tr(eps_el)*Identity(3) + 2*mu*eps_el
def as_3D_tensor(X):
    return as_tensor([[X[0], X[3], 0],
                      [X[3], X[1], 0],
                      [0, 0, X[2]]])
ppos = lambda x: (x+abs(x))/2.
def proj_sig(deps, old_sig, old_p):
    sig_n = as_3D_tensor(old_sig)
    sig_elas = sig_n + sigma(deps)
    s = dev(sig_elas)
    sig_eq = sqrt(3/2.*inner(s, s))
    f_elas = sig_eq - sig0 - H*old_p
    dp = ppos(f_elas)/(3*mu+H)
    n_elas = s/sig_eq*ppos(f_elas)/f_elas
    beta = 3*mu*dp/sig_eq
    new_sig = sig_elas-beta*s
    return as_vector([new_sig[0, 0], new_sig[1, 1], new_sig[2, 2], new_sig[0, 1]]), \
           as_vector([n_elas[0, 0], n_elas[1, 1], n_elas[2, 2], n_elas[0, 1]]), \
           beta, dp
def sigma_tang(e):
    N_elas = as_3D_tensor(n_elas)
    return sigma(e) - 3*mu*(3*mu/(3*mu+H)-beta)*inner(N_elas, e)*N_elas-2*mu*beta*dev(e)
def m(u, u_):
    return rho*inner(u, u_)*dxm
def k(u, u_):
    return inner(eps(u_), as_3D_tensor(sig))*dxm + inner(eps(u), sigma_tang(eps(u_)))*dxm
def c(u, u_):
    return eta_m*m(u, u_) + eta_k*k(u, u_)
def Wext(u_):
    return loading*dot(n, u_)*ds(4)
res = m(avg(a_old, a_new, alpha_m), u_) + c(avg(v_old, v_new, alpha_f), u_) \
       + k(avg(u_old, v, alpha_f), u_) - Wext(u_)
Below is the load-displacement graph from the vonMises tutorial. The geometry enters plastic region after 0.003
Below is the residual when the displacement is around 0.006 (plastic).
I have tried implementing the same problem using MFront library instead of directly implementing the material law. I still get the same behaviour. That’s why I tried with direct implementation of material law to see where the problem is.
Any suggestion would be highly appreciated. Thanks in advance!
Why do you have both sig and sig_tang in the stiffness term ? It should only be sig.
I have modified the stiffness term and residual as below
def k(u_):
       + k(u_) - Wext(u_)
a_form = inner(eps(v), sigma_tang(eps(u_)))*dxm
L_form = -res
for (i, t) in enumerate(np.diff(time)):
    t = time[i+1]
    loading.t = t-float(alpha_f*dt)
    A, Res = assemble_system(a_form, L_form, bc)
But I get the following error
This is due to using TrialFunction in nonlinear problems right? I changed the TrialFunction to Function and the system cannot be assembled then
Here is the list of function spaces
deg_u = 2
deg_stress = 2
V = VectorFunctionSpace(mesh, "CG", deg_u)
We = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=4, quad_scheme='default')
W = FunctionSpace(mesh, We)
W0e = FiniteElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
W0 = FunctionSpace(mesh, W0e)
sig = Function(W)
sig_old = Function(W)
n_elas = Function(W)
beta = Function(W0)
p = Function(W0, name="Cumulative plastic strain")
u = Function(V, name="Total displacement")
du = Function(V, name="Iteration correction")
Du = Function(V, name="Current increment")
v = TrialFunction(V)
u_ = TestFunction(V)
u_old = Function(V)
v_old = Function(V)
a_old = Function(V)
Should I also update the displacement (avg(u_old, du, alpha_f)) in the sig_tang?
Bleyer wrote a package that can be useful for plasticity. See his 2019 and 2020 papers. I tried the legacy version of the package, but had to switch to its dolfinx version due to incompatibility.
If you don’t mind posting a minimal working code I can try running the bugs myself.
Hello @yschapira,
thank you for the suggestion. I will look into the package.
Here is a MWE with just the necessary functions from the tutorials. The geometry is the same from the vonMises_Plasticity tutorial.
parameters["form_compiler"]["representation"] = 'quadrature'
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("once", QuadratureRepresentationDeprecationWarning)
E = Constant(70e3)
nu = Constant(0.3)
lmbda = E*nu/(1+nu)/(1-2*nu)
mu = E/2./(1+nu)
sig0 = Constant(250.)  # yield strength
Et = E/100.  # tangent modulus
H = E*Et/(E-Et)  # hardening modulus
Re, Ri = 1.3, 1.   # external/internal radius
mesh = Mesh("thick_cylinder.xml")
facets = MeshFunction("size_t", mesh, "thick_cylinder_facet_region.xml")
ds = ds(subdomain_data=facets)
deg_u = 2
deg_stress = 2
sig = Function(W)
beta = Function(W0)
u_old = Function(V)
v_old = Function(V)
a_old = Function(V)
bc = [DirichletBC(V.sub(1), 0, facets, 1), DirichletBC(V.sub(0), 0, facets, 3), DirichletBC(V, Constant((0., 0.)), facets, 2)]
rho = Constant(3000.e-6)
eta_m = Constant(0.)
eta_k = Constant(0.)
alpha_m = Constant(0.2)
alpha_f = Constant(0.4)
gamma   = Constant(0.5+alpha_f-alpha_m)
beta_ga = Constant((gamma+0.5)**2/4.)
T       = 0.01
Nsteps  = 100
dt = Constant(T/Nsteps)
cutoff_Tc = 2e-3
p0 = 200.
q_lim = float(2/sqrt(3)*ln(Re/Ri)*sig0)*1.2
loading = Expression("-p*tanh(10*t/tc)", p=p0, tc=cutoff_Tc, t=0, degree=2)
def eps(v):
    e = sym(grad(v))
                      [0, 0, 0]])
def sigma(eps_el):
                      [X[3], X[1], 0],
                      [0, 0, X[2]]])
    s = dev(sig_elas)
           beta, dp
def sigma_tang(e):
metadata = {"quadrature_degree": deg_stress, "quadrature_scheme": "default"}
dxm = dx(metadata=metadata)
def m(u, u_):
def k(u_):
def c(u, u_):
    return eta_m*m(u, u_) + eta_k*k(u_)
def Wext(u_):
def update_a(u, u_old, v_old, a_old, ufl=True):
    if ufl:
        dt_ = dt
        beta_ = beta_ga
        dt_ = float(dt)
        beta_ = float(beta_ga)
    return (u-u_old-dt_*v_old)/beta_/dt_**2 - (1-2*beta_)/2/beta_*a_old
def update_v(a, u_old, v_old, a_old, ufl=True):
    if ufl:
        dt_ = dt
        gamma_ = gamma
        dt_ = float(dt)
        gamma_ = float(gamma)
    return v_old + dt_*((1-gamma_)*a_old + gamma_*a)
def update_fields(u, u_old, v_old, a_old):
    u_vec, u0_vec  = u.vector(), u_old.vector()
    v0_vec, a0_vec = v_old.vector(), a_old.vector()
    a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec, ufl=False)
    v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec, ufl=False)
    v_old.vector()[:], a_old.vector()[:] = v_vec, a_vec
    u_old.vector()[:] = u.vector()
def avg(x_old, x_new, alpha):
    return alpha*x_old + (1-alpha)*x_new
a_new = update_a(v, u_old, v_old, a_old, ufl=True)
v_new = update_v(a_new, u_old, v_old, a_old, ufl=True)
       + k(u_) - Wext(u_) + inner(eps(v), sigma_tang(eps(u_)))*dxm
a_form = lhs(res)
L_form = rhs(res)
    dv = TrialFunction(V)
    v_ = TestFunction(V)
    a_proj = inner(dv, v_)*dxm
    b_proj = inner(v, v_)*dxm
    solver.factorize()
    if u is None:
        solver.solve_local_rhs(u)
        return u
        return
u_tip = np.zeros((Nsteps+1, 3))
file_results = XDMFFile("plasticity_results.xdmf")
P0 = FunctionSpace(mesh, "DG", 0)
p_avg = Function(P0, name="Plastic strain")
time = np.linspace(0, T, Nsteps+1)
Nitermax, tol = 200, 1e-7  # parameters of the Newton-Raphson procedure
results = np.zeros((Nsteps+1, 2))
    t = time[i+1]
    print("Time: ", t)
    nRes0 = Res.norm("l2")
    nRes = nRes0
    Du.interpolate(Constant((0, 0)))
    print("Increment:", str(i+1))
    niter = 0
    while nRes/nRes0 > tol and niter < Nitermax and nRes > 1e-8:
        solve(A, du.vector(), Res, "mumps")
        Du.assign(Du+du)
        deps = eps(Du)
        sig_, n_elas_, beta_, dp_ = proj_sig(deps, sig_old, p)
        local_project(sig_, W, sig)
        local_project(n_elas_, W, n_elas)
        local_project(beta_, W0, beta)
        nRes = Res.norm("l2")
        print("    Residual:", nRes, "niter:", niter)
        niter += 1
    u.assign(u+Du)
    p.assign(p+local_project(dp_, W0))
    sig_old.assign(sig)
    file_results.write(u, t)
    p_avg.assign(project(p, P0))
    file_results.write(p_avg, t)
    p.t = t
    if MPI.comm_world.size == 1:
        u_tip[i+1, 0] = u(Ri, 0)[0]
    plt.figure()
    plt.plot(time, u_tip[:, 0])
    plt.xlabel("Time")
    plt.ylabel("Tip displacement_0")
The code would give some results but I am not sure if it’s correct. I am a bit skeptical about the residual as well. Hope that helps!
Hello @Jeremy_Bleyer, I tried comparing the results from fenics with Abaqus but I am not able to get the small oscillations as observed in the Abaqus result.
Abaqus plot:
Fenics plot:
I reduced the time increment but still was not able to get the oscillations. There is no damping in fenics and in Abaqus I have not changed the default settings.
Could you please let me know how I can resolve this?
