Working with different subdomains: from meshio to dolfin
Hi all,
I’m trying to understand the correct workflow for meshing in fenics, starting from a .msh file and arriving to a working Measure in fenics. In particular, I’m working on this example: my geometry consists of a disk with a hole at the center (poorly speaking, a 2D donut). I created this geometry in gmsh writing the following .geo script:
SetFactory("OpenCASCADE");
Circle(1) = {0.5, 0.5, 0.5, 0.1, 0, 2*Pi};
Circle(2) = {0.5, 0.5, 0.5, 1, 0, 2*Pi};
Curve Loop(1) = {2};
Curve Loop(2) = {1};
Plane Surface(1) = {1, 2};
Physical Surface("omega") = {1};
Physical Curve("gamma") = {1};
Physical Curve("epsilon") = {2};
I labeled the surface of the geometry with omega, while the inner and outer circles with gamma and epsilon, respectively.
Then, I obtained the .msh file by using the 2D and the Refine by splitting commands (refined two times) in the gmsh gui.
In order to read the mesh and import it in FEniCS, I’ve written the following Python script:
msh = meshio.read("donut-2d.msh")
    if key == "line":
        line_data = msh.cell_data_dict["gmsh:physical"][key]
    if key == "triangle":
for cell in msh.cells:
    if cell.type == "line":
        line_cells = cell.data
    if cell.type == "triangle":
        triangle_cells = cell.data
line_mesh = meshio.Mesh(points=msh.points,
        cells=[("line", line_cells)],
        cell_data={"name_to_read":[line_data]})
triangle_mesh = meshio.Mesh(points=msh.points,
meshio.write("boundary.xdmf", line_mesh)
meshio.write("surface.xdmf", triangle_mesh)
mesh = Mesh()
with XDMFFile("surface.xdmf") as infile:
    infile.read(mesh)
mvc_1d = MeshValueCollection("size_t", mesh, 1)
with XDMFFile("boundary.xdmf") as infile:
    infile.read(mvc_1d, "name_to_read")
mf_1d = cpp.mesh.MeshFunctionSizet(mesh, mvc_1d)
mvc_2d = MeshValueCollection("size_t", mesh, 2)
    infile.read(mvc_2d, "name_to_read")
mf_2d = cpp.mesh.MeshFunctionSizet(mesh, mvc_2d)
ds = Measure("ds", domain=mesh, subdomain_data=mf_1d)
dx = Measure("dx", domain=mesh, subdomain_data=mf_2d)
print("")
print("omega area: ", assemble(Constant(1)*dx))
print("gamma + epsilon length: ", assemble(Constant(1)*ds))
print("gamma length: ", assemble(Constant(1)*ds(2)))
print("epsilon length: ", assemble(Constant(1)*ds(3)))
The last lines give me the following outputs:
omega area:  3.1097676855865237
gamma + epsilon length:  6.910189733699893
gamma length:  1.0926747887983828
epsilon length:  5.190205246792324
Reading other posts, I interpreted the quantities within the print function as the integrals over the different measures (is it right?). As you can see, the integral over dx and ds are similar to the theoretical values, while this is not true for ds(2) and ds(3).
So I think I’m quite out of the way, and I’m not working correctly. What I want to do in dolfin is to integrate some terms over gamma and some other terms over epsilon in my weak formulation. Additionally, I could want to use one of these curves for boundary conditions.
So my question is: what is the correct way of passing and/or calling two different (one-dimensional in this case) subdomains from meshio to dolfin?
I’m aware that very probably I’ve misunderstood the meaning of some variables, and I have to admit that I’ve made a sort of “leap of faith” writing this script, since I do not get what kind of operations are done with meshio in the code above, so I’ve just put together what I learned from the posts in this group, but probably this was not enough.
Thank you in advance for your precious help.
Please mark the Physical Surface and Curve with numbers, not strings. As you can observe by inspecting the boundary.xdmf file the values on each boundary is not 1 and 2, but 2 and 3, and does not consist of the whole circle.
This is because you are converting all the data written in with meshio.
See for instance: Transitioning from mesh.xml to mesh.xdmf, from dolfin-convert to meshio - #104 by dokken
or Mesh generation and conversion with GMSH and PYGMSH | Jørgen S. Dokken
for how to convert a meshio mesh and corresponding boundary data in a safe way.
Thank you very much @dokken, with your advice I was able to get the correct results. Just for clarity, if anyone is interested, I’m posting the .geo and the .py corrected versions below. I have two last questions, one is about this statement:
What does it mean? What is the command that has changed from the previous to the final version?
The other question regards the "name_to_read" string that appears, for example, within meshio.Mesh() . Is it an arbitrary string or do we need to use this specific string?
Thank you very much again.
As promised, .geo file:
Physical Curve(1) = {1};
Physical Curve(2) = {2};
Physical Surface(3) = {1};
and .py file:
cells = np.vstack(np.array([cells.data for cells in msh.cells
                            if cells.type=="triangle"]))
                            cells=[("triangle", cells)])
facet_cells = np.vstack(np.array([cells.data for cells in msh.cells
                                  if cells.type=="line"]))
facet_data = msh.cell_data_dict["gmsh:physical"]["line"]
facet_mesh = meshio.Mesh(points=msh.points,
                         cells=[("line", facet_cells)],
                         cell_data={"name_to_read": [facet_data]})
meshio.write("boundaries.xdmf", facet_mesh)
mesh = Mesh()
    infile.read(mesh)
with XDMFFile("boundaries.xdmf") as infile:
print("")
print("gamma length: ", assemble(Constant(1)*ds(1)))
print("epsilon length: ", assemble(Constant(1)*ds(2)))
I’ve not tested the old code for a while now, so I would suggest you sit down and compare the inputs you are giving the meshio meshes.
You can use any string, as long as you are consistent with using the same string when reading in the mesh data.
I’d like to have an advice for gmsh. I think that it is not necessary to open another topic, so I’m writing here.
I’m trying to create a spherical shell in gmsh, with a mesh that is denser near the inner boundary of the shell.
For this purpose, I wrote the following .geo file, and then I executed the 3D command in the gmsh gui for generating the 3D mesh, that is then saved in a .msh file:
Sphere(1) = {0, 0, 0, 0.1, -Pi/2, Pi/2, 2*Pi};
Sphere(2) = {0, 0, 0, 0.12, -Pi/2, Pi/2, 2*Pi};
Sphere(3) = {0, 0, 0, 0.4, -Pi/2, Pi/2, 2*Pi};
BooleanDifference(4) = { Volume{3};  Delete;}{ Volume{2};  };
BooleanDifference(5) = { Volume{2};  Delete;}{ Volume{1}; Delete; };
BooleanFragments{ Volume{5}; Volume{4}; Delete; }{ }
Characteristic Length{ PointsOf{ Volume{4}; } } = 0.04;
Characteristic Length{ PointsOf{ Volume{5}; } } = 0.005;
Physical Surface(1) = {4};
Physical Surface(2) = {3};
Physical Volume(3) = {4, 5};
I used the second sphere to create a dummy volume for imposing a denser mesh step. The generated mesh seems visually good to me:
In order to see if everything works correctly in FEniCS, I first check the volume and surface integral of the spherical shell, of the inner boundary and of the outer boundary respectively, with the following .py script:
def msh_to_mf(dirname):
    msh = meshio.read(dirname + "spherical-shell-3d.msh")
                                if cells.type=="tetra"]))
    tetra_mesh = meshio.Mesh(points=msh.points,
                                cells=[("tetra", cells)])
    facet_data = msh.cell_data_dict["gmsh:physical"]["triangle"]
                             cells=[("triangle", facet_cells)],
    meshio.write(dirname + "boundaries.xdmf", facet_mesh)
    meshio.write(dirname + "volume.xdmf", tetra_mesh)
    parameters["ghost_mode"] = "shared_vertex"
    mesh = Mesh()
    with XDMFFile(dirname + "volume.xdmf") as infile:
        infile.read(mesh)
    with XDMFFile(dirname + "boundaries.xdmf") as infile:
    mvc_3d = MeshValueCollection("size_t", mesh, 3)
    mf_3d = cpp.mesh.MeshFunctionSizet(mesh, mvc_3d)
    return mesh, mf_2d, mf_3d
mesh, mf_2d, mf_3d = msh_to_mf("./")
ds = Measure("ds", domain=mesh, subdomain_data=mf_2d)
dx = Measure("dx", domain=mesh, subdomain_data=mf_3d)
print(assemble(Constant(1)*dx))
print(assemble(Constant(1)*ds))
print(assemble(Constant(1)*ds(1)))
print(assemble(Constant(1)*ds(2)))
print(assemble(Constant(1)*ds(3)))
The integral seems to be also correct.
I’d like to know if there is a simpler and "fenics-friendly" way to write the .geo file, since, even if it seems to be correct, I’m afraid that when I’m going to run the simulation there will be some errors arising due to the cumbersomeness of the .geo file.
Hi guys,
I’m sorry to ask again for an help in importing a mesh from gmsh to fenics, but everytime I change the geometry I get something strange, therefore I think I haven’t get yet what I do wrong in my .geo scripts.
I’m trying to create a geometry that is made of: 1) an inner sphere, 2) a spherical shell that hold the inner sphere, and 3) an outer spherical shell that hold both the inner shell and sphere. All these elements are concentric. In order to do so, I created the following .geo file:
Sphere(1) = {0, 0, 0, 0.020, -Pi/2, Pi/2, 2*Pi};
Sphere(2) = {0, 0, 0, 0.025, -Pi/2, Pi/2, 2*Pi};
BooleanDifference(5) = { Volume{2};  Delete;}{ Volume{1};  };
Characteristic Length{ PointsOf{ Volume{4}; } } = 0.08;
Characteristic Length{ PointsOf{ Volume{5}; } } = 0.008;
Characteristic Length{ PointsOf{ Volume{1}; } } = 0.01;
Physical Volume(1) = {1, 5};
Physical Volume(2) = {4};
Physical Surface(3) = {2};
Physical Surface(4) = {3};
I create the shells by means of the BooleanDifference operation, and then I assign a single PhysicalVolume to the inner shell and sphere, and another PhysicalVolume to the outer shell. Then I also assign a PhysicalSurface to the spherical surface with radius 0.025, and another PhysicalSurface to the outer shell surface. The mesh is then created by using the 3D command in gmsh
In order to check if everything is correct, I calculate the integral over these PhysicalVolume and PhysicalSurface with the following script:
def msh_to_mf():
    msh = meshio.read("mwe_mesh.msh")
                                if cells.type=="tetra"],
                                dtype='object'))
    cells_mesh = meshio.Mesh(points=msh.points,
    tetra_cells = np.vstack(np.array([cells.data for cells in msh.cells
                                      dtype='object'))
    tetra_data = msh.cell_data_dict["gmsh:physical"]["tetra"]
                                cells=[("tetra", tetra_cells)],
                                cell_data={"name_to_read": [tetra_data]})
                                      if cells.type=="triangle"],
                                      dtype='object'))
    meshio.write("total.xdmf", cells_mesh)
    meshio.write("volume.xdmf", tetra_mesh)
    mesh = Mesh()
    with XDMFFile("total.xdmf") as infile:
        infile.read(mesh)
    with XDMFFile("volume.xdmf") as infile:
        infile.read(mvc_3d, "name_to_read")
mesh, mf_2d, mf_3d = msh_to_mf()
print()
print("dx --- fenics value: ", assemble(Constant(1)*dx), " theoretical value: 0.26808")
print("dx(1) --- fenics value: ", assemble(Constant(1)*dx(1))," theoretical value: 6.5453-05")
print("dx(2) --- fenics value: ", assemble(Constant(1)*dx(2)), " theoretical value: 0.268")
print("ds --- fenics value: ", assemble(Constant(1)*ds), " theoretical value: 2.019")
print("ds(1) --- fenics value: ", assemble(Constant(1)*ds(1)), " theoretical value: 0.00754")
print("ds(2) --- fenics value: ", assemble(Constant(1)*ds(2)), " theoretical value: 2.01061")
print("ds(3) --- fenics value: ", assemble(Constant(1)*ds(3)), " theoretical value: 0")
print("ds(4) --- fenics value: ", assemble(Constant(1)*ds(4)), " theoretical value: 0")
What I get is:
dx --- fenics value:  0.2655310362597119  theoretical value: 0.26808
dx(1) --- fenics value:  6.540664246719124e-05  theoretical value: 6.5453-05
dx(2) --- fenics value:  0.26546562961725145  theoretical value: 0.268
ds --- fenics value:  2.0001411091917602  theoretical value: 2.019
ds(1) --- fenics value:  0.0  theoretical value: 0.00754
ds(2) --- fenics value:  0.0  theoretical value: 2.01061
ds(3) --- fenics value:  0.0  theoretical value: 0
ds(4) --- fenics value:  2.0001411091917602  theoretical value: 0
The volume values are okay, while the surface values are not… What am I doing wrong with the surfaces? I’m not able to get it yet.
Thank you.
I would suggest that you visually inspect your mesh using Paraview (which can open the xdmf files that you have produced). There you clearly see that you only have two surfaces in boundaries.xdmf, and that you have one outer boundary (with marker 4).
I do not understand why you claim that ds(2) should be 2.01061, as you have not created a Physical Surface with tag 2 in your mesh.
To obtain the integral over the interior sphere, you need to use the dS measure,
dS_c = Measure("dS",domain=mesh, subdomain_data=mf_2d)
Thank you so much @dokken. I added the line assemble(Constant(1)*dS_c(3)) and I obtain the correct value for the inner sphere surface. But I’ve never seen this "dS"… What is the difference with "ds"? When should I use one instead of the other? Is there any reference about that?
Anyway, just to have everything clear, for the outer surface I should use:
While for the inner sphere surface I should use:
Is it right?
PS. to answer to your question:
I thought that the numbering in dolfin was not following the physical tags (in my case 1,2,3,4) but instead I thought it did a custom numbering, starting from 1 for every different kind of physical entities (so in my case 1,2 for the volumes and 1,2 for the surfaces, I added ds(3) and ds(4) since I imagined that this was not correct, but it didn’t add up with the fact that for ds(3) I was having a 0 integral value). Probably I made some confusion with some examples I’ve seen from the previous versions of dolfin.
dS is the integration measure over interior facets, see for instance: Integrating over an interior surface - #2 by MiroK
while ds is the integration measure over exterior facets.
Dolfin follows your physical tags (as they are read in from XDMFFile, which you can visualize in Paraview).
Does this hold only for surface facet or also for line facet/2D problem? For example, if I have a sort of donut (a small circle and another concentric bigger circle), should I indicate the inner/smaller circular line with dS and the outer/bigger one with ds? I’m asking since I did some 2D simulations without being aware of dS, and nevertheless everything seemed to be fine.
Thank you again, as always.
An interior facet is a facet that has more than one cell attached to it. Whenever you have a cell on both sides of your facet, you need to use dS
