I had a code working fine on version 0.5.0 which stopped to work in the new release 0.6.0, and I cannot find the problem. The subdomains are well defined.
The error:
File "/home/marcel/KCMmodel/FourierIso.py", line 238, in <module>
problem = LinearProblem(a, L, bcs=bc, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
File "/home/marcel/spack/var/spack/environments/fenicsx-env/.spack-env/view/lib/python3.10/site-packages/dolfinx/fem/petsc.py", line 566, in __init__
self._a = _create_form(a, form_compiler_options=form_compiler_options, jit_options=jit_options)
File "/home/marcel/spack/var/spack/environments/fenicsx-env/.spack-env/view/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 176, in form
return _create_form(form)
File "/home/marcel/spack/var/spack/environments/fenicsx-env/.spack-env/view/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 171, in _create_form
return _form(form)
File "/home/marcel/spack/var/spack/environments/fenicsx-env/.spack-env/view/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 138, in _form
assert all([id(d) == id(data[0]) for d in data])
AssertionError
The code:
from dolfinx import fem, mesh, plot
import sys
import argparse
#import system parameters
side = 40.0 #xy size
height = 100.0 #z size
dL = 10 #xy general resolution
dH = 5 #z layer resolution
substrate_res = 20 #z substrate resolution
thickness = [0.06] #Thickness of each layer
c=[2.49*1e-12,2.98*1e-12] #Specific heat c in J/(um)3K
k=[66*1e-6,33*1e-6] #isotropic conductivity in J/(um)2K
tbc = [5e-5] #Thermal boundary conductance of each interface (same order)
pen_depth = 0.012
rpump = 5.0 #Pump beam radius
rprobe = 5.0 #Probe beam radius
beamoffset = 0.0 #Offset between paump and probe beam center
bumppar = -5 #Parameter to increase the resolution in the center
progressionpar = 1.2 #Parameter to increase the resolution close to the surface (1.1-1.3 probably works)
#calculate interface z-coordinates
interfaces = np.cumsum(np.array(thickness))
interfaces = np.append(interfaces,height)
#The frequency "omega" comes from the parameter
parser = argparse.ArgumentParser(description='Calculate phase shift.')
parser.add_argument('freq', type=float, nargs=1,
help='Frequency in Hz')
args = parser.parse_args()
omega = 2*np.pi*args.freq[0]
proc = MPI.COMM_WORLD.rank #For MPI control
# create the mesh
if proc == 0:
gmsh.option.setNumber("General.Terminal",0)
gmsh.model.add("Model")
lc = 10 #point resolution - not really used
gmsh.model.geo.addPoint(0, 0, 0, lc, 1) #layer 1 points
gmsh.model.geo.addPoint(side, 0, 0, lc, 2)
gmsh.model.geo.addPoint(side, side, 0, lc, 3)
gmsh.model.geo.addPoint(0, side, 0, lc, 4)
gmsh.model.geo.addLine(1, 2, 1) #border layer 1
gmsh.model.geo.mesh.setTransfiniteCurve(1, dL, "Bump", bumppar)
gmsh.model.geo.addLine(2, 3, 2)
gmsh.model.geo.mesh.setTransfiniteCurve(2, dL, "Bump", bumppar)
gmsh.model.geo.addLine(3, 4, 3)
gmsh.model.geo.mesh.setTransfiniteCurve(3, dL, "Bump", bumppar)
gmsh.model.geo.addLine(4, 1, 4)
gmsh.model.geo.mesh.setTransfiniteCurve(4, dL, "Bump", bumppar)
gmsh.model.geo.addCurveLoop([-1, -2, -3, -4], 1)
gmsh.model.geo.addPlaneSurface([1], 1) #1st surface
gmsh.model.geo.mesh.setTransfiniteSurface(1)
gmsh.model.geo.synchronize()
leftwall_list = []
rightwall_list = []
frontwall_list = []
backwall_list = []
interfaces_index = []
for count, i_height in enumerate(interfaces):
gmsh.model.geo.addPoint(0, 0, i_height, lc, 5+4*count)
gmsh.model.geo.addPoint(side, 0, i_height, lc, 6+4*count)
gmsh.model.geo.addPoint(side, side, i_height, lc, 7+4*count)
gmsh.model.geo.addPoint(0, side, i_height, lc, 8+4*count)
gmsh.model.geo.addLine(5+4*count, 6+4*count, 5+8*count)
gmsh.model.geo.mesh.setTransfiniteCurve(5+8*count, dL, "Bump", bumppar)
gmsh.model.geo.addLine(6+4*count, 7+4*count, 6+8*count)
gmsh.model.geo.mesh.setTransfiniteCurve(6+8*count, dL, "Bump", bumppar)
gmsh.model.geo.addLine(7+4*count, 8+4*count, 7+8*count)
gmsh.model.geo.mesh.setTransfiniteCurve(7+8*count, dL, "Bump", bumppar)
gmsh.model.geo.addLine(8+4*count, 5+4*count, 8+8*count)
gmsh.model.geo.mesh.setTransfiniteCurve(8+8*count, dL, "Bump", bumppar)
gmsh.model.geo.addCurveLoop([(5+8*count), (6+8*count), (7+8*count), (8+8*count)], 2+5*count) #top surface edge loops
if count == len(interfaces)-1:
gmsh.model.geo.addLine(1+4*count, 5+4*count, 9+8*count)
gmsh.model.geo.mesh.setTransfiniteCurve(9+8*count, substrate_res, "Progression", progressionpar)
gmsh.model.geo.addLine(2+4*count, 6+4*count, 10+8*count)
gmsh.model.geo.mesh.setTransfiniteCurve(10+8*count, substrate_res, "Progression", progressionpar)
gmsh.model.geo.addLine(3+4*count, 7+4*count, 11+8*count)
gmsh.model.geo.mesh.setTransfiniteCurve(11+8*count, substrate_res, "Progression", progressionpar)
gmsh.model.geo.addLine(4+4*count, 8+4*count, 12+8*count)
gmsh.model.geo.mesh.setTransfiniteCurve(12+8*count, substrate_res, "Progression", progressionpar)
gmsh.model.geo.mesh.setTransfiniteCurve(9+8*count, dH)
gmsh.model.geo.mesh.setTransfiniteCurve(10+8*count, dH)
gmsh.model.geo.mesh.setTransfiniteCurve(11+8*count, dH)
gmsh.model.geo.mesh.setTransfiniteCurve(12+8*count, dH)
if count == 0:
gmsh.model.geo.addCurveLoop([1, 10, -5, -9], 3)
gmsh.model.geo.addCurveLoop([2, 11, -6, -10], 4)
gmsh.model.geo.addCurveLoop([3, 12, -7, -11], 5)
gmsh.model.geo.addCurveLoop([4, 9, -8, -12], 6)
gmsh.model.geo.addCurveLoop([(8*count-3), (10+8*count), -(5+8*count), -(9+8*count)], 3+5*count)
gmsh.model.geo.addCurveLoop([(8*count-2), (11+8*count), -(6+8*count), -(10+8*count)], 4+5*count)
gmsh.model.geo.addCurveLoop([(8*count-1), (12+8*count), -(7+8*count), -(11+8*count)], 5+5*count)
gmsh.model.geo.addCurveLoop([(8*count), (9+8*count), -(8+8*count), -(12+8*count)], 6+5*count)
gmsh.model.geo.addPlaneSurface([2+5*count], 6+5*count) #top surface is the last
gmsh.model.geo.mesh.setTransfiniteSurface(6+5*count)
gmsh.model.geo.addPlaneSurface([3+5*count], 3+5*count)
gmsh.model.geo.mesh.setTransfiniteSurface(3+5*count)
gmsh.model.geo.addPlaneSurface([4+5*count], 4+5*count)
gmsh.model.geo.mesh.setTransfiniteSurface(4+5*count)
gmsh.model.geo.addPlaneSurface([5+5*count], 5+5*count)
gmsh.model.geo.mesh.setTransfiniteSurface(5+5*count)
gmsh.model.geo.addPlaneSurface([6+5*count], 2+5*count)
gmsh.model.geo.mesh.setTransfiniteSurface(2+5*count)
lastsurface = 6+5*count #keep track of last surface
interfaces_index.append(6+5*count)
frontwall_list.append(3+5*count)
rightwall_list.append(4+5*count)
backwall_list.append(5+5*count)
leftwall_list.append(2+5*count)
#create layer volume
gmsh.model.geo.addSurfaceLoop([1+5*count, 2+5*count, 3+5*count, 4+5*count, 5+5*count, 6+5*count])
gmsh.model.geo.addVolume([1+count], 1+count)
gmsh.model.geo.mesh.setTransfiniteVolume(1+count)
gmsh.model.addPhysicalGroup(3, [1+count], 1+count)
interfaces_index.pop(-1)
gmsh.model.addPhysicalGroup(2, [lastsurface], 2)
gmsh.model.addPhysicalGroup(2, [1], 1)
gmsh.model.addPhysicalGroup(2, frontwall_list, 3)
gmsh.model.addPhysicalGroup(2, rightwall_list, 4)
gmsh.model.addPhysicalGroup(2, backwall_list, 5)
gmsh.model.addPhysicalGroup(2, leftwall_list, 6)
for n, i in enumerate(interfaces_index):
gmsh.model.addPhysicalGroup(2, [i], 7+n)
#gmsh.option.setNumber("Mesh.RecombineAll", 1)
gmsh.model.mesh.generate(3)
gmsh.option.setNumber("Mesh.SaveAll", 0)
gmsh.write("tempmesh.msh")
#if '-nopopup' not in sys.argv:
#gmsh.fltk.run()
gmsh.finalize()
#read the mesh file
from dolfinx.io.gmshio import read_from_msh
model_rank = 0
domain, cell_tags, facet_tags = read_from_msh("tempmesh.msh", MPI.COMM_WORLD, model_rank, gdim=3)
#Create function space
V = fem.FunctionSpace(domain, ("DG", 1)) #Scalar field works for Fourier
x = ufl.SpatialCoordinate(domain) #spatial coordinates
#define the heat flux at the surface and the volumetric heating
f = 2e-6*((ufl.exp(-x[2]/pen_depth))) * x[0] * (x[0]-side) * x[1] * (x[1]-side) * (2 / (np.pi * rpump * rpump) ) * ufl.exp( - 2 * ((x[0]-side/2.0)**2 + (x[1]-side/2.0)**2) / (rpump * rpump ))
#Variatinol problem
u = ufl.TrialFunction(V)
#Find boundary points
def boundary_one(x):
return np.logical_or(np.isclose(x[0], 0), np.isclose(x[0],side))
def boundary_two(x):
return np.logical_or(np.isclose(x[1], 0), np.isclose(x[1],side))
def boundary_three(x):
return np.isclose(x[2], height)
#define dirichlet boundary conditions
u_D = fem.Function(V, dtype=np.complex128)
u_D.interpolate(lambda x: 0.0 + 0.0j + x[0]*0 + x[1]*0 + x[2]*0)
bc = []
dofs_D = fem.locate_dofs_geometrical(V, boundary_one)
bc.append(fem.dirichletbc(u_D, dofs_D))
dofs_D = fem.locate_dofs_geometrical(V, boundary_two)
dofs_D = fem.locate_dofs_geometrical(V, boundary_three)
#Create functions for k and c in the space
Q = fem.FunctionSpace(domain, ("DG", 0))
kappa = fem.Function(Q)
heatcap = fem.Function(Q)
for layer in range(0,len(interfaces)):
foundcells = cell_tags.find(layer+1)
kappa.x.array[foundcells] = np.full_like(foundcells, k[layer], dtype=ScalarType)
heatcap.x.array[foundcells] = np.full_like(foundcells, c[layer], dtype=ScalarType)
#tag surface for selective integration
ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags)
dS = ufl.Measure("dS", domain=domain, subdomain_data=facet_tags)
mu = 1 #this is the internal penalty parameter, 1e-2 works well so far
n = ufl.FacetNormal(domain) #normal of each surface
#Fourier problem using SIPM, as 10.1016/j.cam.2006.08.029
a = ( kappa*ufl.inner(ufl.grad(u), ufl.grad(v)) + 1j* omega * heatcap * ufl.inner(u,v) ) * ufl.dx \
- ufl.conj(ufl.inner(ufl.avg(kappa*ufl.grad(v)),ufl.jump(u,n))) * ufl.dS \
- ufl.inner(ufl.avg(kappa*ufl.grad(u)),ufl.jump(v,n))*ufl.dS \
+ mu*ufl.inner(ufl.jump(u),ufl.jump(v)) * ufl.dS
#For each interface is necessary to remove general interface conditions and add the interface boundary conductivity
for i, h in enumerate(tbc):
a -= mu*ufl.inner(ufl.jump(u),ufl.jump(v))*dS(7+i)
a += ufl.inner(ufl.jump(u,n)*h,ufl.jump(v,n))*dS(7+i)
a += ufl.conj(ufl.inner(ufl.avg(kappa*ufl.grad(v)),ufl.jump(u,n)))*dS(7+i)
a += ufl.inner(ufl.avg(kappa*ufl.grad(u)),ufl.jump(v,n))*dS(7+i)
L = + ufl.inner(f, v) * ufl.dx
uh = problem.solve()
#Export results to a file
import dolfinx.io
uh.name = "Temperature"
kappa.name = "k"
heatcap.name = "c"
with dolfinx.io.XDMFFile(domain.comm, "outputfourier.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
xdmf.write_function(uh)
xdmf.write_function(kappa)
xdmf.write_function(heatcap)
