How to get the area of a hemi sphere
Hello, I am trying to build a hemi sphere and calculate the area by following the tutorial Integration measures, but the code does not give the correct result. Here is my code.
import dolfinx, ufl
R = 1.0
grid_size = 0.2
order = 2
gmsh.model.add("hemi_sphere")
sphere = gmsh.model.occ.add_sphere(0.0, 0.0, 0.0, R)
box = gmsh.model.occ.add_box(-R-0.1, -R-0.1, 0, 2*R+0.1, 2*R+0.1, R+0.1)
result = gmsh.model.occ.intersect([(3, sphere)], [(3, box)])
gmsh.model.occ.synchronize()
surfaces = gmsh.model.getEntities(dim=2)
for surface in surfaces:
    com = gmsh.model.occ.getCenterOfMass(surface[0], surface[1])
    if np.allclose(com, [0, 0, 0]):
        plane = surface
        gmsh.model.addPhysicalGroup(surface[0], [surface[1]], 10, "circle")
    elif np.allclose(com, [0.0, 0.0, R*0.5]):
        hemi_sphere = surface
        gmsh.model.addPhysicalGroup(surface[0], [surface[1]], 20, "hemi_sphere")
# plane should be used here. There is an extra curve in hemi_sphere
boundary = gmsh.model.getBoundary([(plane[0], plane[1])])
gmsh.model.addPhysicalGroup(1, [b[1] for b in boundary], 1, "boundary")
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", grid_size)
gmsh.model.mesh.generate(2)
gmsh.model.mesh.setOrder(order)
mesh, cell_marker, facet_marker = dolfinx.io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=2)
gmsh.finalize()
dx = ufl.Measure("dx", domain=mesh, subdomain_data=cell_marker)
area = 1 * dx(20)
compiled_area = dolfinx.fem.form(area)
local_area = dolfinx.fem.assemble_scalar(compiled_area)
global_area = mesh.comm.allreduce(local_area, op=MPI.SUM)
print(global_area)
If I integrate 1*dx(20), the result should be close to 2\pi, but the result is 3.14, it is uncorrect. If I integrate 1*dx, it is 6.28, but it should be 3\pi.
Does anyone have some idea ? Thanks.
Here you are setting the geometrical dimension to two, but it should be 3, as you are making a 2D manifold embedded in 3D space, i.e.
model = dolfinx.io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=3)
which gives the correct area.
Please note that this is super easy to debug, if you had written the mesh to file with:
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "hemi_sphere.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_meshtags(cell_marker, mesh.geometry)
and looked at the output in paraview, as it would be:
Thanks for your help, may I ask another question ? I’m trying to calculate the integral of vector field curl on the hemi sphere. But my code produces the error:
ValueError: Cannot determine geometric dimension from expression.
The code to generate the hemi-sphere is same as above, here is the code that calculates the integral of curl.
F = ufl.as_vector([-x[1], x[0], 0.0])
cell_normal_vector = ufl.CellNormal(mesh)
# this line causes error.
form = dolfinx.fem.form(ufl.dot(ufl.curl(F), cell_normal_vector) * dx(20))
If you change your code
to:
zero = dolfinx.fem.Constant(mesh, dolfinx.default_scalar_type(0.0))
F = ufl.as_vector([-x[1], x[0], zero])
it will run.
The problem is doing curl of 0., as it is not associated with a the mesh.
Sorry to bother you again, but how should I calculate the integral of vector \vec{F} along the boundary ? (I am trying to verify Stokes theorem) Is there any function like FacetNormal or CellNormal to get the unit vector along the boundary? Thanks.
As you are working on a manifold, do you mean the boundary of each cell (a line), and thus you would like to know the tangent t\in \mathbb{R}^3 which is perpendicular to n=FacetNormal(mesh)?
You could try using : CellEdgeVectors: ufl package — Unified Form Language (UFL) 2021.1.0 documentation
Maybe not? I want the unit vectors along the boundary as the figures shows
I tried CellEdgeVectors, it does not work
# The line integral of F on the boundary ?
ds = ufl.Measure("ds", subdomain_data=facet_marker)
cell_edge_vector = ufl.classes.CellEdgeVectors(mesh)
form = dolfinx.fem.assemble_scalar(ufl.dot(cell_edge_vector, F) * ds )
The code produces the errors:
  File "/mnt/e/workdir/FEM/fenics/bb2.py", line 48, in <module>
    form = dolfinx.fem.assemble_scalar(ufl.dot(cell_edge_vector, F) * ufl.ds )
  File "/mnt/d/software_install/fenics-0.9/lib/python3.13/site-packages/ufl/measure.py", line 382, in __rmul__
    raise ValueError(
    ...<3 lines>...
ValueError: Can only integrate scalar expressions. The integrand is a tensor expression with value shape (3,) and free indices with labels ().
Here is the complete code:
import dolfinx, ufl
import ufl.classes
R = 1.0
grid_size = 0.2
order = 2
    if np.allclose(com, [0, 0, 0]): # 平面
        plane = surface
mesh, cell_marker, facet_marker = dolfinx.io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=3)
gmsh.finalize()
form2 = dolfinx.fem.form(ufl.dot(ufl.curl(F), cell_normal_vector)* dx(10))
print(dolfinx.fem.assemble_scalar(form2))
