How to run poisson extended
How do I run the program “ft10_poisson_extended.py”, which comes as part of the tutorial vol. 1? I encounter errors.
  1. I suppose I have to download boxfield.py
  2. Then I suppose I have to copy “a part” or “whole program” of the code written in ft10_poisson_exteded.py?
Could you create a minimal working example, or post a link to what you’re referring?
See for example: Read before posting: How do I get my question answered?
Thanks for @nate your response.
from future import print_function
from boxfield import *
def demo_bcs():
“Compute and plot solution using a combination of boundary conditions”
# Define manufactured solution in sympy and derive f, g, etc.
import sympy as sym
x, y = sym.symbols('x[0], x[1]')            # needed by UFL
u = 1 + x**2 + 2*y**2                       # exact solution
u_e = u                                     # exact solution
u_00 = u.subs(x, 0)                         # restrict to x = 0
u_01 = u.subs(x, 1)                         # restrict to x = 1
f = -sym.diff(u, x, 2) - sym.diff(u, y, 2)  # -Laplace(u)
f = sym.simplify(f)                         # simplify f
g = -sym.diff(u, y).subs(y, 1)              # compute g = -du/dn
r = 1000                                    # Robin data, arbitrary
s = u                                       # Robin data, u = s
# Collect variables
variables = [u_e, u_00, u_01, f, g, r, s]
# Turn into C/C++ code strings
variables = [sym.printing.ccode(var) for var in variables]
# Turn into FEniCS Expressions
variables = [Expression(var, degree=2) for var in variables]
# Extract variables
u_e, u_00, u_01, f, g, r, s = variables
# Define boundary conditions
boundary_conditions = {0: {'Dirichlet': u_00},   # x = 0
                       1: {'Dirichlet': u_01},   # x = 1
                       2: {'Robin':     (r, s)}, # y = 0
                       3: {'Neumann':   g}}      # y = 1
# Compute solution
kappa = Constant(1)
Nx = Ny = 8
u = solver_bcs(kappa, f, boundary_conditions, Nx, Ny,
               degree=1, linear_solver='direct')
# Compute maximum error at vertices
mesh = u.function_space().mesh()
vertex_values_u_e = u_e.compute_vertex_values(mesh)
error_max = np.max(np.abs(vertex_values_u_e -
                          vertex_values_u))
print('error_max =', error_max)
# Save and plot solution
vtkfile = File('poisson_extended/solution_bcs.pvd')
vtkfile << u
plot(u)
def solver_bcs(kappa, f, boundary_conditions, Nx, Ny,
degree=1,
subdomains=[],
linear_solver=‘Krylov’,
abs_tol=1E-5,
rel_tol=1E-3,
max_iter=1000):
Solve -div(kappagrad(u) = f on (0, 1) x (0, 1) with 2Nx*Ny Lagrange
elements of specified degree and u = u_D on the boundary. This version
of the solver uses a specified combination of Dirichlet, Neumann, and
Robin boundary conditions.
mesh = UnitSquareMesh(Nx, Ny)
V = FunctionSpace(mesh, 'P', degree)
# Check if we have subdomains
if subdomains:
    if not isinstance(kappa, (list, tuple, np.ndarray)):
        raise TypeError(
            'kappa must be array if we have sudomains, not %s'
            % type(kappa))
    materials = CellFunction('size_t', mesh)
    materials.set_all(0)
    for m, subdomain in enumerate(subdomains[1:], 1):
        subdomain.mark(materials, m)
    kappa_values = kappa
    V0 = FunctionSpace(mesh, 'DG', 0)
    kappa  = Function(V0)
    help = np.asarray(materials.array(), dtype=np.int32)
    kappa.vector()[:] = np.choose(help, kappa_values)
    if not isinstance(kappa, (Expression, Constant)):
        raise TypeError(
            'kappa is type %s, must be Expression or Constant'
            % type(kappa))
# Define boundary subdomains
tol = 1e-14
class BoundaryX0(SubDomain):
        return on_boundary and near(x[0], 0, tol)
class BoundaryX1(SubDomain):
        return on_boundary and near(x[0], 1, tol)
class BoundaryY0(SubDomain):
        return on_boundary and near(x[1], 0, tol)
class BoundaryY1(SubDomain):
        return on_boundary and near(x[1], 1, tol)
# Mark boundaries
boundary_markers = FacetFunction('size_t', mesh)
boundary_markers.set_all(9999)
bx0 = BoundaryX0()
bx1 = BoundaryX1()
by0 = BoundaryY0()
by1 = BoundaryY1()
bx0.mark(boundary_markers, 0)
bx1.mark(boundary_markers, 1)
by0.mark(boundary_markers, 2)
by1.mark(boundary_markers, 3)
# Redefine boundary integration measure
# Collect Dirichlet conditions
bcs = []
for i in boundary_conditions:
    if 'Dirichlet' in boundary_conditions[i]:
        bc = DirichletBC(V, boundary_conditions[i]['Dirichlet'],
                         boundary_markers, i)
        bcs.append(bc)
debug1 = False
if debug1:
    # Print all vertices that belong to the boundary parts
    for x in mesh.coordinates():
        if bx0.inside(x, True): print('%s is on x = 0' % x)
        if bx1.inside(x, True): print('%s is on x = 1' % x)
        if by0.inside(x, True): print('%s is on y = 0' % x)
        if by1.inside(x, True): print('%s is on y = 1' % x)
    # Print the Dirichlet conditions
    print('Number of Dirichlet conditions:', len(bcs))
    if V.ufl_element().degree() == 1:  # P1 elements
        d2v = dof_to_vertex_map(V)
        coor = mesh.coordinates()
        for i, bc in enumerate(bcs):
            print('Dirichlet condition %d' % i)
            boundary_values = bc.get_boundary_values()
            for dof in boundary_values:
                print('   dof %2d: u = %g' % (dof, boundary_values[dof]))
                    print('    at point %s' %
                          (str(tuple(coor[d2v[dof]].tolist()))))
# Collect Neumann integrals
integrals_N = []
    if 'Neumann' in boundary_conditions[i]:
        if boundary_conditions[i]['Neumann'] != 0:
            g = boundary_conditions[i]['Neumann']
            integrals_N.append(g*v*ds(i))
# Collect Robin integrals
integrals_R_a = []
integrals_R_L = []
    if 'Robin' in boundary_conditions[i]:
        r, s = boundary_conditions[i]['Robin']
        integrals_R_a.append(r*u*v*ds(i))
        integrals_R_L.append(r*s*v*ds(i))
# Simpler Robin integrals
integrals_R = []
        integrals_R.append(r*(u - s)*v*ds(i))
# Sum integrals to define variational problem
a = kappa*dot(grad(u), grad(v))*dx + sum(integrals_R_a)
L = f*v*dx - sum(integrals_N) + sum(integrals_R_L)
# Simpler variational problem
F = kappa*dot(grad(u), grad(v))*dx + \
    sum(integrals_R) - f*v*dx + sum(integrals_N)
a, L = lhs(F), rhs(F)
# Set linear solver parameters
prm = LinearVariationalSolver.default_parameters()
if linear_solver == 'Krylov':
    prm.linear_solver = 'gmres'
    prm.preconditioner = 'ilu'
    prm.krylov_solver.absolute_tolerance = abs_tol
    prm.krylov_solver.relative_tolerance = rel_tol
    prm.krylov_solver.maximum_iterations = max_iter
    prm.linear_solver = 'lu'
# Compute solution
solve(a == L, u, bcs, solver_parameters=prm)
return u
I am trying to run programs in the “Section 4.4 Setting multiple Dirichlet, Neumann, and
Robin conditions.”
I am going through the example problem in page 97, and in Page 98 of “Solving PDEs in Python
– The FEniCS Tutorial Volume I.”
  1. In Page 97, it is said that “The complete code can be found in the function solver_bcs in the pro-gram ft10_poisson_extended.py.”
  2. In page, 98, it is mentioned “The complete code can be found in the function demo_bcs in the program ft10_poisson_extended.py.”
The exact problem can be found in
https://raw.githubusercontent.com/hplgit/fenics-tutorial/master/pub/python/vol1/ft10_poisson_extended.py
I have downloaded the boxfield.py from
I have the same problem, did you solve it? And my fenics version is 2019.1.0
Please note that FEniCS v2019.1.0 is considered legacy, see: The new DOLFINx solver is now recommended over DOLFIN
However, if you want to use the FEniCS tutorial (which was built on FEniCS 2016.1.0), you should have a look at the files in this PR: Fix almost every outdated tutorial by JSS95 · Pull Request #74 · hplgit/fenics-tutorial · GitHub
An updated version of the FEniCS tutorial for DOLFINx can be found at: The FEniCSx tutorial — FEniCSx tutorial
Thank you for your answers and suggestions. :smile: At present, I am still using the fenics v2019.1.0 for research, and I will try to use fenicsx later.
