Issue with the get_local. max() function
Hey guys. I have an issue when using get_local.max() function
So first for my code, I am using a 1D interval
mesh = IntervalMesh(1000, 0, 1)
And after solving the problem. I want to find the max value and plot it, so I use
print(theta_list[999].vector().get_local().max())
plt.ylim(0, 3.14)
plot(theta_list[999])
To my surprise. The local max output is 53.64738743162838 but the plot clearly shows that the max on the interval (0, 1) is below 2. the plot looks like this
Any help and suggestions are appreciated!
Some more details. I add local_range and max_index. It seems they are not consistent with the graph.
The codes are
max_index = np.argmax(theta_list[999].vector()[:])
x= ME.tabulate_dof_coordinates()
print(x[max_index])
print(theta_list[999].vector().local_range())
plt.ylim(0, 3.14)
outputs are
[0.499]
53.64669017236389
(0, 2002)
but the plot looks like this
In case you need the whole codes are
from tqdm import tqdm
import random
# Define 1D mesh and space
set_log_level(40)
Element1 = FiniteElement("CG", mesh.ufl_cell(), 1)
Element2 = FiniteElement("CG", mesh.ufl_cell(), 1)
W_elem = MixedElement([Element1, Element2])
ME = FunctionSpace(mesh, W_elem)
# Define functions
u_old = Function(ME)
u_new = Function(ME)
theta_old, vy_old = split(u_old)
theta_new, vy_new = split(u_new)
vy_mid = 0.5 * vy_old + 0.5 * vy_new
theta_mid = 0.5 * theta_old + 0.5 * theta_new
tf = TestFunction(ME)
q, v = split(tf)
kapa_ga = 1
lamb = 1.5
f1 = lamb * cos(2 * theta_mid)
alpha = -450
f2 = alpha * cos(2 * theta_new)
dt = 0.01
# Boundary condition
def boundary(x, on_boundary):
    return on_boundary
bc = DirichletBC(ME, [Constant(1.57), Constant(0)], boundary)
# Initial Condition
class InitialConditions(UserExpression):
    def eval(self, values, x):
        values[0] = 1.57+0.01*random.gauss(0, 1)
        values[1] = 0
    def value_shape(self):
        return (2,)
# Set initial conditions to old function
u_init = InitialConditions()
u_old.interpolate(u_init)
# Weak statement of the equations
F0 = (theta_new - theta_old) / dt * q * dx + kapa_ga*theta_mid.dx(0) * q.dx(0) * dx - 0.5 * (f1 + 1) * vy_mid.dx(0) * q * dx
F1 = (-vy_new.dx(0) * v.dx(0)) * dx + f2 * theta_new.dx(0) * v * dx
F = F0 + F1
t = 0.0
T = 1000 * dt
theta_list = []
vy_list = []
for t in tqdm(np.arange(0, 10.01, 0.01)):
    solve(F == 0, u_new, bc)
    u_old.vector()[:] = u_new.vector()
    u_copy = Function(ME)
    u_copy.vector()[:] = u_new.vector()
    theta_list.append(u_copy.split()[0])
    vy_list.append(u_copy.split()[1])
print(x[max_index])
plt.ylim(0, 3.14)
