Spline model for strain energy
Hallo, I want to calculate the traction and strain curve for a beam with a nonlinear spline to model the strain energy. Basically I want to have a specific spline response in my final plot. I could not find how to do that, I attached the code I am working on. Could you please help me? Thanks.
I am doing a huge mistake probably but here is my code:
import sys
from scipy.interpolate import CubicSpline
ffc_options = {"optimize": True,
               "eliminate_zeros": True,
               "precompute_basis_const": True,
               "precompute_ip_const": True}
un = "trial"
b = 1
lc = 1e-1 * 10
def createGeometryAndMesh(b):
    # Clear all models and create a new one
    gmsh.clear()
    gmsh.model.add("t3")
    P1 = gmsh.model.occ.addPoint(-b , 0, 0, lc)
    P2 = gmsh.model.occ.addPoint(b, scale *0, 0, lc)
    P3 = gmsh.model.occ.addPoint(-b,  b , 0, lc)
    P4 = gmsh.model.occ.addPoint(b ,  b , 0, lc)
    L1 = gmsh.model.occ.addLine(P1, P2)
    L2 = gmsh.model.occ.addLine(P2, P4)
    L3 = gmsh.model.occ.addLine(P4, P3)
    L4 = gmsh.model.occ.addLine(P3, P1)
    Curve1 = gmsh.model.occ.addCurveLoop([L1, L2, L3, L4])
    Surface1 = gmsh.model.occ.addPlaneSurface([Curve1],  1)
    # Synchronize the CAD model
    gmsh.model.occ.synchronize()
    # Create physical groups
    pg1 = gmsh.model.addPhysicalGroup(2, [Surface1])
    gmsh.model.setPhysicalName(2, pg1, "beam")
    # Set mesh size at all points
    gmsh.model.mesh.setSize(gmsh.model.getEntities(0), lc)
    gmsh.option.setNumber("Mesh.MshFileVersion", 2.2)
    gmsh.model.mesh.generate()
    def checkForEvent():
        action = gmsh.onelab.getString("ONELAB/Action")
        if len(action) and action[0] == "check":
            gmsh.onelab.setString("ONELAB/Action", [""])
            createGeometryAndMesh()
            gmsh.graphics.draw()
        return True
    # Refine the mesh
    gmsh.model.mesh.refine()
    gmsh.write("t3.opt");
    gmsh.finalize()
# Importing mesh from gmsh and defining surface and boundary markers
msh = meshio.read("./Result--" + str(un)+ "geo.msh")
    if key == "triangle":
for cell in msh.cells:
    if cell.type == "tetra":
        tetra_cells = cell.data
    elif cell.type == "triangle":
        triangle_cells = cell.data
triangle_mesh = meshio.Mesh(points=msh.points,
                            cell_data={"name_to_read": [triangle_data]})
meshio.write("./Result--" + str(un)+ "mesh.xdmf",
             triangle_mesh)
mesh = Mesh()
    infile.read(mesh)
print(mesh.topology().dim() - 1)
boundary_markers = MeshFunction('size_t', mesh, mesh.topology().dim() - 1, 0)
class Boundary(SubDomain):
        return on_boundary and near(x[1], 0.0)
b_c = Boundary()
b_c.mark(boundary_markers, 3)
File("./Result--" + str(un)+  "MSH3.pvd") << boundary_markers
# Compiling subdomains
dx = Measure("dx", domain=mesh, subdomain_data=mf, subdomain_id=1)
V = VectorFunctionSpace(mesh, "CG", 2)
W_tensor = TensorFunctionSpace(mesh, "CG", 2)
def boundary_bot(x, on_boundary):
    tol = 1E-7
    return on_boundary and near(x[1], 0, tol)
bc_bot = DirichletBC(V, [0, 0, 0], boundary_bot)
def boundary_top(x, on_boundary):
    tol = 1E-7
    return on_boundary and near(x[1], b, tol)
disp = Constant([0.0, 0.0, 0.0])
bc_top = DirichletBC(V, disp, boundary_top)
bcs = [bc_bot, bc_top]
du = TrialFunction(V)  # Incremental displacement
v = TestFunction(V)  # Test function
u = Function(V)  # Displacement from previous iteration
u0 = Function(V)  # Initial displacement
boundary_subdomains = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
boundary_subdomains.set_all(0)
AutoSubDomain(boundary_top).mark(boundary_subdomains, 1)
dss = ds(subdomain_data=boundary_subdomains)
def kinematics(u):
    # Kinematics
    d = u.geometric_dimension()  # Space dimension
    I = Identity(d)  # Identity tensor
    F = variable(I + grad(u))  # Deformation gradient
    C = F.T * F  # Right Cauchy-Green tensor
    Ic = tr(C)
    J = det(F)
    return Ic, J, F, C
from scipy import interpolate
# Strain data points and energy values
strain_values = [0.0, 0.6, 0.19, 0.25]
energy_values = [0.0, 0.03, 0.005, 0.047]
if any(strain_values[i] >= strain_values[i+1] for i in range(len(strain_values)-1)):
    # If there are repeated or non-unique values, preprocess the data
    unique_strain_values, unique_indices = np.unique(strain_values, return_index=True)
    unique_energy_values = [energy_values[i] for i in unique_indices]
    strain_values = list(unique_strain_values)
    energy_values = list(unique_energy_values)
# Calculate the spline for strain-energy interpolation
spline = CubicSpline(strain_values, energy_values)
# Solve variational problem
store_u = np.linspace(0, -0.4, 50 , endpoint=True)
normal = Constant((0, 1, 0))
# Define the stress tensor function space
V_tensor = TensorFunctionSpace(mesh, "CG", 2)
force = []
for i in store_u:
    disp.assign(Constant([0.0, i, 0.0]))
    Ic, J, F, C = kinematics(u)
    # Define the custom strain energy density function
    def psi(F, u, i):
        strain = i
        energy = Constant(spline(strain))
        stress = diff(energy, F)
        return energy, stress
    psi, stress = psi(F, u, i)
    # Total potential energy
    Pi= psi * dx
    # Compute first variation of Pi (directional derivative about u in the direction of v)
    dPi = derivative(Pi, u, v)
    # Compute second variation of Pi (directional derivative about du in the direction of v)
    ddPi= derivative(dPi, u, du)
    # Define the nonlinear variational problem with Jacobian
    problem = NonlinearVariationalProblem(dPi u, bcs, J=ddPi)
    solver.solve()
    # Create a new Function with the same FunctionSpace as stress to store the stress tensor
    stress_calculation = Function(W_tensor, name='Stress')
    stress_calculation.assign(stress)  # Assign the stress tensor to stress_calculation directly
    # Compute traction (force) on the boundary
    traction = dot(stress, normal)
    force.append(assemble((traction[1]) * dss(1)) )
Hi, I am not able to follow what are you trying to do here, please explain.
Pi_main is not defined.
Hi, thank you for replying. I edited the code. I am trying to have spline response for my strain energy. @violetus
I have modified the code in bits so that it is clear to discuss where the problem is arising -
Making geometry
import sys
un = "trial"
b = 1
lc = 1e-1 * 10
scale = 1
    gmsh.clear()
        return True
    # Refine the mesh
    gmsh.write("geo.msh");
    gmsh.finalize()
Importing mesh using meshio
msh = meshio.read("geo.msh")
meshio.write("mesh.xdmf",triangle_mesh)
mesh = Mesh()
    infile.read(mesh)
Defining boundary conditions
b_c = Boundary()
File("msh3.pvd") << boundary_markers
W_tensor = TensorFunctionSpace(mesh, "DG", 0)
    tol = 1E-7
    tol = 1E-7
Defining function spaces and kinematics
def kinematics(u):
    # Kinematics
    Ic = tr(C)
    J = det(F)
    return Ic, J, F, C
Strain and energy values preprocessing
V_tensor = TensorFunctionSpace(mesh, "DG", 0)
Iterative loop for setting up solver and solving
force = []
for i in store_u:
    def psi(F, u, i):
        strain = i
    Pi= psi * dx
    problem = NonlinearVariationalProblem(dPi, u, bcs, J=ddPi)
    solver.solve()
Executing the last block is giving me error -
/tmp/ipykernel_383/4227113402.py in <module>
     20     problem = NonlinearVariationalProblem(dPi, u, bcs, J=ddPi)
     21     solver = NonlinearVariationalSolver(problem)
---> 22     solver.solve()
RuntimeError:
*** Error:   Unable to successfully call PETSc function 'MatSetValuesLocal'.
*** Reason:  PETSc error code is: 63 (Argument out of range).
*** Where:   This error was encountered inside ./dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** Git changeset:  ubuntu
This issue is arising because energy is constant and differentiating it wrt F return 0 which is similar to the issue seen in this post Error: Unable to successfully call PETSc function ‘MatSetValuesLocal’. Reason: PETSc error code is: 63 (Argument out of range), As suggested by @dokken in the post, you might want to have a look at Hyperelasticity — DOLFIN documentation.
I hope this helps.
thank you! @violetus
Hello again, @violetus, sorry I am not too familiar with these much, I could not solve the problem. Do you have any more suggestion?
Consider reading Incompressible Humphrey hyperelastic material in Fencis, this might be of your interest.
Here I defined strain again by following the hyperelasticity document. However I could not find how to manipulate the strain energy to have a specific spline respond.
    def psi(u, i, Ic, J, F, C):
        # Kinematics
        Ic = tr(C)
        J = det(F)
        # Define the strain energy density function
        def strain_energy_density(Ic):
            return (E2 / 2) * (Ic - 3)
        # Calculate the strain tensor
        strain = C - Ic * I
        # Calculate the energy and stress using the strain energy density function
        energy = strain_energy_density(Ic)
What do you mean by E2 here ?
E2 = calculate_spline(x_values, y_values, i)
Ok, maybe I have to workaround the code a bit and fully understand what’s going on there. On the side note, I tried to plot original data and interpolated data using -
store_u = np.linspace(0, -0.4, 50, endpoint=True)
# Calculate energy values using the spline for the given strain values
interpolated_energy_values = spline(store_u)
# Plot the original data points
plt.plot(strain_values, energy_values, 'o', label='Original Data')
# Plot the interpolated data using the spline
plt.plot(store_u, interpolated_energy_values, label='Interpolated Data')
plt.xlabel('Strain')
plt.ylabel('Energy')
plt.title('Strain-Energy Interpolation')
plt.legend()
plt.grid(True)
Could you please interpret the plot and tell what you are trying to achieve exactly ?
Also I would strongly suggest you to go through this post Incompressible Humphrey hyperelastic material in Fencis which shows how you can make user-defined functions and use them.
@violetus Yes, you’re right, I’m checking it out. It’s a little hard to understand as I’m new to Fenics.
What I want to do is: I want to apply a displacement from top to a rectangular. I want the obtain a force-displacement graph from this. This graph should give me a spline with known 3 or 4 points that I want.
I also want to thank you very much for your great help.
I think the post Incompressible Humphrey hyperelastic material in Fencis is doing the same thing which you want to achieve, the author is giving a time-dependent displacement and then calculating the stress corresponding to that and hence pressure vs displacement graph comes out to be like -
yes, I also divided it into steps like they did with time. However, I still haven’t figured out how to define the strain energy to have this curve.
In the context of the post Incompressible Humphrey hyperelastic material in Fencis the author defines strain energy density as -
psi = inner(dot(dgF,pkstrs), grad(_u))
In Hyperelasticity — DOLFIN documentation the author defines the strain energy density as -
psi = (mu/2)*(Ic - 3) - mu*ln(J) + (lmbda/2)*(ln(J))**2
So, I think it depends on the user which model they want to choose.
where I define spline points as:
def calculate_spline(x_values, y_values, x):
    # Calculate spline coefficients
    spline = CubicSpline(x_values, y_values)
    y = spline(x)
    return y
# Define the spline values
x_values = [0, 0.06, 0.19, 0.25]
y_values = [0, 0.03, 0.005, 0.047]
then I calculate psi as below:
for i in store_u:
        # Kinematics
        Ic = tr(C)
        J = det(F)
        def strain_energy_density(u, strain):
            energy = inner(dot(F, strain), grad(u))
            return energy
        strain = C - Ic * I - calculate_spline(x_values, y_values, i)*inv(C)
        energy = strain_energy_density(u, strain)
it is working but the result is not correct
Can you please share the results ? And tell that what you were expecting instead of that.
this is the result I got: @violetus
I want to have something like this spline with the defined points. I want to have a specific response like this spline from my simulation.
You need to apply different energy model to get the type of response you want, so the result you are getting is most probably from Neo-Hookean energy model. I am getting a vague idea that what you are attempting to simulate is viscoelasticity therefore I would suggest you to go through this post Issues with a viscoelastic problem.
