Hi! Hope everyone is safe and healthy.
I am a little (read: very) confused with turning my solutions from FEniCS functions to BoxField objects. I really want to do that as I must work with matplotlib (for instance, show my solutions as contour plots streamplots, etc).
I will be using the poisson equation as an example, in a square domain, as well as on a circular domain. For the square domain,
#Create mesh and define function space
nx=22
ny=22
mesh = UnitSquareMesh(nx, ny)
and solve just as in the example ft01_poisson.py. Then, after obtaining my FEniCS function u, I write
u_box = FEniCSBoxField(u, (nx, ny))
#Set coordinates and extract values
X = 0; Y = 1
u_ = u_box.values
cv = u_box.grid.coorv
following ft10_poisson_extended.py especially line 564.
This works fine!
Now, suppose however my domain is not the one above, but rather the unit disk. In this case, I have
domain = Circle(Point(0,0),1)
mesh = generate_mesh(domain, 64)
How would I now represent u as a structured field? I am a little confused about how Iād do this generally.
Please note that the problem I ultimately want to solve will have u (the solution) as a 3D vector, and the domain will be a cone. Suppose I have solved the Poisson equation inside the cone and I have u as a FEniCS function. How would I represent it as a structure field in order to be able to plot it with matplotlib?
Thanks!
