Since a while I am trying to implement the custom kernels and custom assembler in dolfinx. I encounter a type mismatch error when calling the dolfinx.cpp.fem.Form_float64(…)
even though I was following the unit test example
python/test/unit/fem/test_custom_jit_kernels.py
Then, quite surprisingly, I discovered that when running the unit test, the same type mismatch error is thrown:
>>> test_coefficient(np.float64)
File "<stdin>", line 1, in <module>
File "/workspace/acegen_fenics/tests/test_custom_jit_kernels.py", line 138, in test_coefficient
L = Form(formtype([V._cpp_object], integrals, [vals._cpp_object], [], False, {}, None))
TypeError: __init__(): incompatible function arguments. The following argument types are supported:
1. __init__(self, spaces: list[dolfinx.cpp.fem.FunctionSpace_float64], integrals: dict[dolfinx.cpp.fem.IntegralType, list[tuple[int, int, ndarray[dtype=int32, writable=False, shape=(*), order='C']]]], coefficients: list[dolfinx.cpp.fem.Function_float64], constants: list[dolfinx.cpp.fem.Constant_float64], need_permutation_data: bool, entity_maps: dict[dolfinx.cpp.mesh.Mesh_float64, ndarray[dtype=int32, writable=False, shape=(*), order='C']], mesh: Optional[dolfinx.cpp.mesh.Mesh_float64]) -> None
2. __init__(self, form: int, spaces: list[dolfinx.cpp.fem.FunctionSpace_float64], coefficients: list[dolfinx.cpp.fem.Function_float64], constants: list[dolfinx.cpp.fem.Constant_float64], subdomains: dict[dolfinx.cpp.fem.IntegralType, list[tuple[int, ndarray[dtype=int32, writable=False, shape=(*), order='C']]]], entity_maps: dict[dolfinx.cpp.mesh.Mesh_float64, ndarray[dtype=int32, writable=False, shape=(*), order='C']], mesh: Optional[dolfinx.cpp.mesh.Mesh_float64]) -> None
Invoked with types: dolfinx.cpp.fem.Form_float64, list, dict, list, list, bool, dict, NoneType
Is there a bug in the unit test or I am not using it properly?
Thank you in advance for an advice/help!
Jakub
