I’m trying to simulate a flow problem with no slip boundary conditions, free boundary conditions, and setting a pressure of 0 to one node.
I was able to set up the boundary conditions, but I am also trying to include a constant body force. I included this in the variational formulation:
Force_per_unit_vol = fem.Function(V)
Force_per_unit_vol.interpolate(lambda x: body_force_fun(x))
F = rho_air*inner(grad(u)*u, v)*dx + \
mu_air*inner(grad(u), grad(v))*dx + \
inner(Force_per_unit_vol, v) - \
inner(p, div(v))*dx - \
div(u)*q*dx
Is this correct? If so, what is the output of body_force_fun(x)? Is it a numpy array with the same shape as x? I’m looking to compute something like this:
def body_force_fun(x):
F_max = 1.0e-6
z_offset = 0.01
r_xy = np.sqrt(x[0]**2 + x[1]**2)
if r_xy < 1.0e-8:
return [0, 0, 0]
a = 0.005
max_val = np.sqrt(a/2) * np.exp(-0.5)
r_val = r_xy*np.exp(-r_xy**2/(2*a^2)) / max_val
b = 0.005
z_val = np.exp(-(x[2]-z_offset)**2/(2*b^2))
F_mag = F_max * r_val * z_val
return F_mag / r_xy * [x[1], -x[0], 0]
The full code is below.
Thank you,
Alex
from ufl import inner, div, grad, dx
import basix
vol_mesh = meshio.read('mesh.vtk')
points = vol_mesh.points
cells = vol_mesh.cells[1].data
c_el = ufl.Mesh(basix.ufl.element("Lagrange", "tetrahedron", 1, shape=(points.shape[1],)))
msh = mesh.create_mesh(MPI.COMM_WORLD, cells, points, c_el)
fdim = msh.topology.dim - 1
msh.topology.create_connectivity(fdim, fdim+1)
# Array geometry variables
h_array_1 = 0.02 # Part of height of array's cylindrical section
h_array_2 = 0.035 # Height of array's truncated conical section
h_gap = 0.03 # Gap between array and horizontal surface where powder is falling
rho_air = 1.225
mu_air = 1.8e-2
mark_eps = 1.0e-8
# Function to mark array noslip
def noslip_boundary1(x):
return np.logical_and(x[2] < h_array_2, x[2] > -h_array_1)
# Function to mark table surface noslip
def noslip_boundary2(x):
return np.isclose(x[2], (h_array_2 + h_gap))
# the same as old ufl.VectorElement
# the same as old ufl.FiniteElement
P2 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 2, shape=(msh.geometry.dim, ))
P1 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 1)
V, Q = fem.functionspace(msh, P2), fem.functionspace(msh, P1)
# Create the function space
TH = basix.ufl.mixed_element([P2, P1])
W = fem.functionspace(msh, TH)
W0, _ = W.sub(0).collapse()
# No slip boundary condition 1
noslip = fem.Function(V)
facets1 = mesh.locate_entities_boundary(msh, fdim, noslip_boundary1)
dofs1 = fem.locate_dofs_topological((W.sub(0), V), fdim, facets1)
bc0 = fem.dirichletbc(noslip, dofs1, W.sub(0))
# No slip boundary condition 2
facets2 = mesh.locate_entities_boundary(msh, fdim, noslip_boundary2)
dofs2 = fem.locate_dofs_topological((W.sub(0), V), fdim, facets2)
bc1 = fem.dirichletbc(noslip, dofs2, W.sub(0))
# Since for this problem the pressure is only determined up to a constant, we pin it at a point
zero = fem.Function(Q)
zero.x.array[:] = 0
dofs = fem.locate_dofs_geometrical(
(W.sub(1), Q), lambda x: np.isclose(x.T, [0, 0, -h_array_1]).all(axis=1))
bc2 = fem.dirichletbc(zero, dofs, W.sub(1))
F_max = 1.0e-6
z_offset = 0.01
if r_xy < 1.0e-8:
return [0, 0, 0]
a = 0.005
b = 0.005
bcs = [bc0, bc1, bc2]
w = fem.Function(W)
(u, p) = ufl.split(w)
(v, q) = ufl.TestFunctions(W)
# Tentative velocity step
# https://github.com/bragostin/Fenics/blob/main/HTC_SquareDuct_Steady_Neumann_Minimal_Pub.py
div(u)*q*dx
dw = ufl.TrialFunction(W)
dF = ufl.derivative(F, w, dw)
problem = NonlinearProblem(F, w, bcs=bcs, J=dF)
solver.rtol = 1e-6
solver.report = True
solver.error_on_nonconvergence = True
#solver.max_it = 10
# Compute the solution
solver.solve(w)
u = w.sub(0).collapse()
p = w.sub(1).collapse()
# Write the solution to file
with io.XDMFFile(MPI.COMM_WORLD, "pressure.xdmf", "w") as pfile_xdmf:
p.x.scatter_forward()
pfile_xdmf.write_mesh(msh)
pfile_xdmf.write_function(p)
with io.XDMFFile(MPI.COMM_WORLD, "velocity.xdmf", "w") as ufile_xdmf:
u.x.scatter_forward()
P1 = basix.ufl.element("Lagrange", msh.basix_cell(), 1, shape=(msh.geometry.dim,))
u1 = fem.Function(fem.functionspace(msh, P1))
u1.interpolate(u)
ufile_xdmf.write_mesh(msh)
ufile_xdmf.write_function(u1)
