I do not know what I am doing wrong. Perhaps something basic. But the Temperature is initially very high and then suddenly drops to 0.0!!
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
from dolfinx.fem import (Constant, Function, functionspace, assemble_scalar,
dirichletbc, form, locate_dofs_topological)
from dolfinx.mesh import create_unit_square, locate_entities, meshtags
from ufl import *
import pyvista
import matplotlib as mpl
from petsc4py.PETSc import ScalarType # type: ignore
# !pip install pyvista
Define Problem domain
# Parameters
Torch_rad = 0.5e-4
cell_dim = Torch_rad # Cell dimension for the grid
# Define the corner points of the parallelepiped and the number of cells
point1 = np.array([0.0, 0.0, 0.0])
point2 = np.array([200 * Torch_rad, 20 * Torch_rad, 5 * Torch_rad]) # Adjust these values to define the size of your parallelepiped
# Number of cells in each direction
num_cells = [int(point2[0] / cell_dim), int(point2[1] / cell_dim), int(point2[2] / cell_dim)]
# Create the parallelepiped mesh
domain = mesh.create_box(MPI.COMM_WORLD, [point1, point2], num_cells, cell_type=mesh.CellType.tetrahedron)
point2
array([0.01 , 0.001 , 0.00025])
Visualize Domain
import pyvista as pv
pv.set_jupyter_backend('static')
with XDMFFile(MPI.COMM_WORLD, "workspace/domain.xdmf", "w") as xdmf_file:
xdmf_file.write_mesh(domain)
# Load the mesh with pyvista
grid = pv.read("workspace/domain.xdmf")
# Plot the mesh using PyVista
plotter = pv.Plotter()
plotter.show()
V = fem.functionspace(domain, ("CG", 1))
Define Material Property
# Define material properties
rho = fem.Constant(domain, PETSc.ScalarType(7870.0)) # Density
cp = fem.Constant(domain, PETSc.ScalarType(500.0)) # Specific heat capacity
k = fem.Constant(domain, PETSc.ScalarType(16.0)) # Thermal conductivity
# Define temporal parameters
t = 0.0 # Initialize time as a UFL constant
t_end = 0.008 # Final time
# dt = 0.000025
theta = 1.0
# num_steps = 100
dt = 0.0004
num_steps = int(t_end/dt)
print(f"<num_steps>")
# t_end / num_steps # time step size
fr = 0.1
<num_steps>
CFL = fr*dt/cell_dim
print(CFL)
0.8
Define initial condition
# Create initial condition
def initial_condition(x):
return x[0]*0+295.0
# Define the initial condition
# ic = InitialCondition()
T_n = fem.Function(V)
T_n.name = "T_n"
T_n.interpolate(initial_condition)
T_n.vector.array.shape
(25326,)
Boundary Condition
Neumann BC
class MovingHeatSource:
def __init__(self,t, Q=100.0, Torch_rad=Torch_rad, fr=fr):
self.Torch_rad = Torch_rad # Radius of the heat source
self.fr = fr # Feed rate of the moving heat source
self.q = Q/(np.pi*Torch_rad**2)
# print(self.q)
self.t = t
def __call__(self, x):
# Calculate the current position of the moving heat source
xc = point2[0]*0.1 + self.fr * t
yc = point2[1]/2 # Assume a fixed y-coordinate for simplicity
zc = point2[2]
# print('I am here')
# Calculate the distance from the heat source center
r = ((x[0] - xc)**2 + (x[1] - yc)**2)**0.5
# Set sigma based on the torch radius for rapid decay
in_z_plane = np.isclose(x[2], zc)
sigma = self.Torch_rad / 3 # Adjust sigma as needed for faster decay
heat_expr = self.q * np.exp(-r**2 / (2 * sigma**2)) * in_z_plane
return heat_expr
Define domain boundaries
boundaries = [(1, lambda x: np.isclose(x[2], point2[2])),# upper z surface where heat source is moving
(2, lambda x: np.isclose(x[2], point1[2])),
(3, lambda x: np.isclose(x[1], point2[1])),
(4, lambda x: np.isclose(x[1], point1[1])),
(5, lambda x: np.isclose(x[0], point2[0])),
(6, lambda x: np.isclose(x[0], point1[0]))]
facet_indices,facet_markers = [], []
facets = locate_entities(domain, fdim, locator)
facet_indices.append(facets)
facet_tag = meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
import os
notebook_dir = os.getcwd()
Debugging boundary condition
domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
with XDMFFile(domain.comm, notebook_dir +"/facet_tags.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
xdmf.write_meshtags(facet_tag, domain.geometry)
ds = Measure("ds", domain=domain, subdomain_data=facet_tag)
We can now create a general boundary condition class
T = TrialFunction(V)
class BoundaryCondition():
def __init__(self, type, marker, values,dt=None):
self._type = type
if type == "Dirichlet":
u_D = Function(V)
u_D.interpolate(values)
facets = facet_tag.find(marker)
dofs = locate_dofs_topological(V, fdim, facets)
self._bc = dirichletbc(u_D, dofs)
elif type == "Neumann":
# self._bc = dt * inner(values, v) * ds(marker) #notice dt
self._bc = -inner(values, v) * ds(marker) #notice dt
elif type == "Robin":
# self._bc = values[0] * inner(T-values[1], v)* ds(marker)
self._bc = values[0] * inner(T*theta +(1-theta)*T_n -values[1], v)* ds(marker)
raise TypeError("Unknown boundary condition: {0:s}".format(type))
@property
def bc(self):
return self._bc
@property
def type(self):
return self._type
bcs = []
Setup the linear system
# Define solution variable, and interpolate initial solution for visualization in Paraview
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
F = (T * v / dt + theta * k * dot(grad(T), grad(v))) * dx - (T_n * v / dt - (1 - theta) * k * inner(grad(T_n), grad(v))) * dx
# Define the Dirichlet condition
T_inf = lambda x: x[0]*0+298.0
T_infty = T_inf(x)
Using petsc4py to create a linear solver
solver.setTolerances(rtol=1e-6, atol=1e-8)
# List to store solutions and time steps
solutions = []
solutions.append(np.copy(uh.x.array))
time_steps = []
time_steps.append(0.0)
num_steps
20
Solve
for i in range(num_steps):
# num_steps
print(i)
# being an implicit we start with t+dt
heat_source_tn = MovingHeatSource(t)
heat_source_tnp1 = MovingHeatSource(t)
g = Function(V)
g.interpolate(lambda x: theta*heat_source_tnp1(x) + (1-theta)*heat_source_tn(x))
boundary_conditions = [BoundaryCondition("Robin", 2, (25.0, T_infty),dt=dt),
BoundaryCondition("Robin", 3, (25.0, T_infty),dt=dt),
BoundaryCondition("Robin", 4, (25.0, T_infty),dt=dt),
BoundaryCondition("Robin", 5, (25.0, T_infty),dt=dt),
BoundaryCondition("Robin", 6, (25.0, T_infty),dt=dt),
BoundaryCondition("Neumann", 1, g, dt=dt)]
for condition in boundary_conditions:
if condition.type == "Dirichlet":
bcs.append(condition.bc)
F+= condition.bc
# # Define the left-hand side (LHS) and right-hand side (RHS) of the equation
L = rhs(F)
a = lhs(F)
bilinear_form = fem.form(a)
A = assemble_matrix(bilinear_form, bcs=bcs) # we write this because we do not have a dirichlet BC.
solver.setOperators(A)
linear_form = form(L)
b = create_vector(linear_form)
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, fem.form(L))
apply_lifting(b, [bilinear_form], bcs=[bcs])
set_bc(b, bcs=bcs)
# Solve linear problem
solver.solve(b, uh.vector)
uh.x.scatter_forward()
T_n.x.array[:] = uh.x.array
# Store the solution and the current time step
time_steps.append(t)
0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
# import os
# import pyvista as pv
# # Initialize PyVista
# pv.start_xvfb()
# # Assuming V and plot.vtk_mesh(V) are predefined
# grid = pv.UnstructuredGrid(*plot.vtk_mesh(V))
# # Directory to save the VTK files
# output_dir = "workspace/vtk_files_static_laser_point_refined"
# os.makedirs(output_dir, exist_ok=True)
# j=0
# # Iterate over the stored solutions and time steps for writing to VTK
# for i, (solution, t) in enumerate(zip(solutions, time_steps)):
# if i%10==0:
# # Update the grid with the current solution
# print(f"Writing time step {j} to VTK file")
# grid.point_data["uh"] = solution
# # Define the filename
# filename = f"{output_dir}/solution_{j:04d}.vtk"
# # Write the grid to a VTK file
# grid.save(filename)
# j+=1
# print("All files have been written to the VTK format.")
sol=np.array(solutions)
sol.shape
minsol=np.zeros(21)
for i in range(10):
minsol[i]=np.min(sol[i])
minsol
array([ 295. , 100068.37581255, 107831.83703142, 116929.01594176,
135269.08819064, 152687.62496717, 164027.43308872, 168148.15419566,
171988.70673892, 180126.98577475, 0. , 0. ,
0. , 0. , 0. , 0. ,
0. , 0. , 0. , 0. ,
0. ])
# pv.set_jupyter_backend('pythreejs')
# Convert the FEniCSx solution to a PyVista mesh
topology, cell_types, geometry = vtk_mesh(V)
grid = pv.UnstructuredGrid(topology, cell_types, geometry)
# Add the solution to the mesh
grid.point_data["u"] = uh.x.array
# Plot the solution
plotter.add_mesh(grid, show_edges=False, scalars="u", cmap="viridis")
plotter.show()
plotter.export_html('solution.html')
